#11
john smith wrote:
Sooooo... is there going to be a "Spot Landing" contest as part of this year's Alexis Park Inn Aerial Open Pre-Airventure Party? Fantastic idea John. I can hardly imagine the prizes this group would come up with for best/worst spot landing performance. Jay - Let's see...7.5 months...a prospective partner and I have a rough 3-6 month time frame we're looking to buy (fully realizing it can take waaaaaaaay longer than that)...yep, it just might work. I could be flying to OSH in *my* airplane this year. -- Jack Allison PP-ASEL, IA Student, airplane partnership student "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
3-6 month time frame we're looking to buy (fully realizing it can take waaaaaaaay longer than that)...yep, it just might work. I could be flying to OSH in *my* airplane this year. Awesome! You still looking at Cardinals? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Stefan"
Also, commercial glider pilots must be able to drop the plane between two lines 100' appart. Which is not that impressing when you consider that with those huge airbrakes, you can adjust your glidepath to anything between 50:1 to 5:1. Airbrakes are far superior to flaps for glidepath control but I'm sure you are exaggerating to make the point. Few gliders can achieve 50:1 and I'm not sure about 5:1 either. But they are effective even if not huge. But not always. I had the pleasure to do my initial training in a Schwiezer 2-22 where the difference in glide ratio with zero spoilers and full spoilers was barely distinguishable (slight exaggeration). Side slips with full spoilers were standard procedure. A nice training experience. My first owned sailplane was the Finnish PIK20-b. A 70's vintage glass ship with no spoilers. It had flaps that were infinitely adjustable between -8 and +90 degrees. Flaps can out perform spoilers in the sense that steep descents can be achieved at slower speed. Problems include the need for tight airspeed control to avoid balloning and float along with the fact that flaps are effectively 'one way' devices, especially on gliders. Once you roll in landing flaps and slow down, you really can't increase your glide ratio by rolling them off. If you do retract the flaps to increase your glide ratio, you generally have to increase your speed and/or let your descent rate go up to regain some energy before the desired effect can be achieved. With an engine, you can counteract that but in a glider all you have is height and speed. The PIK could be set down on a dime once the technique was learned. The trick was to fly final with 90degs of flap and flare a foot or so off the ground. Unless you entered the flare with a ridiculously low airspeed, ground effect was sure to float you past any planned landing point. But when you the desired point was reached, you simply dumped the flaps and flared for a 2 pointer. However, the flaps were actuated with a crank that required 2-3 full turns to dump. Imagine rubbing your tummy and patting your head at the same time. It took a full season before I could detach the cranking with my left hand from the smooth pulling with my right. Imagine a bouncing ball..... But once mastered, you could land with a yard of any intended point. |
ps.com... As a segue from off airport landings....how about precision? Can you consistently touch down at minimum speed with your regular aircraft within a 50' mark? Can you do it with a short/soft/XW/ Obstacle? Can you do it with any configuration of flaps and or power? Yes, but I practice it. And while I used to take it for granted, I no longer do. I've done a lot of off field work in gliders where landing precision is a given. The Maule is known to be good short field machine but it's not as easy to spot land or short field land as I would have thought. But when I took my commercial training, I had convinced my instructors that the power off landings to a spot landing would not be an issue due to my experience. I failed my check ride for missing the spot. On the following day, I failed it a second time for missing the same spot! Flying the Mooney power-off to spot was different than doing it in a glider or a Maule. So I no longer believe that I could perform accurate spot landings in something other than my regular plane without practice. |
Maule Driver wrote:
Airbrakes are far superior to flaps for glidepath control but I'm sure you are exaggerating to make the point. Few gliders can achieve 50:1 and I'm not sure about 5:1 either. Ok, I admit. So I'll reduce it to between 48:1 and 7:1. (48:1 being the best glide for an LS8 with 18m, and JAR-22 requires a glide ratio of less than 7:1 with airbrakes deployed.) Maybe I should even reduce the upper limit to 45:1 for the bugs. :-) I had the pleasure to do my initial training in a Schwiezer 2-22 where the difference in glide ratio with zero spoilers and full spoilers was barely distinguishable (slight exaggeration). The airbrakes of the Rhönlerche (aka Rhönstone) were called "noise makers" because the only difference they made was the noise level. :-) Slips were *very* effetive, however. The PIK could be set down on a dime once the technique was learned. Every airplane can be set down on a dime once the technique has been learned (and is regularly practised!). Of course it may be more difficult for some planes than for others. But when you the desired point was reached, you simply dumped the flaps and flared for a 2 pointer. Just smashing down the glider doesn't count. At least it doesn't at the spot landing contests of our club. On the other hand, when outlanding, the only thing which counts is the result and nobody will care about style, of course. Stefan |
Jay Honeck wrote:
Awesome! You still looking at Cardinals? Yep...at the moment, a Cardinal RG is at the top of the list and is the main focus of our research efforts. Still lots of work to do and many variables to consider along the way. -- Jack Allison PP-ASEL, IA Student, airplane partnership student "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
![]() "john smith" wrote Sooooo... is there going to be a "Spot Landing" contest as part of this year's Alexis Park Inn Aerial Open Pre-Airventure Party? ONLY if it can be judged from pool side. Jay DOES have his priorities set, right Jay? g -- Jim in NC |
If it has 5x5.00 tires, make yourself a set of 12"x12"x1" plywood
platforms to park the wheels on any soft surface. The smaller tires readily sink into soft turf, making it difficult to extract the aircraft to depart. Saves the engine/landing gear and your body from excessive abuse. Jack Allison wrote: Yep...at the moment, a Cardinal RG is at the top of the list and is the main focus of our research efforts. Still lots of work to do and many variables to consider along the way. |
![]() "Stefan" The PIK could be set down on a dime once the technique was learned. Every airplane can be set down on a dime once the technique has been learned (and is regularly practised!). Of course it may be more difficult for some planes than for others. I'd have to agree but perhaps not all. A long wing ship I've heard about that really doesn't spot land is the U2 (it was just hangar talk - can anyone comment?) when you the desired point was reached, you simply dumped the flaps and flared for a 2 pointer. Just smashing down the glider doesn't count. At least it doesn't at the spot landing contests of our club. On the other hand, when outlanding, the only thing which counts is the result and nobody will care about style, of course. This wasn't a smash down. Rather it resulted in a particularly smooth, precise, and satisfying landing (once one learned to eliminate the PIOsfrom cranking with one hand while controlling pitch with the other). Problem was that the technique was not documented as far as I know. Just the technique taught by one experienced PIK owner to another. Otherwise I would submit that gliders that depend on flaps only for glide path control *cannot* be consistently and safely landed 'on a dime' in the normal range of conditions without the kind of non-standard technique described above. The PIK couldn't and the Schweizer 1-35 couldn't in my experience. And I think that fact that no one builds production gliders with this configuration is a reflection of this. But my experience is limited here. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
Strong crosswind landings! | Toks Desalu | Piloting | 12 | April 19th 04 07:43 PM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
