Standard Airworthy Certificated Gliders in the US
Old July 16th 14, 06:30 AM posted to rec.aviation.soaring
Doug Mueller
Default Standard Airworthy Certificated Gliders in the US
At 05:10 16 July 2014, Doug Mueller wrote:
At 03:01 16 July 2014, GM wrote:
Can anyone give me some pointers on how to research the FAA
database to
find out if a glider has a standard airworthiness certificate or
must
be
registered in the experimental category?
Uli
Uli,
go to http://www.faa.gov
in the search bar type in (TCDS)
From there click on the link on the left side current model/By
Make
Click on the letter at the top of the manufacturer name. It will
give
alphabetical order.
If it is not listed then it could be under a different type certificate.
Check back here if you have a specific manufacturer not listed.
Best of Luck, Doug
Sorry for the repeat info.
Old July 16th 14, 03:29 PM posted to rec.aviation.soaring
Dan Marotta
Interesting - I could not find either AB Sportine Aviacija or LAK in the
TCDS database. Is that because my glider is Experimental?
Dan Marotta
database to
find out if a glider has a standard airworthiness certificate or must
be
Uli
Uli,
From there click on the link on the left side current model/By Make
Click on the letter at the top of the manufacturer name. It will give
alphabetical order.
Best of Luck, Doug
Old July 16th 14, 03:53 PM posted to rec.aviation.soaring
Bob Kuykendall
I think the cause and effect are the other way around, but, yeah.
Using XCOM and Flight Line radios in certificated gliders Paul Remde Soaring 11 August 21st 11 02:34 PM
Drones To Be Certificated For GA? hierophant[_2_] Piloting 36 April 22nd 11 10:14 PM
Considering Refinishing Club/Standard Class Gliders for part time job [email protected] Soaring 8 January 3rd 09 08:21 PM
How are avionics technicians certificated? Jim Stewart Piloting 7 March 18th 07 02:45 AM
Motor gliders in Standard and 15-meter class? wiktor256 Soaring 0 July 23rd 05 08:51 AM
