Kitplanes Columns
Old April 6th 04, 12:56 AM
Jim Weir
Same way I did last time, hopefully with improved results {;-)
First person to post here that they looked at the files, they understand (more
or less) the task at hand, and are willing to take a crack at the first one has
it.
EDR
-So when are you going to let us know who you select to assist you? :-)
http://www.rst-engr.com
Old April 6th 04, 04:51 AM
G.R. Patterson III
it.
Jim. I sent you a zip file. See what you think.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 6th 04, 08:26 PM
G.R. Patterson III
it.
Ok, Jim. I looked at the files and put together the pages for August from the files
you provided. I did have to change the "oopsie" page from a pdf download to an html
file, since I can't create pdfs. I will send you a zip file shortly.
What's next?
George Patterson
Old April 7th 04, 06:52 AM
Regnirps
Missed a post. Where are the files?
-- Charlie Springer
Old April 7th 04, 04:54 PM
EDR
In article , G.R. Patterson III
(more
has
it.
files
an html
George, forward whatever you want converted to PDF to me. I have a full
version of Acrobat.
Old April 6th 04, 03:41 AM
G.R. Patterson III
Jim Weir wrote:
I also posted all the JULY 2002 files in /kptest as well.
I've got them down. Looks like August instead of July. I've looked at the June files
you provided and will take a stab at August tomorrow.
George Patterson
Old April 8th 04, 04:40 PM
Jim Weir
George Patterson took the task on and has done an absolutely splendid job
translating the first article.
To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go
to the bottom article (July '02).
George, the gang owes you one, and so do I.
The August '02 raw data is posted in the usual place.
-Again I ask...is anybody fool enough to take my Kitplanes column raw data and
-put it into downloadable format for the rest of the gang?
Old April 8th 04, 06:32 PM
Dave Butler
Not Found
The requested URL /kitplanes/KP0207/KPtext.pdf was not found on this server.
Apache/1.3.20 Server at www.rst-engr.com Port 80
Dave
Old April 8th 04, 06:42 PM
frank
Works in Texas...
"Dave Butler" wrote in message
and go
Not Found
server.
Dave
Old April 8th 04, 06:59 PM
Russell Kent
Not Found
Dave
There's two mismatches between the KP0207.htm file and the other files: the parts
list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver, but are
KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case
difference in the "P"s). So the real URLs to the full text and parts list a
http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf
http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf
I imagine that the above to references will break here shortly when Jim fixes the
KP0207.htm file or renames the PDFs.
Russell Kent
Kitplanes PTT story JFLEISC Home Built 1 January 14th 04 03:14 AM
Kitplanes CD-ROM directory David Smith Home Built 4 January 1st 04 09:31 PM
KitPlanes - Home Page by Ron Wanttaja RobertR237 Home Built 40 August 12th 03 10:17 PM
Jim Weir's CO detector design in June Kitplanes Michael Home Built 0 August 8th 03 11:54 PM
Jim Weir's CO Detector in Kitplanes June edition. Michael Home Built 0 July 29th 03 01:32 PM
