Square root wing loading conversion method
Old August 26th 14, 10:03 PM posted to rec.aviation.soaring
Default Square root wing loading conversion method
The other issue with the original question is that normalizing for wing loading is a theoretical comparison that gives a relative sense for how the aerodynamic designs perform, but most gliders have different min/max wing loading ranges so in the real world you might not end up apples to apples in terms of wing loading anyway. Also, the different glider designs will reflect optimizing for a different wing loading ranges. Load a V2 up to the min wing loading of a -27 and it's a very different comparison than both gliders with a 175 lb pilot dry.
Kind of depends what you intend to do with the analysis.
9B
K8 wing root depth Mike Dowling Soaring 1 July 3rd 14 11:30 PM
Wing Root Fairing Bob Noel Owning 8 June 22nd 06 01:24 AM
Ventus A and B Wing Root Fairings [email protected] Soaring 17 June 24th 05 02:13 AM
Wing root fairings D.A.L Soaring 10 October 29th 03 11:36 AM
wing root strakes (not canard A/C) Wallace Berry Home Built 0 October 2nd 03 08:47 PM
