Autorotation ? R22 for the Experts
Old February 29th 04, 09:53 PM
Michael McNulty
You may not have liked his explaination, but John and Steve are correct.
The rotor coning depends on the rotor speed and the total rotor thrust
(weight and
load factor). It does not depend on the engine power or the rate of
descent. A max gross weight auto gives the essentially the same coning as a
max gross weight take off, or a max gross weight landing approach, or a max
gross weight hover, etc....
"Bob" wrote in message
The string starts with a guy asking a question of a pilot or a mechanic.
I,
being a longtime mechanic, try to answer his questionand stay ON TOPIC.
The
guy, and his original question, disappears!
No offense to John, but we end up with a physicist.
Start a new string...pullleeeeez!!!!
Bob
Old February 29th 04, 11:05 PM
Bob
AND ONCE AGAIN...I DID NOT SAY HE IS INCORRECT. Does anyone read a STRING?
OR only the last comment/response? Too bad we can't see where we started or
we would see how afar we wound up! The guy was asking about collective
position vs. engine RPM, but who could possibly imagine just what the
ORIGINAL question was now?
Old March 1st 04, 12:51 AM
Michael McNulty
Hey, you brought up coning, not me.
If you are so concerned with staying on topic, then why did you make your
original (incorrect) statement about coning? It has nothing to do with
autorotation except as it relates to rotor speed.
news
STRING?
or
Old March 1st 04, 01:05 AM
Steve R.
news
STRING?
or
Bob,
My response was prompted by a statement you made that seemed to strongly
imply that a rotor in autorotation had either "no" coning or at least,
significantly less coning than a rotor in powered flight. That is something
I disagree with.
If I misunderstood you, then I apologize. OTOH, I've been known to "not"
state my point of view as precisely as I would have liked on the first
attempt and I've seen others do it too.
FWIW,
Fly Safe,
Steve R.
Old March 1st 04, 01:23 AM
Steve R.
"Steve R." wrote in message
news
STRING?
started
or
Ok Bob,
I did a little search and here's the conversation in full! You'll note that
in message #6, you said (and subsequently reminded me of) that there was "no
cone to speak of" which is essentially saying, "there's no cone!" That part
I disagree with.
You also never really answered "my" question, posed in message #5 regarding
why the pilot could go full down on the collective and have an overspeed
problem with the engine idled but not with the engine and governor still in
the equation. I'll repeat the question. Is the engine acting as a brake on
the rotor rpm, not unlike a car running down hill, in gear, with the drivers
foot off the gas?
I'm just curious about this. I'm not trying to pick any fights. You're the
one that brought up the coning angle part the first time in this
conversation and some of us have questioned that. I still don't feel like
there's been an answer to that part of the question, just some defensive
responses.
FWIW,
Fly Safe,
Steve R.
Start Quote:
Message 1 in thread
Subject: Autorotation ? R22 for the Experts
View this article only
Newsgroups: rec.aviation.rotorcraft
Date: 2004-02-27 09:06:57 PST
Here is a good question for the more experienced helicopter pilot or
mechanic. A friend of mine that flies a late model Robison R22 Beta
II asked this question of a number of individuals and no one seem to
have an explanation. This included people at the manufacturer. I
believe I know the answer, however, I would like to put the question
out and see what others think before tainting their thoughts with my
ideas.
So here is the question: With one person flying the R22 (170lb),
simulating an autorotation by rolling off throttle, the collective
goes full down and pretty-much stays there to maintain proper rotor
rpm. With two people, same maneuver, some collective has to be pulled
to keep the main rotor from over-speeding. The amount of collective
will obviously vary dependent on a number of factors, but for this
example let's say about 1 inch off the stop. One more time with the
same maneuver, with two on board, except let the governor control
engine speed, and not rolling off throttle. In order to maintain
rotor speed the collective has to be on the stop. The question is
why? Please post your thoughts.
Eric DPost a follow-up to this message
Message 2 in thread
Date: 2004-02-27 17:18:01 PST
In the first instance, you are not "simulating" an autorotation; with no
engine OR no engine power applied to the rotor (throttle rolled off) you are
"performing" an autorotation. With the engine throttle left in a flight
position, the governor is GOVERNING rotor R.P.M. due to it's linkage to the
collective and the engine which is what under any circumstances what it
ACTUALLY GOVERNS, and ONLY THEREFORE can govern your rotor R.P.M.
SO...collective bottomed...engine "running", governor GOVERNS rotor R.P.M.
NO engine running (or no throttle applied) YOU govern rotor R.P.M. The
other variables you alluded to will include gross weight per fuel on board,
etc.
BobPost a follow-up to this message
Message 3 in thread
Date: 2004-02-28 07:54:02 PST
are
R.P.M.
board,
etc.
Bob
One pob = collective fully down to maintain rotor speed.
Two pob = collective not fully down to prevent overspeed.
If helicopter is heavier will not the coning angle be greater and
therefore the rotor speed higher because of less effective rotor
diameter. Hence the need to pull some collective at heavier weight to
slow blades and increase rotor disk diameter?
Or maybe I'm talking b****x! It has been known!!
HerbiePost a follow-up to this message
Message 4 in thread
Date: 2004-02-28 09:10:04 PST
Herbie...
YES. BUT...that wasn't the question. The question was given
weight-throttle on vs. given weight-throttle off.
Message 5 in thread
Date: 2004-02-29 06:28:27 PST
news
Herbie...
Bob
I'm not sure I'm getting this either. The original poster was confused
because, engine out of the equation, they had to "raise" the collective to
prevent an overspeed. With the engine / governor still in the equation,
they "didn't" have to raise the collective to prevent an overspeed.
Now, if the collective is bottomed out and the MR blades are at an
autorotative angle, wouldn't the rotor system try to outrun the engine /
drive system? Or, is the engine acting as a brake in the situation, kind of
like a car coasting downhill, using engine compressionas a brake?
Just wondering?
Fly Safe,
Steve R.Post a follow-up to this message
Message 6 in thread
Date: 2004-02-28 09:34:42 PST
And come to think of it...actually NO. Collective down, there's no cone to
speak of or your rotor speed would be drooping.Post a follow-up to this
message
Message 7 in thread
Date: 2004-02-29 06:32:05 PST
to
No cone? I'm not sure I agree with that. Even with the collective all the
way down, there's still positive lift being generated by the rotor system.
Maybe the coneing angle isn't what it would be in steady state, powered
flight but I'm not sure it's accurate to say that there's "no" coning with
the collective full down.
Fly Safe,
Message 8 in thread
Date: 2004-02-29 07:21:10 PST
Steve...
Kindly read my post carefully. I said NO CONE TO SPEAK OF. As in...it
would not to compare to the cone present when trying to yank the helicopter
off the ground at Max Gross Weight. The lift generated with the collective
down is what keeps your rate of decent an "autorotative" rate, rather at
terminal velocity
As to your other post...when the collective is down with no engine power (on
a real helicopter) the pitch links are adjusted to keep the auto-R.P.M.
within an acceptable RANGE. That is a standard maintenance function, but it
dosn't mean the pilot can go to sleep during an auto. Collective down, if
rpm is too high- it's not adjusted properly, but the pilot can jockey the
collective. If its too low it's DEFINATELY not adjusted properly and rots
o' ruck.
In my first post in this string ALL I was trying (apparently not too
clearly) to explain is that if the engine is running (at all) the governor
knows it. I am a heavy helicopter maintenance type and can't even spell
Robinson, BUT even the most "rudimentary" if you will, helicopters have to
operate with some derivation of dynamic principles and proven hardware
concept application. The bottom line is in an auto, to keep the rotor in
the green right off. Too High is always better than Too Low because the
pilot can fix that.
Good luck,
Message 9 in thread
Date: 2004-02-29 08:20:29 PST
You will have almost as much blade cone in a STEADY auto rotation as
in hover. The cone angle is the tangent of the vertical force vector
verses the centrifugal l force vector generated by the rotation of the
blades. The only force not supported by the blades in auto rotation
is the force generated upward on the body of the helicopter by the
vertical wind component. Due to this you will still have 90% or more
of the cone angle when in hover. You can reduce the cone angle by
speeding up the RPM of the blades since the centrifugal force
generated depends on the square of the RPM. Most people keep the
blade RPM at the top of the green in auto's anyway.
John
On Sun, 29 Feb 2004 15:14:24 GMT, "Bob"
Steve...
terminal velocity
(on
it
o' ruck.
pilot can fix that.
Good luck,
Bob
File Type: gif cleardot.gif (43 Bytes, 3 views)
Old March 1st 04, 01:47 AM
Bob
Hey Mike...
I've been looking out of helicopter windows at blade tip targets tracking,
balancing, and setting autorotation RPM since I was done teething. SO you,
your x,+,-,%, = signs, textbooks, drawing boards, engineering degrees, and
any other credentials you might present can go elsewhere and tell someone
about autorotations, heavy gross flights, hovers and blade tip paths. Don't
sell it to me because seein' is believin', and I've seen plenty.
Goodbye string...it's been a gas!
Old March 1st 04, 01:51 AM
Eric D
First off, thanks to everyone that has responded to my original
posting.
Bob, Your response was super, and I understood what you wrote. I
believe what you described is right on the money for larger aircraft
that you mentioned you worked on.
The governor on the Robison R22 Beta II does not have linkage to the
collective. The scenario I described in my original post is due to
the sprag clutch. During low overrun speeds there is some drag
through the sprag. As the overrun speed increase this drag decreases.
To clarify, when speaking of overrun speed, it is the velocity across
the sprag clutch, not rotor speed.
I have limited helicopter maintenance experience on anything larger
then a Robinson R44. I received my A&P in the early seventies and
also have IA. I have worked on many types of aircraft over the years.
My passion for Robinsons came about four years ago, so I'm still
learning. I also have a fixed wing pilot's license and I have started
working on learning how to fly an R22. I'm finding it a blast and I
am really enjoying it.
Thanks again for the great responses,
Eric D
Old March 1st 04, 01:56 AM
Bob
And here's your answer. NO. If a helicopter is working correctly the
Freewheeling Unit or whatever it's called in the aircraft you are
referencing DISENGAGES the ROTOR from the engine drive as in autorotation it
disallows the engine to slow the rotor speed down AT ALL repeat AT ALL!
Old March 1st 04, 02:04 AM
Bob
And THANK YOU ERIC. Thought the dog ate ya, and I've been up to my ears
since I replied to your first question. Out of courtesy to the group, I'll
still consider whatever aircraft you were addressing a, uhhhhhh, helicopter
and leave the rest of this mess in your hands. If there was any help on my
part, you're most welcome.
Happy flying or whatever that contraption does
Old March 1st 04, 04:59 AM
Steve R.
it
Got it! That's what I thought but maybe I missed something. Thanks!
Fly Safe,
Steve R.
Are There Any P-47 Experts Out There Too? Schlomo Lipchitz Naval Aviation 10 February 15th 05 03:06 AM
Advice and experts with 400 series Cessnas (414 and 421), purchase and training [email protected] Owning 36 January 9th 05 02:32 AM
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
aero-domains for homebuilt experts secura Home Built 0 June 26th 04 07:11 AM
Aircraft Id needed from newsgp experts! RGP Military Aviation 1 January 1st 04 07:15 PM
