28 volt pitot heat
Old April 5th 04, 08:28 PM
Jay
I should have thought of looking there, thanks.
Very strange specs. It says that you need more current on the higher
voltage system, which is wrong. You actually need less than half the
current on the double voltage system to produce the same amount of
heat. So for those pitot tubes it says you need 120W of heat for a
12V airplane and 360W of heat on a 24V airplane. I figure both
airplanes will ice the same regardless of the battery inside.
On the same page there is a pitot heater that needs 3-4 amps at 24V
(90W), so something is fishy here. The 3-4 amp is pretty doable with
a boost converter, the higher current (15 amps) stuff gets a little
fancier.
One idea I'd suggest considering is just running the 24V heater on
your 12V system. Realize that you're only putting 1/4 the heat into
the tube and fly accordingly into icing conditions. Don't fly as
high, as fast, or for as long in ice clouds. Its better than a non
heated tube and you've got a ready to go solution. Later, if you have
time and money, you can add the power supply to give full heat. There
seems to be some variabity anyway on how much heat a pitot tube really
needs to have, compare the 90W vs 360W above which is 1/4.
Regards
(B2431) wrote in message ...
(Jay)
How much power does a typical pitot tube heater need?
Aircraft Spruce shows 10 amps for 12 V and 15 amps for 24 V.
Dan, U.S. Air Force, retired
Old April 6th 04, 01:16 AM
Bushy
You might be able to convert a 12 volt soldeing iron for a lot cheaper than
the "aircraft" item.
A pitot tube is simply a metal tube and if the element will fit around it,
you may be able to roll it yourself.
Hope this helps,
Peter
Old March 29th 04, 12:55 AM
Ray Toews
Don't waste your money and add the weight, learn to fly without a
pitot. mine has been frozen all winter (no place to warm it up) and I
have been doing fine. Kind of works as a back up altimeter tho
Spend the money you save on gas.
Ray
On 26 Mar 2004 22:56:24 GMT, (B2431) wrote:
Will running a 28 volt pitot tube heat on 12 volts heat it enough to use? I
keep seeing 28 volt pitot tubes on e-bay and was wondering if they would do the
job.
Old April 8th 04, 05:06 AM
Paul Lee
I made my own heated pitot with aluminum tubing and a 12V Cessna pitot
heater element. You can see the details at http://www.abri.com/sq2000/18.html
(about 5 frames from the bottom). The total cost was about $40 - and it's
"new".
Paul Lee, SQ2000 canard www.abri.com/sq2000
job.
Old April 17th 04, 12:13 PM
B2431
Date: 4/7/2004 11:06 PM Central Daylight Time
Message-id:
"new".
I
job.
I like it. Mind if I swipe the idea?
Old April 17th 04, 03:25 PM
dave
Hi all,
Can the standard heated pitot tube element be changed?
I have looked at mine and can't figure how to get it apart.
I believe its the standard 5812-12v type.
Thanks
Dave
Message-id:
"new".
I
job.
Heat treating wing ribs Holger Stephan Home Built 13 February 3rd 04 11:59 PM
Pitot and static couplings for a TTU-205 B2431 Home Built 0 August 15th 03 07:25 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
