Are you gliding when you touch down?
Old January 21st 05, 06:05 AM
mindenpilot
Oops.
I meant cutting the power, not cutting the pattern
I thought that was a standard pattern. Now, in my Beech, I do a similar
pattern, usually cutting the pattern either close to the threshold, or in
the flare. Any disadvantages to this approach?
Adam
N7966L
Beech Super III
Old January 21st 05, 06:27 AM
Jay Beckman
"mindenpilot" wrote in message
"John Doe" wrote in message
I guess my question is simply put this way, do you cut power
immediately before touching down? If not, when?
I suppose a carrier landing would be an extreme.
Only curious. Thank you.
For standard landings, am I the only one who learned (in a C-172) 2100RPM
10 degree flaps on downwind, 1700/20 on base, 1700/30 or 40 on final, cut
the power over the threshold (maybe a little later) ?
Adam
N7966L
Beech Super III
I was taught (C172SP)
- Abeam the numbers: 1500 rpm + flaps 10
- Base: 1500 + flaps 20
- Final: Flaps 30, pitch for 65-70kts, adjust power as needed for constant
GS
- Power off as I cross the runway end lights (add a very small amount of
power in the flare for a nice soft touchdown...but not if I'm a little hot
so as to avoid more float.)
Old January 21st 05, 07:21 AM
for constant GS
amount of power in the flare for a nice soft touchdown...but not
if I'm a little hot so as to avoid more float.)
I was taught (C152, little or no wind):
- 2100 rpm on downwind
- 1700 rpm abeam the numbers/10° flaps at white arc
- 1300-1500 rpm on base/20° flaps; pitch & trim for 60ish
- Final: adjust power only for GS; last 10° of flaps only as needed
- cut power when I know I have the runway made (not always in the same
specific place, and later with full flaps)
Old January 21st 05, 07:27 AM
mindenpilot
2100RPM
cut
for constant GS
It sounds like we all have a similar way of landing.
I feel better.
I posted because everyone else was talking about cutting power on downwind.
How common is this?
Doesn't seem too many people were taught this way.
Adam
Old January 21st 05, 07:46 AM
cutting power on downwind. How common is this?
Isn't *everyone* taught HOW to make a power-off approach (cutting power
abeam the numbers) before soloing, just in case? I work at a flight
school and have never known anyone to teach routinely making *all*
approaches power-off, though.
Old January 21st 05, 08:29 AM
mindenpilot
I was taught simulated engine failure approaches, and practice them
periodically in my plane.
The OP asked if you cut power immediately before touchdown.
A surprising number of posters responded saying they cut the power on
downwind.
I was assuming this is their normal pattern procedure.
Did I misread, or are people flying patterns much differently than I am?
That is why I asked, How common is this?
Adam
Old January 21st 05, 11:31 AM
Slick
This is the only way I was taught to land.
"Brian" wrote in message
I cut the power anywhere from immediatly after taking off (Aborted
Takeoff) to just after taxing off the runway(Soft Field Landing)
In my Glider I cut the power typically at about 2000' AGL(Release from
the Towplane). It usually takes me about 3 hours to get around to
actually landing.
I power aircraft I normally cut the power on downwind abeam my touch
down point and they try to adjust my configuration (Flaps), glide path
and airspeed
to land at a specified spot on the Runway without having to add power
again.
But I use a different techniques for Short and Soft Field landings.
Brian
CFIIG/ASEL
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Old January 21st 05, 11:33 AM
Cub Driver
On Thu, 20 Jan 2005 16:46:00 GMT, "ShawnD2112"
Standard
landing, wind no factor, I cut power on downwind and glide all the way in.
Me too. Carb heat goes on as soon as I enter the downwind, and the
power comes off when I am abreast my landing spot. I advance the
throttle at least once on each leg for a couple seconds. If I need
power on final, I add it and give myself a D for that landing.
If I glide right in, I give myself a C. If I have to slip, it's a B.
An A is awarded only for a perfect wheelie.
In any event, it's a glide from abreast the landing spot. Never tried
it on a carrier
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
Old January 21st 05, 11:36 AM
Cub Driver
On Thu, 20 Jan 2005 21:03:09 -0800, "mindenpilot"
For standard landings, am I the only one who learned (in a C-172) 2100RPM 10
degree flaps on downwind, 1700/20 on base, 1700/30 or 40 on final, cut the
My first instructor was a marine. He taught me to go to 1500 rpm
abreast the landing spot and fly the pattern thus, chopping power on
final. When he went off to the airlines, his more traditional
successor taught power-off landings.
No flaps in the Cub.
Warbird's Forum:
Old January 21st 05, 11:41 AM
Cub Driver
downwind.
It's my normal procedure. I'm always open to suggestion, however. If
someone is landing straight in, I'll add power and extend my downwind.
If there's someone in the pattern behind him, I'll make a power-on
pattern.
I like being close to the airport. I'm never so unhappy as when flying
the 45. I'd much rather fly straight to the airport and then descend
upon the downwind, but it makes the local folks unhappy. "The pattern
is sacred!" one of them told me. (She's a minister on Sundays.)
Warbird's Forum:
Gliding, Vintage Book 1932 Motorless Flight FA Sarah Mc. Aviation Marketplace 0 November 6th 04 12:40 AM
Gliding Vintage Book 1932 Motorless Flight FA Sarah Mc. General Aviation 0 November 5th 04 02:09 AM
Vietnam War chopper to touch down in Livermore Otis Willie Military Aviation 0 February 19th 04 12:49 AM
Looking to get in touch with a "Thud Driver" Jarrod Cunningham Military Aviation 0 September 6th 03 06:59 AM
I am looking to get in touch with cessna 340 owners endre Owning 0 July 28th 03 03:03 PM
