#11
Since I'm not fully satisfied by his answer I would like also your
opinion. I was told the same thing by a mechanic, but I'm skeptical he has any idea. I've had students put them both in cross feed on the ground, and the engines didn't stop. You might try a high power runup on the ground and do the test. |
When I checked out in the Seneca II, (PA-34-200T) it was standard practice
to start on Main, go to X-Feed (for both sides) during taxi, and return to Main for run up checks and take off. And then the check pilot said, "don't mess with what is working", interesting statement, meaning, don't do the x-feed check on the ground. Forget to go back to Main for take off and you'll have bigger problems. I checked my POH and found the reference you mention. And no explanation as to why. Long time on both to x-feed.. or take off with both on x-feed is not recommended. A guess would be "Not able to maintain high fuel flow rates at take off power across the x-feed line". According to the manual, the only reason to x-feed is to maintain lateral fuel balance when operating on one engine (emergency condition) and to have the other fuel selector to the "off" position. So, right engine shut down, right wing getting heavy from left engine draining fuel from left tank. So Right tank goes to x-feed the left, and left tank is set to off. I know this information does not answer your question. BT "Silvio Mecucci" wrote in message om... I've asked the following question to NewPiper Inc. Sent: Tuesday, February 08, 2005 7:24 AM To: Flynn, Kathy L. Subject: PA34 200T question Dear Mrs / Ms Flynn I've called the italian dealer you gave my the number of. They made me talk with the dirigent who answered my question in the way I'll report Since I'm not fully satisfied by his answer I would like also your opinion. In the P.O.H. of the PA-34-200T, Seneca II I'm flying with, Section 7 - Description and operation, there is a NOTE which reports: "Do not operate with both selectors on "X-FEED."" Page 7-13 Issued August 23, 1976 Revised March 11, 1977 If such a note is present I suppose that something dangerous may happen if the prescription wouldn't be followed . It is straightforward that operating the airplane with both engines in x-feed is meaningless, but I would like to know which could be the consequence of operating both engines on X-FEED on the ground, other than wasting some of the returned fuel if the tanks are full. The italian dealer answered: "I don't know the answer but I think if you use both engines in x-feed they will stop for lack of fuel. In any case you don't need to worry about the x-feed pipeline integrity. It is checked yearly by mechanics, and also you'll never use it in your life." This was all his answer and it seems a little too generic to me and, maybe I'm wrong, I'm not sure He's aware of the precise technical consequence of the both engines x-feed operation. Since I'm going to fly as instructor on this plane I would like to know in deep detail all the consequences of the possible wrong actions. Your help would be really useful to me. Thank you for your attention, Silvio Mecucci Piper answer was: I our technical support reviewed your message and responded with following reply: * All aircraft per certification must be operated using the most current Pilot's Operating Handbook for their aircraft. * The New Piper Aircraft, Inc. recommends the aircraft to be operated per the approved current manual for the aircraft. * The New Piper Aircraft, Inc. will not speculate on what may happen if the aircraft is not operated per the most current correct POH. Thank you, Kathy Flynn THE NEW PIPER AIRCAFT, INC. And this was my last reply... Dear Mrs/Ms Flynn, I do agree with all the point you made and for sure I will operate the aircraft only according to the manual. Having made this last point certain, what I would like to know is the reason why Piper put that note in the manual. This doesn't mean I don't want to follow it.... The problem is that if I, as a flight instructor, say to someone "Never use it in this way." and that someone asks me "Why ?" I should be able to answer him something more complete than "Since this is what the manual says.". That's the reason why I've asked You a support in this. I can assure You that nothing of what You will write in the email (I hope you will answer me again) has a legal value here in Italy (yet), so could you please tell me the reason that note is present in the P.O.H. ? Silvio Mecucci No answer since then... Can anybody help me, or should I unassemble my Seneca II to get an answer ? Thank You all, Silvio Mecucci |
"kage" wrote in message ... Imagine you are a FI and your student asks you why you should not test both X-FEED at the same time durign taxying. What are you gonna answer him ? "Because it is written in the POH." ?! If your student is a good one He would not be satisfied by this answer since it is an answer it could find himself. Thank you anyway... Silvio Imagine you are a FI and your student asks you why you should not test THE LANDING GEAR time durign taxying. What are you gonna answer him ? "Because it is written in the POH." ?! If your student is a good one He would not be satisfied by this answer since it is an answer it could find himself. Best, Karl Well the answer to the x-feed question may be "It was not tested by the builder hence it is not allowed in the aircraft." |
Good Question Silvio, The answer is probably related to an accident
in the early 70's. A Piper Aerostar hit the ground with both fuel selectors in crossfeed. I have no idea why he crashed, but the selctor situation came out in the litigation, and some folks seemed to think it was Piper's fault. This was during a time when Piper aircraft was about to become "the new piper aircraft". I tried to check the NTSB reports, but they only go back to 83 or so. Maybe someone here can remember better than I. Al |
"Silvio Mecucci" wrote in message -
In the P.O.H. of the PA-34-200T, Seneca II I'm flying with, Section 7 - Description and operation, there is a NOTE which reports: "Do not operate with both selectors on "X-FEED."" Page 7-13 Issued August 23, 1976 Revised March 11, 1977 It is straightforward that operating the airplane with both engines in x-feed is meaningless, but I would like to know which could be the consequence of operating both engines on X-FEED on the ground, other than wasting some of the returned fuel if the tanks are full. Here is a link that adequately describes why both engines should not be in the crossfeed position- http://www.ntsb.gov/ntsb/brief.asp?e...16X01434&key=1 D. |
On Fri, 11 Feb 2005 00:19:48 GMT, "Capt.Doug"
wrote: Here is a link that adequately describes why both engines should not be in the crossfeed position- http://www.ntsb.gov/ntsb/brief.asp?e...16X01434&key=1 D. How does that accident adequately describe why you shouldn't have both engines on crossfeed? In the statement made by the pilot, he stated that he placed the fuel selectors on crossfeed during his taxi but prior to takeoff, he had them in the on position. Then after the plane landed on the highway and on his exit of the plane, he flipped them down missing the off position (which is very possible if you have ever flown in a Seneca) The FAA's examine found them just as the pilot stated. In the probable cause statement, all the FAA could do is state that there was a loss of engine power in the left engine. There is no other facts supporting the notion that he had taken off with both on crossfeed. Now you could make the assumption that the pilot was lying, but because there was no other evidence to show that he was, you can not say that this was the cause of the accident. The FAA sure didn't feel comfortable saying it, because it wasn't even mentioned as a possibility. I am curious as well as why. I fly for a company part time that has a Seneca II and I have also taught many students in a Seneca II and not once has that question been poised to me nor have I really thought about it. But it does make for an interesting question. Scott D To email remove spamcatcher |
| recommended. A guess would be "Not able to maintain high fuel flow rates at | take off power across the x-feed line". Yes, I thought to this. But then I thought also that while using the X-feed in real situation the engine still running is used at higher than normal cruise settings. So.. I still don't know.. A good answer to the original quetion could be "Since it has happened that a take off with both X-FEED on has ended in an accident, and nobody has still identified the cause". But this accident has to be reported prior of March, 11, 1977, the last revision for the manual I have. S. |
Scott D. wrote in message In the statement made by the pilot, he
stated... Would you incriminate yourself? The costs of cleaning up the lead left from the fuel on the highway and surrounding soil and sewer to EPA standards was huge. The interstate was closed for most of the day which brought repercussions from the DOT. Not to mention the airplane was totalled. What is the incentive to admit liability? There is no other facts supporting the notion that he had taken off with both on crossfeed. Now you could make the assumption that the pilot was lying, but because there was no other evidence to show that he was, you can not say that this was the cause of the accident. The FAA sure didn't feel comfortable saying it, because it wasn't even mentioned as a possibility. In a court of law, the evidence presented is weak. However, can you explain why the aircraft failed to remain airborne? It wasn't an overweight issue. I have flown Senecas, I through IV. The fuel selectors are not too hard to manage effectively. One just has to remember to manage them. If fatalities are not involved, the NTSB sometimes chooses to find an easy way to finish the paperwork. I know this firsthand as do a select few others in this group. Read between the lines of the report and you will know the cause. Talk to a Piper engineer off the record and you will know the cause. Ask the same engineer the same question in a courtroom and a different answer will be elicited, something akin to the answer received by Mr. Mecucci. I am curious as well as why. I fly for a company part time that has a Seneca II and I have also taught many students in a Seneca II and not once has that question been poised to me nor have I really thought about it. But it does make for an interesting question. Here's some more interesting questions. Why do some single-engine Cessnas equipped with bladder tanks run out of gas prematurely? Why do some Mooneys' electric landing gears retract during the roll-out? The AFMs don't tell you. Here's one for you to ponder- Why do Senecas have a preponderence for nosegear failures? Piper won't tell you that they do, but they will sell you a reinforced drag link bolt. D. D. D. |
| Thread Tools | |
| Display Modes | |
| Seneca V vs. Navajo operating costs | Jarema | Owning | 1 | February 12th 05 11:30 PM |
| Insuring a C310 vs. Piper Seneca | Dave | Owning | 17 | October 27th 04 04:29 PM |
| Want to purchase PA34-200 Seneca | Grasshopper | General Aviation | 11 | July 7th 04 06:09 PM |
| Seneca V question | DeltaDeltaDelta | Piloting | 5 | January 17th 04 03:44 PM |
| I am going to do it again! A Piper Seneca? | Michelle P | Owning | 5 | August 20th 03 02:59 AM |
