White LS Sleeves VS Wedekind for ASW 19?
Old May 19th 14, 05:44 PM posted to rec.aviation.soaring
JohnDeRosa
Default White LS Sleeves VS Wedekind for ASW 19?
Just to reiterate, as JS mentioned, the Uerling Sleeves only work on "straight" L'Hotellier fittings. They don't work on 90 degree fittings which my glider has for the ailerons.
I used Uerling Sleeves on the airbrake straight fittings because these were a BITCH to get the original safety pins in while trying to look inside a black hole on a white ship in bright sunlight. The ailerons were much easier and I continued to use the pins until I went Wedekind.
Also, I was told way back when that the Uerling Sleeves needed to be replaced every 2 years. Anyone know about that?
- John
http://aviation.derosaweb.net/wedekind
Wedekind Sleeves for GROB ASTIR CS Juliet11[_2_] Soaring 2 April 1st 13 03:39 PM
Wedekind Safety Sleeves ContestID67 Soaring 3 March 5th 07 12:04 PM
Hints on Securing L'Hotellier with Wedekind Sleeves ContestID67 Soaring 0 December 1st 05 08:29 PM
Wedekind Safety Sleeves Huds Soaring 5 May 8th 05 03:07 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
