Icebound wrote:
Saying "Experimentally" didn't alter the gist of the post for pilots... only for research-meteorologists! :-) Agreed. I really am pleased to see this much interest, and frankly knowledge, displayed by pilots for a subject I've spent a good part of my life studying. Jim Rosinski |
On 7 Feb 2005 20:06:38 -0800, "jim rosinski"
wrote: Agreed. I really am pleased to see this much interest, and frankly knowledge, displayed by pilots for a subject I've spent a good part of my life studying. Jim Rosinski Jim, to me this is kind of the point regarding this subject and the FAA's insistance on it being a part of the written examination. How does knowing this information help the average pilot in his task of flying safely from one point to another. Does any pilot (besides yourself) actually think about this while flying? If so when? Under what circumstances? After a while don't pilots kind of get to understand when clouds begin forming due to warming? And when the clouds do form, don't we (VHF guys) normally just avoid them? Thanks, Corky Scott |
I wrote:
remarkably simple expression: g/Cp, where g is gravity (9.8 m/s) This should have read 9.8 m/s^2, not 9.8 m/s, for those who care. Jim Rosinski |
2°/1000' is "average" since air at different levels may be saturated or unsaturated and can change from one to the other at different levels. Lifted air would cool at 3°/1000' while lifting through dry air and at 1°/1000' lifting through moist air levels. So.... the average is 1°
-- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Andrew Sarangan" wrote in message 1... Instability produces cumulus clouds and stability produces stratus clouds. We know that. However, since the saturated and unsaturated lapse rates are significantly different (1C/1000' compared to 3C/1000'), it seems quite possible to get cumulus clouds even when the atmosphere below is stable. For instance, if the environmental lapse rate is 2C/1000', the unsaturated air is stable. Once clouds form (how they form without vertical currents is a different matter), the air inside the clouds will become unstable. Does this seem reasonable? On a related question, where does the concept of 'average' lapse rate (2C/1000') come from? I always took this to mean 50% RH air, but it took me a long time to learn that that was not the case. The air is saturated or it is unsaturated. How can there be an average between saturated and unsaturated? The standard lapse rate and standard temperature at different elevations are all based on this 2C/1000' concept. What's the deal with this? |
![]() "Darrell S" wrote in message news:bdUNd.46622$bu.24635@fed1read06... 2°/1000' is "average" since air at different levels may be saturated or unsaturated and can change from one to the other at different levels. Lifted air would cool at 3°/1000' while lifting through dry air and at 1°/1000' lifting through moist air levels. So.... the average is 1° no, No, NO!!! The 2 degrees per 1000 feet comes from a "determined" average lapse rate of real atmospheres averaged around the globe and averaged throughout time.... determined within reason. It has nothing, NOTHING, to do with saturated or unsaturated or dry adiabatic or saturated adiabatic. Dry and Saturated adiabatic lapse rates are a law-of-physics-rates-of-cooling, not actual temperatures in the real nor in the "standard" atmosphere. Please divorce those two concepts: First concept: Environmental lapse rate: temperature structure of the real atmosphere right now. Usually, but not necessarily, cools with height. How much per 1000 feet? Depends on the structure TODAY, THIS INSTANT. Not constant throughout. May be several degrees per 1000 feet in some layers, zero in others, and even an inversion in still others. .... and Standard Atmosphere Lapse Rate: defined at "lowering 1.98 degrees per 1000 feet" within the troposphere (lowest 11 kilometres). Second concept: Dry Adiabatic lapse rate: a RATE-OF-COOLING (or heating) of a parcel of air should it be displaced from its present level and rise (or descend) through the atmosphere, with the consequent pressure change on it. The "dry-adiabatic" rate of cooling will occur as long as no moisture is being condensed. About 3 degrees per 1000 feet, reasonably linear with height. .... and Saturated Adiabatic lapse rate: a RATE-OF-COOLING (or heating) of a parcel of air should it be displaced from its present level and rise (or descend) through the atmosphere, with the consequent pressure change on it. The "wet-adiabatic" rate of cooling (or heating) will occur as long as the relative humidity of the parcel is 100 percent and moisture is being condensed (or evaporated if descending). This rate is less than the dry-adiabatic rate, because the condensation of moisture releases heat which slows the cooling of the air. Not linear with height. Varies from about 1 degrees per 1000 feet at very high dewpoints, to almost 3 degrees per 1000 feet at very low dewpoints. Two different concepts! |
What you described is exactly the point many people (including myself)
have been confused about. The 2C/1000' is the average environmental lapse rate. Adiabatic lapse rate is never 2C/1000'. It is 1C/1000' or 3C/1000'. Many FAA texts do not explain this point clearly. Since most pilots get their meterology knowledge from FAA texts, and are not formally educated on the subject, it is not surprising this confusion exists. I would bet you any money that if you took a survey of CFI's most would not know this fact. "Icebound" wrote in : "Darrell S" wrote in message news:bdUNd.46622$bu.24635@fed1read06... 2°/1000' is "average" since air at different levels may be saturated or unsaturated and can change from one to the other at different levels. Lifted air would cool at 3°/1000' while lifting through dry air and at 1°/1000' lifting through moist air levels. So.... the average is 1° no, No, NO!!! The 2 degrees per 1000 feet comes from a "determined" average lapse rate of real atmospheres averaged around the globe and averaged throughout time.... determined within reason. It has nothing, NOTHING, to do with saturated or unsaturated or dry adiabatic or saturated adiabatic. Dry and Saturated adiabatic lapse rates are a law-of-physics-rates-of-cooling, not actual temperatures in the real nor in the "standard" atmosphere. Please divorce those two concepts: First concept: Environmental lapse rate: temperature structure of the real atmosphere right now. Usually, but not necessarily, cools with height. How much per 1000 feet? Depends on the structure TODAY, THIS INSTANT. Not constant throughout. May be several degrees per 1000 feet in some layers, zero in others, and even an inversion in still others. ... and Standard Atmosphere Lapse Rate: defined at "lowering 1.98 degrees per 1000 feet" within the troposphere (lowest 11 kilometres). Second concept: Dry Adiabatic lapse rate: a RATE-OF-COOLING (or heating) of a parcel of air should it be displaced from its present level and rise (or descend) through the atmosphere, with the consequent pressure change on it. The "dry-adiabatic" rate of cooling will occur as long as no moisture is being condensed. About 3 degrees per 1000 feet, reasonably linear with height. ... and Saturated Adiabatic lapse rate: a RATE-OF-COOLING (or heating) of a parcel of air should it be displaced from its present level and rise (or descend) through the atmosphere, with the consequent pressure change on it. The "wet-adiabatic" rate of cooling (or heating) will occur as long as the relative humidity of the parcel is 100 percent and moisture is being condensed (or evaporated if descending). This rate is less than the dry-adiabatic rate, because the condensation of moisture releases heat which slows the cooling of the air. Not linear with height. Varies from about 1 degrees per 1000 feet at very high dewpoints, to almost 3 degrees per 1000 feet at very low dewpoints. Two different concepts! |
Andrew Sarangan wrote:
Adiabatic lapse rate is never 2C/1000'. It is 1C/1000' or 3C/1000'. Many FAA texts do not explain this point clearly. Since most pilots get their meterology knowledge from FAA texts, and are not formally educated on the subject, it is not surprising this confusion exists. I don't want to re-confuse you, but there actually *is* a saturated adiabatic lapse rate equal to 2C/1000'. Recall that warmer air can hold more moisture than cold air. As a result, saturated adiabatic lapse rates vary from nearly the same as the dry rate of 3C/1000' (cold air), all the way up even beyond the 1C/1000' you quote (very warm air). You're right about the ****-poor nature of FAA texts though. Not just the bad meteorological explanations, even their basic physics is wrong. They blather on about "centrifugal force", which doesn't even exist! What does exist is centripetal acceleration, which acts in the opposite direction of the mythical "centrifugal force". Jim Rosinski |
"jim rosinski" wrote in message
oups.com... [...] You're right about the ****-poor nature of FAA texts though. Not just the bad meteorological explanations, even their basic physics is wrong. They blather on about "centrifugal force", which doesn't even exist! Well, except that unlike the whole lapse rate confusion, the idea of "centrifugal force" is perfectly valid, depending only on one's frame of reference, and complained about only by overly pedantic engineers and laymen. Pete |
![]() "jim rosinski" wrote in message oups.com... .... Not just the bad meteorological explanations, even their basic physics is wrong. They blather on about "centrifugal force", which doesn't even exist! What does exist is centripetal acceleration, which acts in the opposite direction of the mythical "centrifugal force". Ooops, Jim. Just when you had them on your side :-) :-) |
![]() "Andrew Sarangan" wrote in message 1... What you described is exactly the point many people (including myself) have been confused about. The 2C/1000' is the average environmental lapse rate. Adiabatic lapse rate is never 2C/1000'. It is 1C/1000' or 3C/1000'. Many FAA texts do not explain this point clearly. Since most pilots get their meterology knowledge from FAA texts, and are not formally educated on the subject, it is not surprising this confusion exists. I would bet you any money that if you took a survey of CFI's most would not know this fact. As Jim pointed out, the moist (saturated) adiabatic rate is not constant, but anything from about 1 to about 3 deg C per 1000. Because the amount of condensing moisture is different at different dewpoints, and therefore the amount of heat released is different in the different situations. If no condensation is occurring, yes, then it is only 3/1000. I have only recently sat through my first aviation ground school. Meteorology was taught by a pilot, not a meteorologist. The pilot himself had obvious lack of understanding of the subject. After his instruction, we have 30 new potential pilots in a second generation with similar misconceptions. Eventually one or more of them are going to become CFIs. They may upgrade their meteorological education.... or NOT; the current instructor didn't. I have not checked this out in detail: http://66.208.12.20/amsedu/online/info/ but it appears to be EXACTLY what pilots could use. The full one-time course fee at $250 is a bargain in the context of your overall flying costs. Even the no-license-fee "textbook-only" option would help us all. By the way, the American Meteorological Society, in case you don't know, has been around since 1919, and is THE organization for professional meteorologists in the USA, so I am pretty confident that you will be getting your money's worth. |
How high is that cloud? | Tim Hogard | Instrument Flight Rules | 26 | November 29th 04 01:40 AM |
