#11
Hi,
The ConnectMe program works great for uploading task declarations to the 302 and downloading secure flight logs from the 302. However, it can't be used to edit 302 settings or to load the pilot name. The 302 utility must be used for those items. Fortunately, those settings only need to be setup once. You can download versions for PC and PDA (not Oudie) he http://www.cumulus-soaring.com/cai_downloads.htm Best Regards, Paul Remde Cumulus Soaring, Inc. _______________________________ "Muttley" wrote in message ... On Thursday, September 4, 2014 9:23:39 PM UTC+1, wrote: Nick, Per your suggestion, I just sent a request to learn how to put the CAI Utility file (PC or IPAQ) onto the Oudie, if possible. Raul Boerner DM Can you not use the ConnectMe utility already installed on the Oudie, it is supposedly compatible with the Cambridge 302?? Mottley |
I am another person who would really like the Oudie to talk to the 302 so that settings like Ballast, Bugs, Polar (two different wings for my aircraft) could be set via the Oudie.
Is the problem that the Oudie people just don't want to install the software or is there a basic computer language problem with the systems? |
I use a Dell Streak 5 running XCSoar which communicates with my 302 via
Bluetooth (K6BT that I got from Cumulus). It allows me to set MC, bugs, ballast, polar, pilot name, etc., and receives GPS data, wind, speed, etc. from the 302. I know at least one person who runs XCSoar on his Oudie so perhaps that would be a way to achieve your goal. XCSoar is FREE, so all you have to do is download and install it and you're ready to give it a try. You can also download a PC version of the program to learn and practice with. I started this thread a while back because I'd lost my copy of the 302 utility. I got it from Paul's site and, one of these days, I'll carry my laptop to the airport and see if I have my name in the 302. I probably did it with the Ipaq when I bought the glider. BTW, when I've flown other gliders, it's been simple to select another polar from the list provided by the XCSoar executable. Dan Marotta On 9/5/2014 7:00 AM, wrote: I am another person who would really like the Oudie to talk to the 302 so that settings like Ballast, Bugs, Polar (two different wings for my aircraft) could be set via the Oudie. Is the problem that the Oudie people just don't want to install the software or is there a basic computer language problem with the systems? |
I found this 23 February,2011 post by Andrej. However, there were other responses indicating freeze problems using these solutions.
Cambridge 302 Compatibility? There are two ways to use the CAI utility on Oudie: 1. Save it to the root of the microSD card and rename it to UpdateOudie.exe. Before you use Oudie for inflight navigation you will have to remove the card otherwise it will keep running the utility. 2. Overwrite the ConnectMe.exe in 2577 folder with the utility file. That will remove ConnectMe from your Oudie and the ConnectMe button will start the utility. You can get the ConnectMe back by reinstalling the firmware. |
Lou
with all due respect, bringing my laptop to the airport, purchasing a converter cable, disconnecting my Oudie cable from my 302, connected this new cable, disconnecting the new cable and them rehooking up my Oudie cable does not sound simple to me. This is my point of my first post. We Should be able to bypass all of the above. Simple to me is to have Naviter put the CAI Utility on the Oudie and then open the program with the touch of your finger and do your thing. All you 302 + Oudie fans please shoot a email to Naviter and ask them to give use the option of loading the CAI Utility during the next update, I would hazard a guess it would be quite simple for them to do so and would be another great benefit of owning a Oudie. |
Hi Nick,
Unfortunately, the problem is not a Naviter problem - it is a Cambridge problem. The Cambridge 300 Utility can be copied to an Oudie, but it doesn't seem to run well on an Oudie. It must be compiled for a processor which is not compatible with the Oudie. Naviter doesn't have the original Cambridge 300 Utility code - so they can't fix the problem. Cambridge is no longer around, so they can't fix it either. ClearNav probably doesn't have the code. Even if they did - they wouldn't be motivated to work on it. Theoretically, Naviter could create screens in SeeYou Mobile which would make it possible to edit the pilot name and polar data and logging interval in the 302 (as is done with the LX1600). However, I doubt they would be motivated to do that since 302 units are not as popular in Europe and are being replaced with newer products (like the LXNAV V7) quite rapidly which work great with SeeYou Mobile. If you are doing to lobby Naviter - lobby that they add 302 support (pilot name, polar and logging interval settings) to SeeYou Mobile. But I wouldn't expect much. Naviter would rather work on new features which would apply to a larger population of SeeYou Mobile users. Best Regards, Paul Remde Cumulus Soaring, Inc. "Nick Kennedy" wrote in message ... Lou with all due respect, bringing my laptop to the airport, purchasing a converter cable, disconnecting my Oudie cable from my 302, connected this new cable, disconnecting the new cable and them rehooking up my Oudie cable does not sound simple to me. This is my point of my first post. We Should be able to bypass all of the above. Simple to me is to have Naviter put the CAI Utility on the Oudie and then open the program with the touch of your finger and do your thing. All you 302 + Oudie fans please shoot a email to Naviter and ask them to give use the option of loading the CAI Utility during the next update, I would hazard a guess it would be quite simple for them to do so and would be another great benefit of owning a Oudie. |
On 7/09/2014 00:21, Nick Kennedy wrote:
Lou with all due respect, bringing my laptop to the airport, purchasing a converter cable, disconnecting my Oudie cable from my 302, connected this new cable, disconnecting the new cable and them rehooking up my Oudie cable does not sound simple to me. This is my point of my first post. We Should be able to bypass all of the above. Simple to me is to have Naviter put the CAI Utility on the Oudie and then open the program with the touch of your finger and do your thing. I love self-absorption. It's such a pleasure to watch. Let me see: using a laptop on the field which you probably already had in your car to use in the clubhouse and hooking and unhooking a cable is much more difficult and stressful than re-writing parts of a large application - including its tricky communication protocols, testing the re-writes, re-writing to fix the faults, re-testing, etc and then promulgating the result to hundreds of owners around the world - of whom ONLY 10 GIVE A DAMN! ....and ALL of that 10 already own the program and wouldn't pay a penny for the revision! Now I'm as prospective an Oudie owner as any of the thousands of r.a.s. readers who also don't own one. Will easier 302 compatibility make me rush out and buy one? No. Will any price rise due to increased software maintenance overheads make the Oudie a more attractive purchase to me and thousands of other non-owners? No also. GC All you 302 + Oudie fans please shoot a email to Naviter and ask them to give use the option of loading the CAI Utility during the next update, I would hazard a guess it would be quite simple for them to do so and would be another great benefit of owning a Oudie. |
Plenty of old Ipaq's around where the CAI Utility works well on a cable connection. No need for Laptops.
Muttley |
On Mon, 08 Sep 2014 03:24:55 -0700, Muttley wrote:
Plenty of old Ipaq's around where the CAI Utility works well on a cable connection. No need for Laptops. It should be trivial for anybody with a soldering iron to make up a T- cable (possibly with a switch in it) by combining the new cable and an Oudie-compatible cable. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Hi Paul
Thank you for response and the clear explanation why the CAI Utility is not compatible with the Oudie. I know very little about software code and operating systems. The CAI utility, to me anyway, seemed to be a very simple program and I thought it would be easy to just Copy and Paste it into a Oudie. Obviously this is not the case. Cheers Nick Kennedy |
Cambridge 302 Utility app | [email protected] | Soaring | 1 | June 7th 12 03:59 PM |
Cambridge Utility Program Question | Scott Alexander[_2_] | Soaring | 4 | February 9th 10 07:34 PM |
Utility program for PDA | Oscar Goudriaan | Soaring | 4 | April 10th 08 07:11 PM |
CAI 302 Utility program confusion | Frank[_1_] | Soaring | 1 | March 30th 07 03:57 AM |
CAI 302 Utility Program questions | Andy Smielkiewicz | Soaring | 2 | March 16th 05 01:32 PM |
