Silver Badge questions
Old February 22nd 15, 05:45 AM posted to rec.aviation.soaring
Bill T
Default Silver Badge questions
I don't think Repolge barographs are accepted any more? Many years ago SSA told us we were the only submitter that year using a Repolge and film.
I thought it now had to be a digital recorder?
Most "approved" recorders have a baro record for altitude, along with the GPS altitude.
Someone at your field may have a portable recorder, Nano's are great.
BillT
Old February 22nd 15, 11:24 AM posted to rec.aviation.soaring
Cookie
Both the SSA website info on silver badge, and the FAI "rules" still mention "stand alone baragraph".....I can't find anything that says a "replogle" or Winter" baro is not to be used!
The lower cost electronic flight recorders such as Fly with CE...do NOT have baro (pressure)altitude so the rules require an extra height margin when going for altitude badges, to compensate for any possible error..
Cookie
BillT
Old February 22nd 15, 11:27 AM posted to rec.aviation.soaring
Cookie
Cookie
So I think climbing an extra 100 meters for the silver altitude beats spending an extra $500 to $1000 for a pressure sensing recorder any day!
Cookie
BillT
Old February 22nd 15, 01:01 PM posted to rec.aviation.soaring
MNLou
Sorry Gents - I disagree.
Buy a Nano. They are relatively cheap, foolproof, fully IGC approved. Set it and forget it.
Plus, when you decide to fly your first contest, you will want a backup recorder anyway. Also, you can tie it into any instrument that needs a GPS engine.
Just my $0.02.
Lou
Old February 22nd 15, 01:03 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I don't think Repolge barographs are accepted any more? Many years ago SSA told us we were the only submitter that year using a Repolge and film..
BillT
The removal of mechanical barographs from the Sporting Code was proposed at last year's FAI/IGC Plenary meeting (Varese, ITA, 7-8 March 2014) as a Year One proposal. It is on the agenda for this year's Plenary (to be held at Lausanne SUI 27-28 February 2015) as a Year Two proposal. IF accepted, it will be incorporated into the Sporting Code this October 1st (end of northern hemisphere season, start of southern hemisphere season). See http://www.fai.org/igc-about-us/igc-meetings ; scroll down to para 8.1.9. Click "Sporting Code Committee Proposals". So, they can currently be used; it is POSSIBLE (perhaps probable) that this will be the last northern hemisphere season where they will be acceptable.
It takes two years for most changes to be made; an initial proposal, questions, comments, requests for change, then a final proposal, vote, and if accepted, the process to incorporate it into the next Sporting Code.
One gotcha; when I went to the fai pages, I initially couldn't find the agenda with links that had this, in the "documents" link where I expected it; it was cleverly hidden in the "about us" link under "meetings". As of this morning, it is in "documents" under "meetings".
If you want a break from shoveling snow, you can click through the links and read each proposal; reports from OSTIV, voting for locations of future World Contests (eg. - 1st PAGC handicaps are mentioned). You can watch, over the years, the progress in the Sporting Code. The changes proposed for this year may mean the SC is 80% the length of the current code, theoretically much simpler, and separates badge flying from records (which as any casual reader of the sporting code knows, greatly complicates and frustrates neophyte badge fliers (and their OOs)). Good, thankless work by the Sporting Code committee.
2D
Old February 22nd 15, 01:08 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Old February 22nd 15, 02:05 PM posted to rec.aviation.soaring
Cookie
I'm not sure what pparts you disagree with? Maybe everything?
As far as Baragraph...I said they can be used...and offer a $0 solution to the OP's problem...But, I do not recommend this as the best solution however, as baragraphs are not user friendly, and pose all kinds of potential problems, like just trying to mount into the glider.
A Nano at over $400 is a good solution, but maybe beyond the budget of a beginning glider pilot...although it is something that will be used well into the future if the pilot stays with the sport. (better than the $1000 Colibri's my club purchased a few years back.)
I think the Fly with CE is a better choice for a beginner, at $150... and it's very user friendly. A couple of new pilots could also chip in to share the cost. Or a club could purchase several..
Cookie
Just my $0.02.
Lou
Old February 22nd 15, 02:31 PM posted to rec.aviation.soaring
Our club members have been snapping up used EW Microrecorders for around $200 each. Four purchased last year. Fully approved, user friendly and price sensible.
Lane
Old February 22nd 15, 02:51 PM posted to rec.aviation.soaring
Bob Pasker
well, I am not getting a barograph. this is 2015, after all
so the low-cost choices seem to be (correct me if I'm wrong):
Fly WithCE (needs windows, but I guess I can install Parallels on my Mac)
EW Microrecorders (looks like a Hayes Modem from 1982)
LXNAV Nano (seems to be my favorite choice right now)
they are all within my price range
can any of these devices act as a high-res GPS source for an iPad running, say, Foreflight or one of the soaring apps, either over bluetooth or USB?
thanks!
Old February 22nd 15, 03:08 PM posted to rec.aviation.soaring
Bob Pasker
looks like their Logbook program installs and runs in Parallels + Windows 10 Technical Preview, but I don't know if it will connect with the device because I don't have one
fly with ce silver badge question Bob Cook[_2_] Soaring 4 August 20th 13 04:37 PM
fly with ce silver badge question Bob Cook[_2_] Soaring 0 August 20th 13 02:47 AM
Silver Badge! [email protected] Soaring 17 November 24th 08 03:12 AM
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
Silver Badge Fun (?) - real challenges? Nyal Williams Soaring 0 July 11th 03 04:45 PM
