#11
sorry...dis SYMMETRY that is...aduhhh
Bob |
Definition of Coriolis Effect ~ Rotor blades will accelerate when its CG
moves closer to the center of rotation and will decelerate when it moves farther. Rotor blades accelerate and decelerate accompanied with the rotor blades flapping. __________________________ Bob you are correct when discussing a conventional teetering rotor or a flapping rotor. The above definition supports your statement, but, the "center of rotation" it is referring to is that of the mast. On a gimballed rotor, the teetering does not causes the blades to move closer or further from the "center of rotation" (tilted axis) of the teetered rotorhub. It must be noted that the rotor blades of a teetering rotor are connected to the mast via a Hooke's (Universal) joint. In this arraignment, the mast will turn at a constant velocity but the rotor will accelerate and decelerate. This effect can be equally well explained by the cyclical Coriolis effect or by the Hooke's joint effect. By replacing the Hooke's joint with a Constant Velocity joint the rotation of the teetered rotor hub will now be constant. In other words, the blades will no longer lead/lag in respect to the axis of the rotorhub AND will no longer lead/lag in respect to the axis of the mast. Dave J "Bob" wrote in message ... Coriolis effect has to do with dissimetry of lift (advancing blade vs. retreating blade) not blade velocity. On an articulated rotor head, lead/lag will remain, so CV joints are moot in that regard. Bob |
I believe I stated that the "moot" application is and articulated rotor head
and should have said a Fully articulated rotor head. |
Agreed. The subject is rotor with three or more blades. I used the
teetering rotor as the example because it is easier to understand, and the out-of-plane flapping and teetering hinges are functionally very similar. Researchers have been looking into the possibility of a soft-in-plane rotor for the tilt-rotor, to reduce the strength and weight of the current rotor. This implies, of course, that there is lead/lag activity in the V-22 rotor and the question is one of what activities are causing this lead/lag. Excluding lesser activities such as drag, a Constant Velocity joint will cause the rotor hub to tilt and have the same plane as the tip-path-plane. This will mean that the hub and blade roots will rotate at a constant velocity. There are patents for rotor head CV joints, but the original question asks if a CV joint has actually been implemented. The use of a CV joint in the V-22 should imply that it could also be implemented in conventional rotorcraft and result in simpler smoother rotors. http://www.SynchroLite.com/1301.html and its associated pages is the reason for originally asking the question. Dave J "Bob" wrote in message ... I believe I stated that the "moot" application is and articulated rotor head and should have said a Fully articulated rotor head. |
Dave,
I am following your idea of the tetering rotor hub i.e. the Bell 206, and I must state clearly that the blades on such a hub never change the angular relationship with respect to one another. The angular relationship from the trailing edge of one blade to the leading edge of the other blade NEVER changes. There is no mechanism in the rotor head that could possibly allow that to happen. positions on the head are FIXED PERIOD. The reason the head teters os to provide for equal lift on the advancing blade side of the rotor disk and the retreating blade side of the rotor disk. The higest point of the teter is over the nose and the lowest point is over the tailboom. Coriolis will ALWAYS accelerate a blade whose center of gravity moves toward the axis of rotation. Lift being agreed now equal all around, and blade angular relationships never changing, therefore velocity with respect to one another never changing, where does coriolis effect enter into this discussion at all??? Forgive me, but even after 20 years of strictly helicopter maintenance of All shapes and sizes I am at a loss to see the merit in your discussion. On a V-22 the same physics apply. For coriolis to enter the picture, it would necessarily be induced only by lead/lag of the blades and a hinge or mechanism to allow that to happen. I'm certainly not a V-22 guru but on ALL helicopters thae same things will happen for the same reasons. Now I'm sitting here asking myself where this might be going. Bob |
Hi Bob,
The intent of the original post in this thread was for me to get a clear understanding of exactly what is taking place in the V-22 rotor. Specifically, to find out if it is only a gimbaled hub or it is in fact a CV hub. I believe we agree on what the Coriolis effect is. We probably both agree that if a rotor mast is vertical and its TEETERING rotor disk is tilted 10-degrees down at the front, then the two blades, in unison, will be experiencing a two/rev. acceleration and deceleration, as they move toward and away from the axis of rotation. This rotational vibration is absorbed in the mast. In addition, we probably both agree that if a rotor mast is vertical and its FLAPPING rotor disk is tilted 10-degrees down at the front, then the blades will be experiencing a two/rev. acceleration and deceleration, as they move toward and away from the axis of rotation. This rotational vibration is absorbed in the lead/lag hinges. Now lets tilt the masts in both examples 10-degrees forward, so that the masts are now normal to the disks. I think that we will agree that in both examples the blades will no longer experience a two/rev acceleration and deceleration. There is no Coriolis effect about this tilted mast. This is where the CV joint differs from all existing rotor heads. The CV joint takes the constant rotational velocity of the vertical mast and delivers a constant rotational velocity to the axis of the tilted rotor disk. The blades are now rotating about tilted axis of the rotor disk and when viewed along this axis there is no Coriolis. Hope this explains my original question. Dave J. "Bob" wrote in message ... Dave, I am following your idea of the tetering rotor hub i.e. the Bell 206, and I must state clearly that the blades on such a hub never change the angular relationship with respect to one another. The angular relationship from the trailing edge of one blade to the leading edge of the other blade NEVER changes. There is no mechanism in the rotor head that could possibly allow that to happen. positions on the head are FIXED PERIOD. The reason the head teters os to provide for equal lift on the advancing blade side of the rotor disk and the retreating blade side of the rotor disk. The higest point of the teter is over the nose and the lowest point is over the tailboom. Coriolis will ALWAYS accelerate a blade whose center of gravity moves toward the axis of rotation. Lift being agreed now equal all around, and blade angular relationships never changing, therefore velocity with respect to one another never changing, where does coriolis effect enter into this discussion at all??? Forgive me, but even after 20 years of strictly helicopter maintenance of All shapes and sizes I am at a loss to see the merit in your discussion. On a V-22 the same physics apply. For coriolis to enter the picture, it would necessarily be induced only by lead/lag of the blades and a hinge or mechanism to allow that to happen. I'm certainly not a V-22 guru but on ALL helicopters thae same things will happen for the same reasons. Now I'm sitting here asking myself where this might be going. Bob |
Yes Dave. That does explain your original question.
