#11
Paul Smedshammer wrote: This is a bit long winded but I'm looking for qualified opinions as to what might have happed to an almost total loss of power while in cruise flight in my Mooney M20F. Here is the story of what happened: I also own an M20F. Did you have teh ram air on? There are cases of ice build up when the ram air is on. The owner's manual cautions us to turn it off in ice conditions. Have you checked your fuel vents? There have been reports of Mooneys lossing power after fuel vent blocks. However, changing tanks should fix that. The Mooney does have an automatic alternate air system. At annual, the automatic switching door should be inspected and the spring pressure should be measured. -Robert, M20F |
In article , "clyde woempner" wrote:
VFR on top, not good if you and the plane are not capable of IFR flight. Did the forcast call for any broken or scattered conditions along your route of flight, if so where?? Water in the fuel system can lead to freezing in the fuel line as you gain altitude. The weather report would give you the freezing level. This can of course block and/or restict the fuel flow. But, second guessing the problem is not too smart, I strongly suggest you have a shop check it out, maybe a fuel pump was sucking air from a loose fitting, etc. Have it checked out, and watch out for Mt. Diablo. Just remember, always have options: Clyde I agree that VFR on top is not the best idea if you and plane are not capable of IFR flight. But in this case the Mooney M20F is fully capable of IFR flight and I'm working on my IFR ticket. Not that my working on it makes any difference in this case. However, I thought I understood the risk here and felt that while it was risky to try and make it over this 30 mile socked in overcast with totally clear skies above, it was worth the risk as I needed to get home (I know - Get There Itis) and this engine was just over 50 hours SMOH along with overhauled mags, generator, fuel servo, and prop governor at the same time. The engine was performing perfectly. Famous last words? I don't think an IFR ticket would have helped a whole lot in this case. It would have provided for 1 attempt at an IFR approach with only 45% power maximum available and 600 foot overcast with 3 miles max visibility in mist below me. For those interested, here is photo of what it looked like about 10 seconds before the event. http://www.coreutilities.com/mooney/RoughEngine.JPG Trust me, I learned my lesson and I will not be going VFR on top like this again without options like enough altitude to glide to a visible landing site and the IFR ticket in hand. Even then I'm going to think twice about attempting it. A second engine would have been great to have! Paul |
In article .com, "Robert M. Gary" wrote:
Paul Smedshammer wrote: This is a bit long winded but I'm looking for qualified opinions as to what might have happed to an almost total loss of power while in cruise flight in my Mooney M20F. Here is the story of what happened: I also own an M20F. Did you have teh ram air on? There are cases of ice build up when the ram air is on. The owner's manual cautions us to turn it off in ice conditions. Have you checked your fuel vents? There have been reports of Mooneys lossing power after fuel vent blocks. However, changing tanks should fix that. The Mooney does have an automatic alternate air system. At annual, the automatic switching door should be inspected and the spring pressure should be measured. -Robert, M20F When this happened I had the power boost off. As one of the trouble shooting items I opened it and got a slight increase in power like from 30% to 35%. Hard to judge but it was running extremely rough and opening the power boost cleaned it up just a little bit. I left it open as it did make things just a little better. But it was the enriching of the mixture that really made the difference. Still less than 50% power but it at least ran smoother. By the way, I LOVE this plane. It is old but it fly's great and I feel the most comfortable I have ever felt in about 7 different planes types (152, 172, 172RG, 182, Debonair, Warrior, and Arrow). The Mooney just has the performance I have always been wanting. It is a great plane... as long as the engine keeps running! Paul, 1967 M20F |
seconds before the event. http://www.coreutilities.com/mooney/RoughEngine.JPG Trust me, I learned my lesson and I will not be going VFR on top like this again without options like enough altitude to glide to a visible landing site and the IFR ticket in hand. Even then I'm going to think twice about attempting it. A second engine would have been great to have! Paul Wow. That photo made my blood run cold. It's beautiful, but knowing that there's a chance that you have to descend into it is chilling. I am glad that things turned out OK for you. Thanks for posting. -Trent PP-ASEL |
Paul Smedshammer wrote: In article .com, "Robert M. Gary" wrote: When this happened I had the power boost off. As one of the trouble shooting items I opened it and got a slight increase in power like from 30% to 35%. Do you know if your shop has done the AD that requires checking the drain holes in the ribs? Since Mooney stores it's fuel in the wing (rather than in a real fuel tank), the fuel needs to run through the ribs. At the bottom of the ribs there are very small holes. When the tank gets patched its easy to put your B-2 over these holes and create a small pocket where fuel (and water) can stay trapped for some time. Some of these holes should be covered (since they are mating points that can allow fuel leaks) and others are there on purpose (to allow water and fuel to run through). I wonder if you might have disloged some water in your flight. Turning on the pump would increase the amount of fluid running through the system and maybe move the water out sooner? Just a guess. -Robert, Mooney CFI and M20F owner (and loving it!!) |
Ron Rosenfeld wrote: I have had problems, over the years, with clogged injector; clogged fuel line; and clogged fuel servo. In all of those instances, the EGT for the affected cylinder(s) went down when engine roughness was noted. Except for the fuel servo when the problem became evident on takeoff and I was concentrating on landing, rather than looking at EGT's. I had a plug go bad and that cylinder's EGT actually went up. I never understood that. -Robert, M20F |
Robert M. Gary wrote :
I had a plug go bad and that cylinder's EGT actually went up. I never understood that. If one plug in a two plugged cylinder quits working, then there is only one flame front. Instead of the fuel/air charge burning from two ignition sources, it burns from one. This results in the charge taking longer to completely burn. Since the charge took longer to burn, the gasses are still hotter when the exhaust valve opens and the gasses pass by the EGT probe. This will happen anytime you go from 2-plug to single plug operation. When in cruise, switch to one mag or the other. You should see a rise on all EGTs. John Galban=====N4BQ (PA28-180) |
"Robert M. Gary" wrote: I had a plug go bad and that cylinder's EGT actually went up. I never understood that. That's easy: failure of one plug prolongs the burning of the mixture, so some is still burning as it is ejected out the exhaust past the temp. probe. -- Dan C172RG at BFM |
"Robert M. Gary" wrote I had a plug go bad and that cylinder's EGT actually went up. I never understood that. -Robert, M20F Incomplete/slower combustion, gases still burning in the exhaust header- on the way past the EGT sensor. -- Jim in NC |
Paul:
You didn't say what the OAT was. I'd gather that it was above 0C. I fly a PA28-180C (PP-SEL/Instrument). This past summer in severe clear, 2 SMOH, I had a rough running engine and made a 180 and landed right back at the airport I departed from (from about 10 min out). We looked at everything and the only thing we could come up with was I had gotten a load of ice (for those of you who have not flown this model, the updraft carb attaches to the intake manifold which runs through the middle of the oil pan -- difficult to get ice, but I managed). In your case I am thinking that you need to pull and inspect your fuel filters and/or screens. You may find them contaminated with water (or perhaps some other foreign substance). But then, just like in my case, static run ups, sumping fuel, etc. shows nothing. And the plane runs just fine like it was all a figment of your imagination. As another person noted (being much more familiar with your model than I am - I can only drool at the M20 parked over at the maint hanger), you may have pockets in your tanks that allow for trapped water and by luck of the draw... BTW - This PA28-180C is the first I've owned. Used to fly rental Cessnas which seemed to always have water. This one has to fly through a serious rain storm to get any water. Seems it sucks it in through the tank vents! Later, Steve.T |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 08:13 PM |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 10:36 PM |
| Sim time loggable? | [email protected] | Instrument Flight Rules | 12 | December 6th 03 08:47 AM |
