Jet turbine reliability
Old June 3rd 15, 08:26 AM posted to rec.aviation.soaring
krasw
Default Jet turbine reliability
On Tuesday, 2 June 2015 21:40:56 UTC+3, wrote:
On Tuesday, June 2, 2015 at 7:34:47 AM UTC-7, krasw wrote:
Surely jet engine cannot be more unreliable than Solo two-stroke that you need to dive to start. If it would, you would be lucky to start it even once.
Solos don't need a dive to start. You can start them that way if your starter battery is dead but normally you never need to do this.
I was obviously talking about turbos, which you have to dive to start. There is only handful of turbos with electric starter (for some unimaginable reason).
There on single moving (rotating) part in a turbine. Compare that to shaking two-stroke held together with a bucket of tiewraps.
Old June 3rd 15, 09:05 PM posted to rec.aviation.soaring
Steve Parker[_2_]
Let's hope that that single rotating part has been made and assembled with
the proper controls.
Something rotating at 100,000 rpm about 3 feet from your head had better be
good.
Contained failure would mean bullets being fired at your fin/tailplane.
Uncontained failure and you had better have a good parachute, assuming you
survive the explosion!!
Old June 3rd 15, 09:57 PM
Brett Brett is offline
Member
First recorded activity by AviationBanter: May 2006
No Dan, the TJ42 turbine used in the JS1 Revelation has been developed from scratch specifically for the sailplane market. They have never been used in anything but sailplanes and comprehensive testing has been completed for certification. I have had the privilege of visiting the factory in Northern Germany and was very impressed with the dedicated plant and the professionalism of the staff.
Brett
Old June 3rd 15, 10:04 PM posted to rec.aviation.soaring
Hazard is to the rear engine and its mounted behind you. I remember seeing that some of these also had a containment housing. So, I think they have addressed the issue. But it makes one heck of a pop if they do shed a blade! This will be about the only time a turbine will vibrate as it winds down..
Old June 3rd 15, 10:19 PM posted to rec.aviation.soaring
Alexander Georgas[_2_]
Having flown a land-mower piston engine for quiet a while (ASW-24E) and
now having decided to go for the JS1 jet, I consider this a major step
forward in terms of safety.
Make no mistake, none of these engines is an aircraft engine in the
sense used by airplane pilots. You should always expect that it will
fail to start, or worse, quit at the most inappropriate time every
single time you use it. Not doing so is simply foolhardy.
The difference with the JS1 jet (and I imagine the similar shark
installation) is that if the engine does not start, you are not stuck
with a huge profile in the airstream and a glider that is descending
like a rock. You simply flip a switch and about a minute later you are
either climbing or continuing towards a perfectly normal off-field landing.
This is much closer to the idea people have when they buy into a
self-launcher or turbo, only to discover later that the reality is very
different. It is a great sign of progress that now jet and electric
technology are making this much more of a reality.
On 03/06/2015 04:47, wrote:
They are MODEL engines and are not "man rated" by the FAA. There are several YT vids showing how they are built and assembled. Watch these and then determine if you ever want to put your "skin on the line" using one. By comparison, the Williams FJ-44 is a small TURBOFAN originally built to power US cruise missiles. It had to demonstrate extreme reliability before it was FAA certified and man rated for use on very light business jets. Not to mention it was originally designed to stringent military specs. Bottom line again, these are model TURBOJET engines. Never put your safety/life in a position where their reliability matters.
Old June 4th 15, 01:55 AM posted to rec.aviation.soaring
Dan Marotta
That was Brett that wrote about the FJ-44, not me.
On 6/3/2015 2:57 PM, Brett wrote:
Dan Marotta;904892 Wrote:
That's what I thought.
On 6/2/2015 7:47 PM, wrote:-
reliability matters.-
Dan Marotta
Brett
Dan Marotta
Old June 4th 15, 05:37 AM posted to rec.aviation.soaring
I would expect the QA on these units to be better than that of the typical model turbine. You'll be much less likely to run into a dud here. What is the retail price of this 420N turbine with ECU?
Old June 4th 15, 06:47 AM posted to rec.aviation.soaring
"They are MODEL engines and are not "man rated" by the FAA. There are several YT vids showing how they are built and assembled."
A very inappropriate comparison. It's akin to comparing an experimental aircraft with a certified, high capacity transport category aircraft.
The Williams has undergone destructive testing, blade containment testing, is certified for flight into known icing, use on ground, use in rain etc etc.
Using M&D's engine as an example, it has no accessory gearbox so no lubrication; you add extra oil to the fuel like a 2-stroke. It has no electrical system thus no self-sustaining fuel delivery nor command and control. Both of those functions are powered by the battery so it's essential to leave a battery untouched 'for Justin'. It's not approved for ground operation other than maintenance nor for flight in rain. It's a simple, elegant, low weight, low drag thrust source for sustaining. A 'getcha home jet' with only the operating principle as a similarity with Williams and other certified products. And thanks heavens for that! It would be too large, too heavy and too *EXPENSIVE* otherwise.
CJ
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Turbine Duke or turbine Baron? Montblack Piloting 1 December 13th 05 04:54 PM
Turbine Duke or turbine Baron? [email protected] Piloting 26 December 13th 05 07:50 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 03:27 PM
Reliability of O-300 Captain Wubba Owning 13 March 9th 04 12:17 AM
