Update on CAI flight recorder repairs from CNi (GPS Date problems)
Old December 15th 14, 03:13 AM posted to rec.aviation.soaring
Ramy[_2_]
Default Update on CAI flight recorder repairs from CNi (GPS Date problems)
My 302 was purchased new in 2008 and has the black case. I fly often which may helped the GPS battery to stay charged longer, not sure.
I just checked the NMEA sentence on the ground (no IGC log since I didn't fly or drive with it) and the NMEA sentence $GPRMC has the string 141214 after the coordinates. Today was 12/14/2014 and from what I gather this confirms my date is still correct.
Ramy
Old December 15th 14, 03:11 PM posted to rec.aviation.soaring
Dan Marotta
You should see that same date string at the beginning of the B records,
as well. But I guess those would only happen if you were moving?
Ramy
Dan Marotta
Old December 15th 14, 03:53 PM posted to rec.aviation.soaring
records, as well.* But I guess those would only happen if you were
moving?
Ramy
Dan Marotta
My latest 302 file is from October and the date is fine. It shows this line in the record:
HFGPS:GARMIN,LVS-25,12,18000
Does anyone know if this is one of the affected GPS engines?
With the 302 installed in my glider (which sits in my basement) I don't have a good way to test the unit.
Herb
Old December 15th 14, 04:15 PM posted to rec.aviation.soaring
David Kinsell[_2_]
Default Update on CAI flight recorder repairs from CNi (GPS Dateproblems)
records, as well.Â* But I guess those would only happen if you were
moving?
not sure.
Ramy
Dan Marotta
line in the record:
Herb
Yes, the 25 is the unit in question. However, that's likely just
hardcoded in the Cambridge firmware, so it doesn't mean anything. Even a
unit build in 2010 showed that string, and it almost certainly has the
GPS15 in it.
I was able to read the time from my unit before and after satellite lock
by looking at a tablet interfaced to the unit. Since the time before
lock had just drifted a bit from real time, I concluded the clock hadn't
lost power and the date almost certainly is still good.
-Dave
Old December 16th 14, 06:25 AM posted to rec.aviation.soaring
Ramy[_2_]
Looks like people are looking at different indicators to determine if the date is valid. Can anyone confirm which NMEA sentence holds the year and in what format?
Ramy
Old December 16th 14, 11:47 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
and in what format?
Its in two of the header records: the H record starting with HFDTE and
the first C record. In both cases the date is held as six digits: DDMMYY
You can find full details he
http://www.fai.org/component/phocado.../category/855-
technicalspecifications?download=8455:igc-fr-spec-with-al3-2014-6-30a
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Latest update of SeeYou and OLC flight claims causing problems [email protected] Soaring 6 October 30th 14 07:59 PM
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 08:31 PM
IGC-approval for LXN Colibri recorder - update issued [email protected] Soaring 0 June 20th 05 08:58 PM
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder Ian Strachan Soaring 0 March 15th 04 02:32 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 08:08 AM
