Running Top Hat on Kobo mini
Old July 19th 15, 04:53 PM posted to rec.aviation.soaring
Default Running Top Hat on Kobo mini
On Saturday, October 4, 2014 at 10:41:50 PM UTC+1, Ben S wrote:
Are you running Top Hat? What do you think?
Any chance you are running Top Hat on a Kobo mini? Please share
your experiences.
Have set up a Kobo Mini system with a hockey puck GPS (GlobalSat 353-S4) running TopHat to go in a SF27 we`re refurbishing. First impressions are VERY good and the screen readability is excellent.Strong sunlight is no problem at all. Very impressed. Makes everything else look very substandard.
PD.
Old July 21st 15, 04:00 PM posted to rec.aviation.soaring
your experiences.
I have run Top Hat with a mini Kobo for two years without any problems at all. My first set up used a hockey puck GPS and external 5v power coming from the 12v on-board power and a voltage reducer and a y-cable. This worked very well.
My current set-up uses the NMEA signals from a power flarm via a DB9 connector and serialUSB converter cable (obtained from someone in Spain for about 50 Euros). This cable also provides 5v power to the mini Kobo. This set-up also works perfectly and has cleaned up the situation behind the panel somewhat.
My mini Kobo has never seized up or done anything unexpectedly (this is reserved for the pilot) -
I'm very happy with Top Hat and the mini Kobo. Also, Rob Dunning gives great support for the TH.
Ulli Werneburg, MZ
I am up and running again Danny Deger Piloting 2 June 27th 07 05:20 PM
Running slow Jamie Nicholl Simulators 2 February 16th 06 09:57 PM
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Running an 0-235 well beyond TBO Paul Folbrecht Owning 8 March 14th 04 12:30 AM
