Type-like Instrument Ratings
Old January 16th 05, 04:42 AM
Doug
The cost will go down. It costs no more to make a glass panel than the
gyros they replace, maybe less.
For an idea of what it can cost, you can get an experimental AI
replacement that has an AI, TC, VSI and probably some other stuff I've
forgotten for under $2000. All electronic, with no mechanical gyros.
And they work!
I really don't think it's all that big an issue. Just train and become
competent with what you have, and fly it.
IFR IMC flight is mostly about what to do if something becomes
non-functional anyway. So have lots of backups and know how to cross
check to determine just what is going on.
Old January 16th 05, 02:51 PM
I expect the panels will become more standardized or the insurance
companies will step in and make something like that mandatory.
That certainly hasn't been the case with air carrier and biz jet aircraft.
For instance, the Falcon 900 (the biz jet with three engines) requires a
new, separate type rating for the new 900EX.
Old January 16th 05, 09:28 PM
Colin W Kingsbury
"Doug" wrote in message
True, but the point is that you can only get a glass panel in a new plane,
and a new plane is (and will continue to be) far more expensive than an
"equivalent" new one. Most places are getting crunched badly enough on fuel
as it is.
And they work!
Well if you cut the single biggest line-item expense out of anything you can
cut the cost substantially. Certification will never get cheaper, nor will
the delta in price between new and used airplanes. It's also unlikely that
installing glass panels in used planes will prove economical in anything but
big-ticket high-performance planes like Bonanzas. So the rest of us will
have to wait a decade or so until they start becoming common on the used
market, which they inevitably will.
I'd disagree- moving from my 172, with two NAV/COMs, ADF, and Loran, to a
G-1000-equipped 172, represents a dramatic step up in complexity. If someone
is already used to flying with a GNS-430 then the transition will probably
be straightforward, but for many of us there's a lot of new functionality to
learn about, especially if you want to truly use the full integrated
capabilities of the system, which is the point.
However, I agree that in the long run, it will represent an improvement in
safety and utility. There's no longer any question about where the future
is.
-cwk.
Old January 16th 05, 09:41 PM
Roy Smith
as it is.
The interesting transition is going to happen in a few (5-10?) years
when glass cockpits have been around long enough for all the flight
schools to have them. Then we're going to be putting out a new
generation of freshly-licensed pilots who grew up on glass and won't
accept less. Kind of like what's happening with GPS today.
Old January 18th 05, 05:33 PM
Gene Whitt
Yes!!!!!!
Gene Whitt
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Type-like Instrument Ratings jsmith Instrument Flight Rules 13 January 18th 05 05:33 PM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
