I use [the E6B] all the time for flight planning, just like I always did.
What part of the flight planning do you use it for? Are you in training or have you already gotten your PPL? I have my PPL (SEL), instrument rating, and 800 hours. I like to fly low, so more detailled flight planning is necessary than if I just pointed my nose into the sky and survey the world from 6500 feet. I use VFR checkpoints every 10-30 minutes, depending on landmarks, and use it for calculating time for each leg, wind correction angle, estimated ground speed (which impacts fuel stops; I also use airnav and the telephone for gas prices and availability - fifteen miles can mean a hundred dollars difference in fuel costs), and just about everything except weight and balance (for which I use CoPilot on my Palm) Once in the air, I'll keep track of my times to next checkpoint in the flight log, but I use mental estimates (and the GPS if I feel lazy) to do any calculations I need. But most of the time I'm looking out the window. IFR I do the same thing, except that most of the time I'm copying down amended clearances, negating most of the preflight planning. ![]() Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
Does anyone actually use an E6B anymore? If so, what for?
Maybe it is just me...I like taildraggers, I like radial engines, and I like my E6B. I use it all the time for flight planning and keep it handy in the cockpit. Carl. |
On Mon, 29 Nov 2004 12:34:13 -0800, "Slip'er"
wrote: Does anyone actually use an E6B anymore? If so, what for? Maybe it is just me...I like taildraggers, I like radial engines, and I like my E6B. I use it all the time for flight planning and keep it handy in the cockpit. Carl. Nope, not just you, but we are getting more scarce. z |
Two reasons: I can work it with one hand and the batteries never die!
Additional reason: I have an aluminium model so it's also very impervious to heat, unlike an electronic E6B. Dave Reinhart Corky Scott wrote: On Sun, 28 Nov 2004 13:47:07 -0600, "Bill Denton" wrote: I am currently using a Jepp CR-3, but I'm working on my Christmas list and I'm wondering if I should add an E6B. Does one have any advantages over the other as far as real life, training, exams, go? As a separate issue, I am also looking at the Jepp TechStar, the CX-2 Pathfinder, and Sporty's electronic flight computers. Any recommendations? Does anyone actually use an E6B anymore? If so, what for? Corky (just wondering) Scott |
On Mon, 29 Nov 2004 09:37:56 -0500, Corky Scott
wrote: Does anyone actually use an E6B anymore? If so, what for? Yep. Have had the same one for about 20 years. I use it for all my flight planning, and sometimes when I can't find my calculator to do math. z |
taking tests?
BT "Corky Scott" wrote in message ... On Sun, 28 Nov 2004 13:47:07 -0600, "Bill Denton" wrote: I am currently using a Jepp CR-3, but I'm working on my Christmas list and I'm wondering if I should add an E6B. Does one have any advantages over the other as far as real life, training, exams, go? As a separate issue, I am also looking at the Jepp TechStar, the CX-2 Pathfinder, and Sporty's electronic flight computers. Any recommendations? Does anyone actually use an E6B anymore? If so, what for? Corky (just wondering) Scott |
Bill Denton wrote:
I am currently using a Jepp CR-3, but I'm working on my Christmas list and I'm wondering if I should add an E6B. For high speeds the CR computers have an advantage. They correct for compressibility, and temperature rise at the OAT probe too. On the other hand, I think wind problems are easier on an E-6B because you read GS and WCA directly off the instrument after plotting the wind dot and setting course. The CR solves for wind in a completely different way, which saves a lot of space but makes more demands on the user. Since you're interested enough to ask, why not go ahead and get an E-6B? It's not like they're a high cost item. Or you could buy a military whiz wheel on eBay. I see them there frequently. -- Paul Hirose To reply by email delete INVALID from address. |
Thanks to all for your advice. I may just go ahead and pick up an E6B, just
to play with, if nothing else! "Bill Denton" wrote in message ... I am currently using a Jepp CR-3, but I'm working on my Christmas list and I'm wondering if I should add an E6B. Does one have any advantages over the other as far as real life, training, exams, go? As a separate issue, I am also looking at the Jepp TechStar, the CX-2 Pathfinder, and Sporty's electronic flight computers. Any recommendations? TIA |
On Tue, 30 Nov 2004, Bill Denton wrote:
Thanks to all for your advice. I may just go ahead and pick up an E6B, just to play with, if nothing else! If you're just wanting a 'test' E6B, see if you can get one of the 'student model' cardboard & plastic ones; they're about a third the price of a 'real' aluminum/plastic E6B, have identical functions, and are surprisingly tough. 200hrs+ into flying, I'm still using my slightly battered, coffee-marked 'student' cardboard E6B, because I haven't gotten around to buying myself a 'real' one... after I do buy an aluminum E6B, I'll keep the cardboard one on my desk for flightplanning and fiddling... Brian PP-ASEL/Night |
![]() "Brian Burger" wrote in message ia.tc.ca... On Tue, 30 Nov 2004, Bill Denton wrote: Thanks to all for your advice. I may just go ahead and pick up an E6B, just to play with, if nothing else! If you're just wanting a 'test' E6B, see if you can get one of the 'student model' cardboard & plastic ones; they're about a third the price of a 'real' aluminum/plastic E6B, have identical functions, and are surprisingly tough. 200hrs+ into flying, I'm still using my slightly battered, coffee-marked 'student' cardboard E6B, because I haven't gotten around to buying myself a 'real' one... after I do buy an aluminum E6B, I'll keep the cardboard one on my desk for flightplanning and fiddling... Brian PP-ASEL/Night I never used an E6B until recently and now think that it is pretty cool. I bought a large aluminium one and would like to find an old (WWII) one. Whoever came up with it was pretty clever! Mike MU-2 |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
new theory of flight released Sept 2004 | Mark Oliver | Aerobatics | 1 | October 5th 04 10:20 PM |
Flight instructors as Charter Pilots | C J Campbell | Piloting | 6 | January 24th 04 07:51 AM |
Non-TW CFI cannot give Flight Review in TW | Hilton | Piloting | 12 | January 19th 04 10:31 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
