Lower Priced ADS-B Out Solution
Old March 22nd 15, 03:11 PM posted to rec.aviation.soaring
Dan Marotta
Default Lower Priced ADS-B Out Solution
Thanks Bill,
PM sent.
On 3/21/2015 8:31 PM, Bill T wrote:
Dan we have the BLM reservation for the 17-18-19 of April. The Pawnee is in Parowan getting the wings recoverd. We are hoping it will be back in time to get us to the lake bed. Hard to move the 2-33 or Grob down there without it. I'll let you know.
It looks like Tonopah will the the 21st to 27th of June.
BillT
Dan Marotta
Old March 22nd 15, 06:32 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Saturday, March 21, 2015 at 5:53:06 AM UTC-7, Bill T wrote:
Thanks Andy, will do. We have an ancient KT Mode C, we'll need to add approved GPS receiver, 1090ES and compatible altitude encoder, plus an ADS-B out box to tie together.
BillT
Hi Bill,
It wasn't totally clear from your post, but to clarify...Modern Mode S transponders should transmit 1090ES Out with the addition for a properly configured GPS. The 'ES' stands for 'Extended Squitter' with appends the GPS information to the Mode S broadcast. Since it operates on the same frequency as Mode C, you should be able to upgrade transponders without changing antenna installation. It seems likely that if you wait, there will be available on the market an integrated Mode S/1090ES Out box with built in GPS, in which case all you'd be able to reuse the Mode C antenna, antenna cable run and power and simply find a spot for the GPS antenna. I'm not sure about the altitude encoder - I think generally access to a static line is the only necessity.
Keeping the old Mode C and adding ADS-B UAT Out entails not only the GPS, but running additional power and (probably) a circuit breaker, one or maybe two additional ADS-B antennas and coax runs, double the inspection and maintenance and in all likelihood more debugging for interoperability. To the extent that the UAT Out has some sort of control head you'll need find a place to mount that too. Lastly you'll have to face the inevitability of being stuck with two systems forever (even after your Mode C finally gives up the ghost). Since Mode S and UAT operate on different frequencies they cannot be combined and will always require separate antennae. If you make the investment in UAT, switching back over to 1090ES Out once your Mode C dies entails also throwing out the relatively newer UAT gear, pulling the antennae, etc. Would be a bit messy and expensive.
Andy, 9B
Old March 22nd 15, 07:48 PM posted to rec.aviation.soaring
Bill T
Thanks Andy.
It would be great if they came up with a 1090ES system with built in GPS reciever, all in one box would be great.
Yes, all of the UAT systems I have seen require their own control head. You can't just program it and forget it.
Not much room on a Pawnee panel.
I had your old LS-4 "9B" out for a spring cleanup and on display at the VGT Open House yesterday. It's ready for the summer season.
BillT
Old March 23rd 15, 02:10 AM posted to rec.aviation.soaring
Dan Marotta
You'll also need power to your encoder if it's a separate box. It has a
heater for the pressure transducer.
BillT
Hi Bill,
Andy, 9B
Dan Marotta
Old March 23rd 15, 05:01 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
BillT
Many happy flights in that ship.
GA Priced Out Of The Market? Larry Dighera Piloting 5 March 22nd 15 07:35 PM
(US) FS: SZD-56-1 Diana, very low time, priced to sell ES Soaring 0 April 15th 14 03:29 AM
UAL Aircraft Tooling For Sale!! Priced well below market!! Scott Pirong Products 0 April 21st 04 02:29 PM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 10:43 PM
Very over priced but very cool parts for our homebuilts Gig Giacona Home Built 0 November 13th 03 07:21 PM
