FAA ambiguity
Old January 6th 05, 01:00 AM
G.R. Patterson III wrote:
Obviously, the FAA feels that it's safe enough to *suggest* that we
come in at
1,000' AGL, *suggest* that we enter the pattern on the downwind leg
at a 45
degree angle or come straight in, *suggest* that we report our
position by
distance and direction (as opposed to something like "on the VOR
approach"), and
doesn't feel that safety would be significantly improved by
*requiring* us to do
anything beyond get the plane down in one piece.
I don't have a problem with that, myself. They've made the
recommendations and a
sensible pilot will not deviate much from them.
I would definitely deviate from the first one you mentioned. The
latest AC "recommends" that pilots fly patterns at 1,000' AGL. That's
not a very good suggestion at an airport that has a published pattern
altitude of 800' AGL (of which there are many examples throughout the
country). Instead, I fly the published altitude. If there is none,
THEN I'll fly the recommended 1,000' AGL.
Other regs require me to acquaint myself with all of the information
pertinent to a flight before I go. Why would I ignore an 800' AGL
pattern altitude listed for an airport, in favor of following the
recommendation in AC?
Old January 6th 05, 01:05 PM
Neil Gould
Recently, Bob Gardner posted:
AIM 3-2-1 says that it is the responsibility of the pilot to insure
that ATC clearance or radio communication requirements are met prior
to entry into Class B, C, or D airspace; the Air Traffic Control
Handbook tells controllers that it is their responsibility to
coordinate the passage through that airspace of flights to which they
are providing services. Which is right??
Perhaps it's a matter of how one reads these things? For example, I
interpret your above statement as follows:
* The ATC handbook states that controllers must coordinate the passage
through their airspace.
* AIM 3-2-1 says that pilots must adhere to the instructions of ATC prior
to entry into Class B, C, D airspace.
In other words, pilots must follow the instructions they are given by ATC
before entering controlled airspace. Ergo, all pattern entry in controlled
airspace is determined by ATC. Where's the conflict?
Neil
Old January 6th 05, 04:12 PM
Michael
What bothers me, and what I find to be absolutely incredible, is the
lack of clear direction that is provided by the numerous documents
that are produced by the FAA.
If you think it's bad on the operations side, try the maintenance side
sometime. Much worse.
Once I used to look for wisdom in FAA regulations and advisory
circulars. Once I tried to reconcile them so there was no
contradiction. It's a task that I believe is beyond the capabilities
of even a talmudic scholar. I've given up.
Occam's Razor - the simple explanation is usually the correct one. The
simple explanation is that the FAA is staffed with a bunch of useless
bloody loonies. It's not as far-fetched as you think.
The real business of the FAA is the regulation of the airlines. That's
what the general public thinks of when it thinks aviation. That's
where the visibility is. That's where the promotion opportunities are.
That's also where this level of ambiguity is simply not tolerated -
and neither is regulation that is impossible to comply with. Airlines
and their unions have legal staffs and the ears of congressmen. That
doesn't mean they have it all their own way, but it does mean that
there is some level of accountability.
Then there is the part of the FAA that deals with GA. The FSDO's,
primarily. You will NEVER see an airline employee at the FSDO in his
professional capacity. The airlines have their own offices. There is
no visibility in GA, and no real opportunity to move up. So when you
deal with the GA portion of the FAA, realize that you are dealing with
the losers of the FAA, with the occasional little airplane enthusiast
thrown in.
Ever want to install a CD player or other entertainment system into
your little airplane? Good luck. Some people will tell you that it
can't be done unless you buy the $1000+ certified version. In some
FSDO's, they are even correct. In others you can get by with it - but
it's not really legit. Think the airlines would tolerate that state of
affairs? Of course not. So the FAA issued AC 25-10. It spells out
how you can install a CD player, video game, or other miscellaneous
non-required electrical equipment for entertainment purposes. It's
really quite simple to follow and very reasonable. Problem - it
applies ONLY to transport category airplanes. Not your little
bugsmasher. You're still hosed.
NOW do you get it?
Michael
Old January 6th 05, 05:46 PM
Bob Gardner
I can't count the number of times I have been flying with a student on
flight following, and upon approaching Class D airspace hear the question
"Should I switch over to the tower?" I think the existing situation is
confusing to many pilots. Added to this, and extending the thread a tad, is
the situation where the tower has ceded the top 500 feet of its D airspace
to the overlying approach control, so the student learns, to his surprise,
that he need not call the tower at all but can stay with approach. This is
not a big deal except that it leads to a lot of unnecessary transmissions:
"Approach, BuzzBird 35X, should I switch over to the tower now?" "Negative,
stay with me."
Bob Gardner
"G.R. Patterson III" wrote in message
Bob Gardner wrote:
AIM 3-2-1 says that it is the responsibility of the pilot to insure that
ATC
clearance or radio communication requirements are met prior to entry into
Class B, C, or D airspace; the Air Traffic Control Handbook tells
controllers that it is their responsibility to coordinate the passage
through that airspace of flights to which they are providing services.
Which
is right??
I don't see any conflict. The AIM tells me that it's my responsibility to
handle
things before I enter the controller's airspace and the ATCH says it's the
controllers' responsibility after I get in there. Two different scenarios
and
locations in the air.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old January 6th 05, 08:10 PM
Richard Russell
On 6 Jan 2005 08:12:09 -0800, "Michael"
snipped good stuff....
NOW do you get it?
Michael
I do get it, Michael. In fact, I got it from the beginning. That
doesn't diminish my astonishment that the situation can actually be as
convoluted as it seems to be. Where else would this be tolerated?
Rich Russell
Old January 6th 05, 09:07 PM
Michael
Sorry. I got overexcited.
That
Nowhere, I suspect. You should realize that it's mostly not tolerated
in aviation either.
I gave you the example of the CD player for a reason. A friend of mine
has an AM/FM/Tape Player installed in his Bonanza. There is no
paperwork for it. Never has been. It has been there for maney years.
It is clearly not legal, and yet every IA seems to sign off the annual
every year.
That's little ****. A friend of mine bought a Cherokee Six in Alaska.
The pilot's seat was a lawn chair. The doors had to be duct taped
closed. She flew it to Houston. I've seen a tractor carburetor come
off a certified airplane - and I'm talking about a model that had NEVER
been approved for aviation. It made it through dozens of annuals and a
major overhaul, and was only removed when the bowl cracked.
My girlfriend bought a Straduster a few years ago. The owner had been
flying for many years, but eventually did get around to getting a
private license. With a private license and an experimental
(amateur-built) airplane, he would take people up for aerobatic rides
(without parachutes) and charge for it. I know people who file and fly
IFR who never got the instrument rating, and I know at least one who
used to do it - until he finally got rated. He went on to be a fleet
captain for a major airline and a DE in transport category jets.
This is the reality of general aviation. You won't see it at the front
desk of the FBO, with a flight school staffed by airline wannabes, but
dig a little deeper and it's all around you.
This is how people react to regulations that are unworkable. It's no
different from what you see on the highway. Almost nobody consistently
drives the speed limit. Few people come to a full stop at every stop
sign. Every gas station I've ever seen in Texas sells cold beer, and
the open container law has had no impact. Rules that are unworkable or
unacceptable are largely ignored.
GA rules are some of the most unacceptable and unworkable of all, and
they're also some of the most widely ignored. Only on these newsgroups
and in the commercial flight schools are pilots concerned about what's
legal. In the real world, they're only concerned with what they can
get away with. The intolerable is not tolerated.
There is something about these newsgroups that seems to attract a
subset of people who believe we SHOULD tolerate this. People who
believe that even though the regulations are clearly convoluted,
self-contradictory, and unworkable we should still comply. People who
even believe that it's reasonable to rat out someone to the FAA for
non-compliance. They're a vocal minority - nothing more.
Can you imagine what would happen if the majority of pilots openly
refused to comply? That's what happened in the ultralight world. The
rules set weight and operational limits that were ridiculous, and
people simply did not comply. 90% of the single seaters were
overweight, and 90% of the "instruction-only" two seaters were being
flown for personal use. So what happened? Were there prosecutions on
a mass scale? No. Everyone knew that people wouldn't stand for that.
So in the end, the FAA came up with something more reasonable (sport
pilot) in hopes that people would comply. Whether they do - or
continue to fly as they have been - remains to be seen.
Michael
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
RV-7a baggage area David Smith Home Built 32 December 15th 03 04:08 AM
