#11
On Wed, 24 Nov 2004 18:11:12 -0800, Jim Weir wrote:
After a hell of a lot of work and research, I settled on Vertex. THe reasons would take me an hour to lay out, so I won't. I would one would appreciate hearing any of them that related to the units' performance, durability, etc (as opposed to business reasons). all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com the blog www.danford.net |
"Jeff Franks" wrote in message ...
Just wondering if anyone here had experience (good or bad) with Vertex handheld transceivers. I'm about to buy SOMETHING, but I'm not sure whether or not I'm gonna stick with the standard ICOM. I bought the VXA-700 and I'm quite happy with it. I've used it twice now in the air when I've had radio problems (I don't fly with that club anymore). Once to fly back into the Wash. DC ADIZ. I monitor local traffic for my own amusement when I'm on the ground with it too. I like it since it's small and relatively lightweight. It uses a LiON battery so there's a very long battery life. It has a 5W output which is good. It's hardy and robust so that it can bang around in the bottom of my flight bag w/o harm. All of this combined means that it's easy to carry and will have the power to be useful when I need it. If it's NOT easy to carry, then I'm more likely to omit it and not have it when I need it. A bigger and heavier radio, or one that I need to carry a backup battery for, is one I'm less likely to have with me. I bought the headset adapter for the earphone plug. I often just leave that attached to the radio. I can move my headset from the panel to the handheld very quickly if needed. It has the VOR feature, but I've not had occasion to use that. It also gets weather radio (in the US), FM broadcast, and 2 meter band. Ideally, I would prefer a standard earphone/headset plug and standard antenna plug, but it's a minor issue. I'm willing to live with external adapters for the sake of the smaller size and lower weight than ICOM or Sporty's. The thing is waterproof up to 3 feet under, so rain won't hurt it either. There are rubber corners for more protection from getting dropped too. I live under and fly in and around the ADIZ. Loosing a radio here is a big deal. Potentially fighter jets and license suspension type of big deal. Having a robust, powerful, long-life backup radio is a key part of my strategy. I would recommend the VXA-700. -Malcolm Teas |
The nice thing about being on the engineering side of the house (as opposed to
the business side) is that my decisions are based on the quality and technical superiority of one product over another. Business reasons played very little in my decision. I considered the Vertex superior in terms of mechanical design and the resultant reliability. As was pointed out elsewhere, that chicken$#!t advertising 5 watts RF output (and then in small letters "PEP") isn't far from deceptive advertising, but that's the way some other companies are doing it and I guess to be competitive you have to play the game. Actually, you can't really go wrong with either Vertex or Icom. What I wish Vertex would do is come out with a permanent panel mount flatpack like the Icom and then I'd REALLY be happy. Jim Cub Driver shared these priceless pearls of wisdom: -On Wed, 24 Nov 2004 18:11:12 -0800, Jim Weir wrote: - -After a hell of a lot of -work and research, I settled on Vertex. THe reasons would take me an hour to -lay out, so I won't. - -I would one would appreciate hearing any of them that related to the -units' performance, durability, etc (as opposed to business reasons). Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote in message . ..
As was pointed out elsewhere, that chicken$#!t advertising 5 watts RF output (and then in small letters "PEP") isn't far from deceptive advertising, but that's the way some other companies are doing it and I guess to be competitive you have to play the game. I think it is deceptive. More than once I've heard somebody saying that they bought X handheld because it had a 5 watt transmitter. Several of the companies that sell handhelds are using the gimmick. Transmit power on most handhelds is about 1.5 watts. The funny part is that this is plenty of power for the task. You can transmit to the horizon from jet altitudes with 1.5 watts. When I used a handheld as a primary radio (1.5 watt w/ external antenna), I had no problem conversing clearly with Approach when I was 30 miles out. All in all, transmit power is not a big deal for aviation handhelds. John Galban=====N4BQ (PA28-180) |
horizon from jet altitudes with 1.5 watts. [...] ...transmit power is not a big deal for aviation handhelds. One of the uses of a handheld is to get weather, clearances and such on the ground in winter before starting the hobbs meter. I suspect that this is where the extra power comes in handy. Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
Please stop me, Dear Lord, before I answer him in a tone unbecoming of a Thanksgiving weekend... {;-) Jim Jose shared these priceless pearls of wisdom: - -One of the uses of a handheld is to get weather, clearances and such on the ground in winter before starting the hobbs meter. I suspect that this is -where the extra power comes in handy. - -Jose Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
- One of the uses of a handheld is to get weather, clearances and such on the
- ground in winter before starting the hobbs meter. I suspect that this is - where the extra power comes in handy. Please stop me, Dear Lord, before I answer him in a tone unbecoming of a Thanksgiving weekend... Bearing in mind that the sites one might need to reach from the ground might not be located on the same field (in which case a tin can and a string would work), and there could be hills and such in the way, what is wrong with my thinking? Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
Jim Weir wrote:
Please stop me, Dear Lord, before I answer him in a tone unbecoming of a Thanksgiving weekend... Wow, such restraint? An early New Year's resolution perhaps? Impressive! :-) -- Jack Allison PP-ASEL, soon-2-B-IA Student, airplane partnership student "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
"Jose" wrote in message om... - One of the uses of a handheld is to get weather, clearances and such on the - ground in winter before starting the hobbs meter. I suspect that this is - where the extra power comes in handy. Please stop me, Dear Lord, before I answer him in a tone unbecoming of a Thanksgiving weekend... Bearing in mind that the sites one might need to reach from the ground might not be located on the same field (in which case a tin can and a string would work), and there could be hills and such in the way, what is wrong with my thinking? Jose DON'T DO IT JIM! Just send the poor guy a 30 year old ARRL Handbook and maybe he will see the light. Hmmmmm, now, what chapter was it that talked about transmitting through hills at VHF frequencies? |
| Thread Tools | |
| Display Modes | |
| What's next for Garmin handhelds? NEW 296 | MichaelR | Piloting | 3 | March 19th 04 01:50 PM |
| What's next for Garmin handhelds? | Mike Rapoport | Piloting | 13 | March 6th 04 04:58 PM |
| CAD outline of Rans S6S instrument panel? | Rob Turk | Home Built | 2 | October 21st 03 10:27 PM |
| Handhelds and alkaline batteries | Ross Richardson | Piloting | 44 | August 10th 03 01:17 AM |
| Vertex Standard 700 opinions?? | EGWW | Owning | 3 | July 15th 03 02:43 PM |
