Slider on a ram air parachute
Old June 24th 15, 02:56 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Slider on a ram air parachute
And what is the result of using a round canopy in the high desert. Alan Silver had a good article on whether to use a ram air or round E chute. In the end the round has less potential for problems which could make a bad day even worse.
On Tuesday, June 23, 2015 at 9:08:12 AM UTC-7, Dan Marotta wrote:
I've seen the result of using a round canopy in the high desert.* I
opted for the controllability of a ram air canopy.* It is an
emergency chute with similar opening characteristics to a round
canopy.* If you're interested, here's a link to the manual:* http://www.rigginginnovations.com/fi...AviatorMnl.pdf
On 6/22/2015 2:13 PM, Nick wrote:
On Monday, 22 June 2015 19:31:26 UTC+1, wrote:
Sliders are only removed from ramair parachutes for fixed object jumping or dopey stunts. Any 'already in the air' deployments will be likely be at a speed that causes damage either to equipment or jumper. Jumper first, the gear can take more then most people. You really don't want to use a nonslider equipped ramair parachute over 50 mph or so.
Exactly. However, do you want to use a ram air parachute when it deploys slower than an emergency chute?
Dan Marotta
Old June 23rd 15, 03:52 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Google silver parachute ask Allen. He wrote an article regarding ram vs round emergency chutes. Very informative.
On Monday, June 22, 2015 at 9:59:25 AM UTC-7, Dan Marotta wrote:
Recently somebody made a comment about my emergency ram air
parachute and whether or not it has a slider to to slow deployment.*
I checked with my rigger and jump instructor and here's what he
said:
Your parachute has a slider. The maximum airspeed for slider-off deployments is 65 mph. In an aircraft emergency, you will almost always be deploying at a higher speed than that, so the slider is absolutely necessary. Deploying slider-off at high speed can damage the gear and maybe the jumper.. Your parachute is designed to open as fast as possible without causing damage. It should take about 3 seconds/300 feet for it to open in most situations. Exactly the same as a round parachute of roughly equivalent area.
Dan Marotta
Buy Parachute [email protected] Soaring 4 September 27th 11 01:41 AM
Old Parachute Dan Marotta Soaring 9 March 3rd 11 04:51 PM
FS: Parachute Ed Byars Soaring 0 March 28th 06 11:09 PM
F.S. Parachute Tom Stowers Aviation Marketplace 0 October 1st 04 12:36 AM
**Attention** FS2004 Water Effects Slider is backwards Worrybird Simulators 12 August 13th 03 09:45 PM
