Kobo Aura refresh rate?
Old June 23rd 15, 04:09 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Kobo Aura refresh rate?
Nope - battery at 90+ percent. Like I said, the Googlesphere suggests that some versions (maybe early production) of Kobo were prone to washing out and becoming unresponsive in direct sunlight. FWIW, a highly sophisticated heat shield (i.e. a piece of cardboard box taped over the Kobo) seems to have eliminated the problem.
P3
On Tuesday, June 23, 2015 at 10:55:27 AM UTC-4, wrote:
On Sunday, June 21, 2015 at 9:56:42 AM UTC-4, Papa3 wrote:
A somewhat related question - has anyone run into problems with a Kobo (Kobo Mini) washing out in direct sunlight due to overheating? I flew with one for the first time in a club glider earlier this month running TopHat on a Kobo Mini. The Kobo was secured via a suction mount to the canopy. I liked it quite a bit, until the display began to become fainter and fainter. At some point, the touch screen became unresponsive. Luckily, I had a backup copy running on my HTC One which worked fine.
Some Googling suggests that some Kobo Minis may have issues with long periods in direct sunlight. Anyone in the gliding community care to comment?
P3
This might have been a low battery problem rather than a screen heat issue. If the battery is at it's end the Kobo will screen freeze and nothing works after that.
Gary
Old June 26th 15, 10:38 AM posted to rec.aviation.soaring
Hi, for those of you that used Kobo Mini, what GPS do you suggest and how difficult is to connect to Kobo?
Thank you in advance,
Sergio
Old June 27th 15, 08:01 AM posted to rec.aviation.soaring
Johan Pretorius
Sergio I haven't yet had a Kobo to try this on but my best information points to this plan:
.. Run XCSoar on a Kobo. Set it up to receive GPS data by TCP over a wifi link. I've tested this so I know XCSoar can do it.
.. Run an app called BlueNMEA on my Samsung Galaxy S2. This apparently lets you output GPS signal over wifi. I haven't tested this part.
.. Have a portable battery available in the cockpit to charge the S2 (or the Kobo) via usb if it runs out of power... though I'm expecting it to last at least 2 hours because the screen can stay off.
Old June 27th 15, 08:15 AM posted to rec.aviation.soaring
Johan Pretorius
Oh also... I plan to test this on the the ground first as I've had problems in the past with radio interference from setups like this (specifically with the USB charging). If someone who knows about such things can tell us all how best to avoid that problem, I for one would be grateful.
Old June 29th 15, 06:14 PM posted to rec.aviation.soaring
PBA
I'm a diehard Kobo/top hat fan.
If you haven't used an ereader screen in a glider, you are in for a treat.
I just replaced my first kobo (left other in rental car )
and my new (old stock) kobo has the sunlight issue. It's becoming very light during the flight to almost unreadable. This is especially bad with high temperatures. I did not have this problem with my previous kobo so I think this is a QC issue.
I have my kobo wired (soldered) to a colibri II. This is an amazing setup that gives you everything you need from a moving map + IGC approval for badge/comp/record flying. The kobo charges the colibri and the whole unit is charged from a micro USB.
I have noticed the radio inference if I hold this unit close to my Dittel radio, doesn't effect it unless I hold it close though so it's a non issue for the most part.
Old June 29th 15, 06:49 PM posted to rec.aviation.soaring
Papa3[_2_]
If you haven't used an ereader screen in a glider, you are in for a treat..
Glad I wasn't the only one with the sunlight issue. I've built a temporary shade out of black cardboard. I'll test this out a few more times before claiming victory, but it seemed to help a lot in the two flights where I used the prototype version (i.e. the top of a box taped to the mount with wing tape).
Running Top Hat on Kobo mini Ben S Soaring 11 July 21st 15 04:00 PM
Color Kobo Dan Marotta Soaring 3 October 25th 14 11:10 PM
Any experience with aura/optical migraine? Don Tuite Piloting 1 July 6th 07 02:38 AM
Pls refresh, flying clubs at FRG, ISP, HWV, HPN? Michael Robbins Piloting 3 December 13th 06 07:42 PM
Pls refresh, flying clubs at FRG, ISP, HWV, HPN? Michael Robbins Instrument Flight Rules 3 December 13th 06 07:42 PM
