I agree it possibly had something to do with local chilling taking
water out of the local air. But air at that temp already has very little water vapor in it. That seems hard to believe, and I've never seen what you described. Huh! Gasoline will dissolve a small amount of water into solution. The amount that will dissolve goes down with temperature, creating a fine ice crystal "snow" in your fuel tanks under severe cold conditions. When flying, this snow will accumulate on any filter screens (such as in the gascolator) and can eventually block your fuel flow requiring only a very tiny amount of water. I know - it happened to me (see Sport Aviation Dec 1986) Remember that your fuel that morning was probably colder than it had ever been since it was made at a refinery in some warmer climate. For that reason I add a small amount of isopropyl alcohol to my fuel whenever the local temps go below freezing. Beware of fuel that has been severely chilled before it was last filtered. |
ever been since it was made at a refinery in some warmer climate. For that reason I add a small amount of isopropyl alcohol to my fuel whenever the local temps go below freezing. Really? I guess this throws out my concerns about finding alcohol in my mogas! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jay Honeck wrote: Remember that your fuel that morning was probably colder than it had ever been since it was made at a refinery in some warmer climate. For that reason I add a small amount of isopropyl alcohol to my fuel whenever the local temps go below freezing. Really? I guess this throws out my concerns about finding alcohol in my mogas! Jay, if you have any sense, you're looking for (and trying to avoid) *ethanol* in your gas, not isoproply. George Patterson The desire for safety stands against every great and noble enterprise. |
*ethanol* in your gas, not isoproply. Aren't they *both* unapproved for use in aircraft engines? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
By "small amount" of isopropyl alcohol (in a yellow container if you
use the illegal automotive stuff) I mean only a couple tablespoons to a tank full. Not a 10 percent slug of ethanol like the gasohol crud. |
On Sun, 19 Dec 2004 01:28:16 GMT, "Jay Honeck"
wrote: Remember that your fuel that morning was probably colder than it had ever been since it was made at a refinery in some warmer climate. For that reason I add a small amount of isopropyl alcohol to my fuel whenever the local temps go below freezing. Really? I guess this throws out my concerns about finding alcohol in my mogas! Different type of alcohol. The stuff in gasoline is usually ethanol. Isopropyl alcohol (IPA) is better at pulling water into solution in a gas tank. |
Winter in Michigan | Roger | Owning | 8 | January 28th 05 06:24 PM |
Snow... | Dan Luke | Instrument Flight Rules | 5 | December 28th 04 07:26 PM |
flying in snow | Teacherjh | Piloting | 17 | March 22nd 04 05:05 PM |
$3.00 a gallon gasoline by summer(read all of this, it just might work) | Fastglasair | Home Built | 8 | March 10th 04 12:12 AM |
Weight of snow on wings | Michael Horowitz | Home Built | 10 | January 4th 04 10:58 PM |
