PowerFLARM Portable Firmware Update: 6.02
Old April 4th 15, 11:28 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default PowerFLARM Portable Firmware Update: 6.02
The power has been off and back on, several times and it still reads Glider.
JJ
Old April 6th 15, 01:40 AM posted to rec.aviation.soaring
On Friday, April 3, 2015 at 10:30:28 AM UTC-4, Paul Remde wrote:
IMPORTANT
PowerFLARM Portable users should update to version 6.02 ASAP. There was a
bug in version 6.00 which caused it to show "Towplane" as the aircraft type
when it should have displayed "glider". That may have caused users to select
the wrong aircraft type. After you upgrade be sure to verify the aircraft
type setting.
http://flarm.com/support/firmware-up...are-version-6/
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
This thread is a bit confusing.
The heading specifically states Portable. Further down the thread there is reference that there is only one firmware for both the core and the portable. So is this updated firmware 6.02 needed for both the core and the portable? Is this issue of thinking it's a tow plane an issue for both the portable and the core? Should everyone thus upgrade from 6.0 to version 6.02? Even if the configuration is showing "glider" not "towplane"?
Old April 6th 15, 04:45 PM posted to rec.aviation.soaring
Paul Remde
Hi,
The upgrade notes state that the major change only applies to the Portable.
The Core doesn't display aircraft type information. The bug in version 6.00
was in the part of the software that affects the way the Portable displays
the aircraft type.
If you change the aircraft type in a Portable which as software version
6.00, it will set the aircraft type incorrectly in the PowerFLARM hardware.
It is setting the integer vale that stores the aircraft type incorrectly.
It then reads it incorrectly too. So, it is important for all PowerFLARM
Portable owners to upgrade to version 6.02 and then verify that the aircraft
type is set correctly.
Best Regards,
Paul Remde
_______________________________
IMPORTANT
type
select
type setting.
Best Regards,
Paul Remde
Old April 6th 15, 04:46 PM posted to rec.aviation.soaring
Paul Remde
Hi JJ,
Yes. You need to upgrade. PowerFLARM Portables with firmware 6.00 set and
read and display the glider type incorrectly.
Best Regards,
Paul Remde
"JJ Sinclair" wrote in message
JJ
Old April 10th 15, 11:14 AM posted to rec.aviation.soaring
RuudH
Will this firmware update also solve the problem with nuisance danger traffic warnings during tow when tow plane is Flarm equipped?
See https://www.youtube.com/watch?v=MindH_4spp0
See text under video
Op vrijdag 3 april 2015 16:30:28 UTC+2 schreef Paul Remde:
IMPORTANT
type setting.
Best Regards,
Paul Remde
Old April 10th 15, 03:13 PM posted to rec.aviation.soaring
jfitch
The release notes say it does.
PowerFLARM firmware v3.00 released (feature complete) FLARM Soaring 42 July 24th 14 09:24 PM
Portable PowerFlarm hardware update kd6veb Soaring 8 March 22nd 13 10:44 PM
Flarm with Firmware 1.20 update Robert Fidler[_3_] Soaring 49 January 31st 12 03:40 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
Garmin GPS496 Firmware Update John Smith Piloting 0 July 23rd 08 02:38 AM
