Hybrid Arcus
Old April 1st 15, 09:33 PM posted to rec.aviation.soaring
son_of_flubber
Default Hybrid Arcus
This approach is cleaner
http://www.youtube.com/watch?v=zpluCYve9qw&t=5m32s
Old April 1st 15, 10:47 PM posted to rec.aviation.soaring
Bill D
OK, with full recognition that it's April 1st, an electric ducted fan has some advantages for self-launch in that ~60 knots is right in the middle of the "sweet spot". It could beat any open prop's thrust/Watt ratio at that speed.
Old April 1st 15, 11:42 PM posted to rec.aviation.soaring
son_of_flubber
I think the best use for this toy would be as a single-use emergency sustainer. It develops 5.5 kg maximum thrust, 12 lbs of thrust... say 10 lbs for hand waving ease.
So an 800 lb gross weight glider with L/D 40:1 requires 20 lbs of thrust to sustain altitude. Add one of these 'toy' engines for 10 lbs of thrust would in turn give the glider an equivalent L/D of 80:1 while the turbo was running. Run it intermittently while flying between thermals. Turn it off and let it cool while you climb in the thermal. Add 2 turbos for redundancy. Run both and you have an intermittent use sustainer. It pushes on the airframe with a force of 10-20 pounds.
Power from Duracells Alkaline batteries. Cheap. High energy density and a long shelf life.
Hybrid Engines?? sisu1a Soaring 16 March 15th 09 12:30 PM
The Best Hybrid Car For You n41beyha Piloting 0 November 27th 07 04:52 PM
bio-diesel hybrid future John T Home Built 9 September 2nd 05 01:22 PM
bio-diesel hybrid future John T Piloting 8 September 2nd 05 01:22 PM
bio-diesel hybrid future Martin Hotze Piloting 0 August 27th 05 01:42 PM
