Rewiring boom mike for ASW27
Old December 6th 14, 07:17 AM posted to rec.aviation.soaring
Pierre Vav
Default Rewiring boom mike for ASW27
Did it on the 17.
Easy job, great results.
Found 6 parts of cable. Replaced by one piece of RG174.
Crimped male/female BNC connectors to be able to take the dash away.
Old December 6th 14, 06:37 PM posted to rec.aviation.soaring
Papa3[_2_]
On Friday, December 5, 2014 12:37:49 PM UTC-5, wrote:
On Friday, December 5, 2014 12:13:22 PM UTC-5, Papa3 wrote:
Easiest way is as you described. Use old wire to pull new wire forward. Hopefully you mike cable will be long enough to get to the connector at the radio and avoid additional connections.
Have fun
UH
Be advised - Hank's definition of "fun" isn't the same as most normal pilots.
p3
Define "normal"
UH
Not UH.
Old December 6th 14, 08:50 PM posted to rec.aviation.soaring
Boise Pilot
Bruno, you mentioned this last summer at Nephi, I meant to ask you if the pins on your radio are adjusted correctly for your type of mike? I know on the Dittel,Becker and some others that there are some small pins that can be moved in different combinations for various types of mikes. You may not have a mike problem.Check your manual this could save you the "fun" that Hank mentioned.
One Idaho
On Friday, December 5, 2014 8:57:09 AM UTC-7, wrote:
Anyone who has flown with me knows the quality of my radio transmissions both in and out really blows. I'm ripping out as much as possible and starting fresh. It would be great to replace the boom mike wiring through the right side wall to make sure it is not part of the problem. Has anyone replaced this wire? Is it possible to just connect a new wire onto it and just pull the new one through?
Bruno - B4
Old December 7th 14, 12:50 AM posted to rec.aviation.soaring
One Idaho
Bruno - B4
Thanks for the suggestion One Idaho. I am sending all my hardware to Richard at Craggy Aero for him to trouble shoot. I will mention this to him and have him check. Thanks!
Bruno - B4
Aircraft rewiring Brinks Owning 0 December 21st 06 10:51 PM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Home Built 1 December 3rd 04 09:16 PM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Piloting 1 December 3rd 04 09:16 PM
Icom Boom Mike Kevin Neave Soaring 2 September 25th 03 09:39 AM
Boom-mike cannula Jay Products 3 September 19th 03 03:10 PM
