Very serious - please read
Old June 20th 14, 11:54 AM posted to rec.aviation.soaring
Default Very serious - please read
Regardless of the inaccuracies in the USA Today article, the float problem in Lycoming engine carburetors is real, and must be addressed. This problem happened to our Pawnee tow plane, resulting in an off field landing and extensive damage.
Tom Knauff
Old June 20th 14, 02:47 PM posted to rec.aviation.soaring
Bill D
Tom Knauff
Yes, it's very real - and it's been recognized as a problem for at least 50 years.
I suspect most of the problem can be traced to the effects of engine vibration on delicate carburettor floats and the fact that float bowls tend to collect water condensation which causes corrosion. Corroding brass floats was why they tried plastic floats.
I've known operators who replaced their carburettors with rebuilt ones every 500 - 1000 hours as preventative maintenance. Just because the engine has a 2000 hour TBO doesn't mean the accessories will last that long.
This why it's nearly impossible to find a carburettor on a car these days.
Old June 20th 14, 04:19 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
days.
Er no. The reason you do not find carburetors in cars is the stringent
emission standards required, and the fact that they can only be met by
injected engines where the fuel is metered.
Old June 20th 14, 06:28 PM posted to rec.aviation.soaring
bumper[_4_]
I think the real reason you don't find more modern technology creeping into the legacy aircraft engines is FAA regulation, certification costs, and liability.
BTW, back in '09 there was a "mandatory SB" to replace metal, plastic, and previous foam floats with the new "blue epoxy foam" floats.
bumper
Read on how to avoid internet scams and fraud attempts! Please read and inform others if you find it usefull. Mark Piloting 0 April 2nd 10 04:43 PM
Group C-54. See Read Me: 01 of 14- C-54 Read Me.txt (1/1) Rogue Aviation Photos 0 June 1st 09 04:59 PM
read [email protected] Owning 0 March 22nd 05 03:06 AM
READ ACPOKER5 Soaring 0 September 11th 04 10:39 PM
Probably seen this, but a fun read (again) John Rotorcraft 2 November 17th 03 01:57 PM
