Helicopter Simulator
Old October 21st 04, 06:57 PM
Ezra Bavly
Hi Andrew,
Can you offer a good group discussion site for the Flightsim 2004?
I am using that MicroSoft FlightSim 2004software to simulate a Bell
JetRanger 206 helicopter and it is working quite beautifuly.
I am not fammiliar with the X plane program it might be better, but after
setting everything up with flight sim
I will carry on and try to enhance the program.The 2 areas I find need to
work on are the Landmarks issue and the other
is bulding the actual Switchs, Circuit Breaker to control the engine
systems. Any information on that will be appreciated.
Thanks
Ezra
"Andrew Crane" wrote in message
"Ezra Bavly" wrote in message
news:%tVbd.110800$a41.94245@pd7tw2no...
Hi There,
Any Idea where can a person find real geographical data to down load and
use
with the Microsoft flight sim 2004?
Ezra
Hi.
Why the subject "helicopter simulator"? MSFS can't simulate a helicopters.
Try X-Plane. Still rubbish but 1000 times closer than MSFS. Also, you're
in
the wrong group for flight sims.
Regards
Andrew
Inweb Networks. Quality internet and telecoms services
Sales: 08000 612222 Support: 08704322222. http://www.inweb.co.uk
E1 call share. 0800, 0845 and 0870 numbers - best rates. Resellers welcome
Old October 26th 04, 10:07 AM
Andrew Crane
news:hMSdd.791780$M95.84283@pd7tw1no...
Hi Andrew,
It depends on what you mean by works beautifully. The thing just doesn't
handle like a helicopter. For instance, if you go shooting across the
airfield at low level and pull back for a wingover, you'd expect the thing
to go shooting up into the air. It doesn't. Also I'd challenge you to auto
the thing. Also, if you slow down beyond ETL, the thing starts oscillating
in yaw from a point way behind the tail.
X-Plane is way better, but still fails to model
- etl
- vrs
- rotor overspeeds
- rotor disc coning at low RPM
- in fact most effects of low RPM
You will find though that the flight model is much much better than MSFS,
although the eye candy doesn't touch that of MSFS. Whilst neither of them
will fly like a chopper, you can use MSFS for navigation exercises and to a
limited extent, VFR flight planning (I sometimes practice a flight using
MSFS before going out and doing it for real as navigation is not my strong
point).
You can run both. X-Plane is a free download for a fully-functioning sim
which only differs from the real thing by offering limited scenery and
taking control away from you after about 5 minutes of operation.
Regards
Andrew
Old October 26th 04, 05:19 PM
Jim Carriere
Hi Andrew,
Another gripe about MS flight sim is the collective pulls exactly to
100%, no more, and the response-droop feel is all wrong. Maybe the
sit-down sim I tried was incorrectly rigged, but in real lift, you
can pull WAAAY more than 100% torque in a 206, especially in transient.
If you think of it as procedures trainer or an expensive video game,
it doesn't seem so bad.
Old October 26th 04, 11:16 PM
Brett Sumpter
Actually, it models everything you've listed in current versions
(7.61/62) - some better than others though:
ETL isn't as abrupt in onset as it should be, but it's definitely
there.
VRS is there but is a hack & not truly calculated, it's a very generic
effect - it looks for vertical descents over a certain rate & then
kicks it in. You get a nasty rate of descent & some wobbling around,
recovery takes some airspeed.
It'll most definitely overspeed the rotor, and the disk does cone more
at low rpm. You can also droop the rpm by pulling pitch too fast, or
pull too much & bleed it off - which slows the tail rotor as it
should, you'll run out of yaw control pretty quick.
Most of this has been there for quite a while, although ETL was broken
in a few versions along the way...
On Tue, 26 Oct 2004 10:07:47 +0100, "Andrew Crane"
- etl
- vrs
- rotor overspeeds
Old October 18th 04, 05:09 PM
Beav
Hi There,
use
Twy www.flightsim.com and www.simflight.com
Beav
Please note my E-mail address is "beavis dot original at ntlworld dot com"
(with the obvious changes)
Beavisland now lives at
www.beavisoriginal.co.uk
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Rotorcraft 0 September 22nd 04 07:17 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
helicopter simulator plans Anthony Rotorcraft 0 November 5th 03 05:13 PM
