Use of ridge lift for tow - review of procedure/protocol
Old July 2nd 15, 02:50 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Use of ridge lift for tow - review of procedure/protocol
On Thursday, July 2, 2015 at 9:29:26 AM UTC-4, wrote:
"soft release" is a poor practice and not needed. It makes the release of the rope less positive, makes it much harder for the tug pilot to know the glider is off, and in extreme cases can leave enough slack to be a hazard..
Releasing from normal position, without excess tension beyond stable tow, does no harm to properly maintained Schweizer hooks.
Good example of RAS being a prime source for bad practices and misinformation.
UH
Ditto that. I had some guy show up at Blairstown one time for a field check.. At the assigned altitude, I suddenly find us diving at the towplane. I think I only got to "What the f..." before he released, at which point the rope passed within a couple of inches of my eyes in the back seat before pulling away. Seriously? It's a dangerous solution to a non-problem.
P3
Old July 2nd 15, 03:18 PM posted to rec.aviation.soaring
kirk.stant
UH
Ditto that. I had some guy show up at Blairstown one time for a field check. At the assigned altitude, I suddenly find us diving at the towplane. I think I only got to "What the f..." before he released, at which point the rope passed within a couple of inches of my eyes in the back seat before pulling away. Seriously? It's a dangerous solution to a non-problem..
P3
Ditto ditto that! Had a young student on an early solo flight in a 2-33 (used to a heavy IP in the back) try a soft release on a pattern tow and just about kite me into the ground - he got talked to, you can be sure.
And soft releases off a Tost are REALLY stupid!
And while we are venting, "slingshotting" at the top of a tow to get an extra 20 ft of altitude really gets me steamed, too....
Kirk
66
Old July 3rd 15, 01:06 AM posted to rec.aviation.soaring
Bill T
UH , I didn't say it was proper, I said it is what he did.
BillT
Old July 3rd 15, 01:12 AM posted to rec.aviation.soaring
Cookie
See section taken from PTS private glider, below..."normal tension"
We argued about the Schweizer tow hook before here on RAS....It is easy to make the hook such that it doesn't "bang" open...metal on metal...
One of the worst things you can do is "go high" on the tow pilot!
And slack rope is something to be avoided too...
And why all the crazy gyrations, when you have more import concerns during release?
People who try this, and don't do it correctly...really interesting!
I teach my students to be in good, smooth, steady position before release....if your not in good position or stable..don't release until you are!
Cookie
FAA-S-8081-22
1-10
Change 1 (9/1/10)
F. TASK: TOW RELEASE
REFERENCE: Soaring Flight Manual.
Objective.
To determine that the applicant:
1. Exhibits knowledge of the elements related to tow release,
including related safety factors.
2. Maintains high-tow position with normal towline tension.
3. Clears the area before releasing the towline.
4. Releases the towline and confirms release by observing the
tow
line.
5. Makes level or climbing
UH
Ditto that. I had some guy show up at Blairstown one time for a field check. At the assigned altitude, I suddenly find us diving at the towplane.. I think I only got to "What the f..." before he released, at which point the rope passed within a couple of inches of my eyes in the back seat before pulling away. Seriously? It's a dangerous solution to a non-problem.
P3
Kirk
66
Old July 3rd 15, 01:13 AM posted to rec.aviation.soaring
Bill T
Kirk, I had one recently rated pilot try that on me off tow. I saw it happening and I almost turned to the side of his zoom but decided not to make the situation worse.
I though of dropping the rope mid zoom, but did not want to loose two rings and all that new rope. I toughed it out, when he got off I told him on the radio to never do that again. When we were both on the ground I asked him about that maneuver and where he got the idea. He said it was something he read.
I told him we do not teach it, if I knew if him doing it again that would be his last flight at our club.
As for soft releases, when trained and done properly they are a non event.
BillT
Old July 3rd 15, 01:26 AM posted to rec.aviation.soaring
Cookie
When we fly the SE ridge at Blairstown...IF...you know the ridge is working nicely...you only have to be towed to "get there"...height is almost meaningless...1000' or 1200' above the airport, (and below crest) is certainly doable and reasonably safe...although it is 3 miles back into a head wind if you decide to bail...
At Wurtsboro, the ridge is basically also the downwind leg for landing...I've released at 800' above the airport....you either go up in ridge lift, or if you don't, you just go down in the pattern! One day with a student, I got him to (reluctantly) release at 800', at the ridge...we flew straight along the ridge, after 10 miles we were at 3000'...
The craziest ridge tow I ever saw was at Harris Hill....The release was at 5'..
Yes, five feet above the airport!! The glider pilot hung on tow until the speed got up to about 70 or so...then released...flew down the runway..(it starts going down hill) and then off the cliff! Into the ridge lift and gone!
Of course in the old days, just north of Wurtsboro, they bungee launched off the ridge..maybe 2/3 of the way up. Today, at Ellenville, the hang gliders jump off at about the 1/2 way point...there is a good landing field below...so what could possibly go wrong?
Cookie
On Friday, June 26, 2015 at 12:38:57 PM UTC-4, son_of_flubber wrote:
What are the best practices for using ridge lift when towing?
What is different when the ridge altitude is increasing?
Should the tow plane approach the ridge perpendicular at the saddle (rather than at a 45)? What if circumstances force you to release at this point (pointed straight at the ridge, close and below)?
Is it okay to tow below the top of the ridge and utilize slope lift? (With the wind coming from the right or the left?)
Assuming that the wind is coming from the left, is it okay to release, uncrab and drift downwind to clear towplane rather than circling right and ending up low and on the leeward side of the ridge.
If you're above the ridge and the wind is coming from the right, is it okay to release and make the towplane go onto the leeward sink side of the ridge?
Other things to keep in mind?
Old July 3rd 15, 02:18 AM posted to rec.aviation.soaring
son_of_flubber
For the few readers that are unfamiliar with Harris Hill, there is an 'emergency runway' maintained 700 feet below the end of the primary runway.
Nice for PTOT3.
Old July 3rd 15, 02:49 PM posted to rec.aviation.soaring
Bob Pasker
the only place where I have rented that practices soft releases is Estrella, in AZ. Its now on my checklist of "things to keep the check pilot happy," and ever other place wants a standard release. --bob
Old July 3rd 15, 03:32 PM posted to rec.aviation.soaring
So true. After flying with Jason at Estrella I had check rides at two different soaring locations before renting and I used Jason's soft release technique. HEAVILY CRITICIZED by both CFIs for the soft release.
I have used it a couple of times during my private tows and have seen the towplane fly straight ahead for a couple miles before realizing that I was no longer on tow.
Old July 3rd 15, 04:00 PM posted to rec.aviation.soaring
Dan Marotta
A so-called soft release is OK by me if I happen to be looking in the
mirror at the time of release but I will log your release height at the
point where I realize you're gone, not where you claim you got off.
There was an article in Soaring back in the 80s, I believe, which
discussed rope tension during tow. It's not very much for a glass
glider (20 lb) and I wouldn't think more than 40 lb. or so for a drag
master (2-33). There's no harm in releasing at that tension. Why fly a
bunch of maneuvers just to get a little slack before releasing?
Dan Marotta
PowerFLARM protocol 71? kirk.stant Soaring 1 May 10th 15 04:46 PM
Who Knew? (dipping protocol) CupCaked Piloting 0 April 26th 11 04:59 PM
Bizjet protocol JS Soaring 5 September 4th 06 06:29 AM
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
Looking for Ridge Lift/Turbulence Diagram DrJack Soaring 22 November 14th 03 08:49 PM
