At 03:18 04 July 2015, John Carlyle wrote:
Jon, I flew 3 hours today, and my Butterfly vario was happy with all of the mess= ages from my Flarm (v6.03). My messages typically look like LFLA185213GPS 1= 0 45.=20 I'm in PA, so maybe there's something to Matt's GPS jamming theory.=20 -John, Q3 On Friday, July 3, 2015 at 11:26:00 AM UTC-4, jfitch wrote: In the Flarm IGC file there appear to be no skipped Lat Long records arou= nd these messages. Time correlating to the Air Av IGC log, at each of the i= nstances there are no missing fixes.=20 =20 My guess is that it is a Air (Butterfly) vario thing. The Flarm NMEA stre= am must have changed to introduce some new stuff at the 6.0 change, and the= vario is choosing to warn about things that might be better unsaid. But I = was trying to get more info on the PowerFlarm first. If you look at the GPS Altitude trace in SeeYou, this Should go to zero when there are no valid GPS Positions. |
On Saturday, July 4, 2015 at 2:15:06 AM UTC-7, Tim Newport-Peace wrote:
At 03:18 04 July 2015, John Carlyle wrote: Jon, I flew 3 hours today, and my Butterfly vario was happy with all of the mess= ages from my Flarm (v6.03). My messages typically look like LFLA185213GPS 1= 0 45.=20 I'm in PA, so maybe there's something to Matt's GPS jamming theory.=20 -John, Q3 On Friday, July 3, 2015 at 11:26:00 AM UTC-4, jfitch wrote: In the Flarm IGC file there appear to be no skipped Lat Long records arou= nd these messages. Time correlating to the Air Av IGC log, at each of the i= nstances there are no missing fixes.=20 =20 My guess is that it is a Air (Butterfly) vario thing. The Flarm NMEA stre= am must have changed to introduce some new stuff at the 6.0 change, and the= vario is choosing to warn about things that might be better unsaid. But I = was trying to get more info on the PowerFlarm first. If you look at the GPS Altitude trace in SeeYou, this Should go to zero when there are no valid GPS Positions. Yes it does. Pressure altitude is still present, and perfectly tracks the Triadis log. Further dissecting the B records, for those that are bad, the fix is indicated as "V" (2D), fix accuracy as "999", and satellites tracked as "00". The latitude and longitude are repeats of the last valid fix, as required by the IGC spec. The conclusion is that the voice warnings are real, and the PowerFlarm GPS has gone Tango Uniform. The fact that it works in approximately the second half of the flight makes me suspect heat susceptibility (ground temps in the 90's F, vs. 50 at altitude). I will try playing with the antenna location (but it is the same as last year when it worked fine). |
On Thursday, July 2, 2015 at 10:12:49 PM UTC-7, jfitch wrote:
I am getting this bitching Betty alarm every so often. It may do it for a minute or so, then goes away, then comes again. Looking at the Flarm IGC file, there are comment lines that look like this: LFLA213757GPS 7 45 Which I believe represents GPS status (7 satellites?) Then I get some that look like this: LFLA213857GPS 0 0 No satellites? The B field time stamps show a lat and long 4 seconds before and 4 seconds after. In the flight today I got 14 of these and about that many warnings (I didn't count the warnings). This didn't happen last year, started coincident with the 6.0.2 firmware "upgrade". Can anyone shed any light on this? Can't find any spec from Flarm that describes it. I have now written an XL parser for the Flarm IGC file, which counts the instances of dropped fixes. I found no dropped fixes at all from flights in 2013. I found dropped fixes in one flight in 2014, 56 dropped on one particular flight, none in any others. I have now 3 flights in 2015 with the new firmware. 1st flight shows 19 dropped fixes, 2nd flight 373 dropped fixes, 3rd flight 882 (and all fairly short flights too). Not an encouraging trend. The reason I am now aware of it, is that the new Flarm firmware announces bad fixes with the Lxxxxxx GPS 0 0 comment line, and the Air Vario announces it to me with a voice warning. Didn't do that before. |
I had issues right after I upgraded my brick a couple of months ago. Turned out to be a loose GPS cable connection to the brick as the GPS antenna does not screw on just pushes on. I pushed it back on and hasn't had a problem since.
On Saturday, July 4, 2015 at 8:17:08 PM UTC-7, wrote:
I had issues right after I upgraded my brick a couple of months ago. Turned out to be a loose GPS cable connection to the brick as the GPS antenna does not screw on just pushes on. I pushed it back on and hasn't had a problem since. I tried pulling and reseating the connector. I wonder if a more efficient antenna would work better on the Flarm. Is anyone using a larger patch antenna with it? |
At 00:31 05 July 2015, jfitch wrote:
On Thursday, July 2, 2015 at 10:12:49 PM UTC-7, jfitch wrote: I am getting this bitching Betty alarm every so often. It may do it for a= minute or so, then goes away, then comes again.=20 =20 Looking at the Flarm IGC file, there are comment lines that look like thi= s: =20 LFLA213757GPS 7 45=20 =20 Which I believe represents GPS status (7 satellites?) =20 Then I get some that look like this: =20 LFLA213857GPS 0 0 =20 No satellites? The B field time stamps show a lat and long 4 seconds befo= re and 4 seconds after. In the flight today I got 14 of these and about tha= t many warnings (I didn't count the warnings).=20 =20 This didn't happen last year, started coincident with the 6.0.2 firmware = "upgrade".=20 =20 Can anyone shed any light on this? Can't find any spec from Flarm that de= scribes it. I have now written an XL parser for the Flarm IGC file, which counts the in= stances of dropped fixes. I found no dropped fixes at all from flights in 2= 013. I found dropped fixes in one flight in 2014, 56 dropped on one particu= lar flight, none in any others. I have now 3 flights in 2015 with the new f= irmware. 1st flight shows 19 dropped fixes, 2nd flight 373 dropped fixes, 3= rd flight 882 (and all fairly short flights too). Not an encouraging trend.= =20 The reason I am now aware of it, is that the new Flarm firmware announces b= ad fixes with the Lxxxxxx GPS 0 0 comment line, and the Air Vario announces= it to me with a voice warning. Didn't do that before. Not beyond the bounds of possibility that reporting No GPS in the L-record is a new feature Introduced with Version 6? |
On Sunday, July 5, 2015 at 10:00:07 AM UTC-7, Tim Newport-Peace wrote:
At 00:31 05 July 2015, jfitch wrote: On Thursday, July 2, 2015 at 10:12:49 PM UTC-7, jfitch wrote: I am getting this bitching Betty alarm every so often. It may do it for a= minute or so, then goes away, then comes again.=20 =20 Looking at the Flarm IGC file, there are comment lines that look like thi= s: =20 LFLA213757GPS 7 45=20 =20 Which I believe represents GPS status (7 satellites?) =20 Then I get some that look like this: =20 LFLA213857GPS 0 0 =20 No satellites? The B field time stamps show a lat and long 4 seconds befo= re and 4 seconds after. In the flight today I got 14 of these and about tha= t many warnings (I didn't count the warnings).=20 =20 This didn't happen last year, started coincident with the 6.0.2 firmware = "upgrade".=20 =20 Can anyone shed any light on this? Can't find any spec from Flarm that de= scribes it. I have now written an XL parser for the Flarm IGC file, which counts the in= stances of dropped fixes. I found no dropped fixes at all from flights in 2= 013. I found dropped fixes in one flight in 2014, 56 dropped on one particu= lar flight, none in any others. I have now 3 flights in 2015 with the new f= irmware. 1st flight shows 19 dropped fixes, 2nd flight 373 dropped fixes, 3= rd flight 882 (and all fairly short flights too). Not an encouraging trend.= =20 The reason I am now aware of it, is that the new Flarm firmware announces b= ad fixes with the Lxxxxxx GPS 0 0 comment line, and the Air Vario announces= it to me with a voice warning. Didn't do that before. Not beyond the bounds of possibility that reporting No GPS in the L-record is a new feature Introduced with Version 6? As I said, this was introduced in V6. The same information was available in the B record in prior versions, but you had to dig for it a bit more. Of course the Vario is not looking at the IGC file, only the serial stream, which I do not have the equipment to directly capture, so I do not know what changes where made to it, and what changes to the interpretation. |
At 05:54 06 July 2015, jfitch wrote:
On Sunday, July 5, 2015 at 10:00:07 AM UTC-7, Tim Newport-Peace wrote: At 00:31 05 July 2015, jfitch wrote: On Thursday, July 2, 2015 at 10:12:49 PM UTC-7, jfitch wrote: I am getting this bitching Betty alarm every so often. It may do it fo= r a=3D minute or so, then goes away, then comes again.=3D20 =3D20 Looking at the Flarm IGC file, there are comment lines that look like thi=3D s: =3D20 LFLA213757GPS 7 45=3D20 =3D20 Which I believe represents GPS status (7 satellites?) =3D20 Then I get some that look like this: =3D20 LFLA213857GPS 0 0 =3D20 No satellites? The B field time stamps show a lat and long 4 seconds befo=3D re and 4 seconds after. In the flight today I got 14 of these and about tha=3D t many warnings (I didn't count the warnings).=3D20 =3D20 This didn't happen last year, started coincident with the 6.0.2 firmware =3D "upgrade".=3D20 =3D20 Can anyone shed any light on this? Can't find any spec from Flarm that de=3D scribes it. I have now written an XL parser for the Flarm IGC file, which counts the in=3D stances of dropped fixes. I found no dropped fixes at all from flights i= n 2=3D 013. I found dropped fixes in one flight in 2014, 56 dropped on one particu=3D lar flight, none in any others. I have now 3 flights in 2015 with the ne= w f=3D irmware. 1st flight shows 19 dropped fixes, 2nd flight 373 dropped fixes= , 3=3D rd flight 882 (and all fairly short flights too). Not an encouraging trend.=3D =3D20 The reason I am now aware of it, is that the new Flarm firmware announce= s b=3D ad fixes with the Lxxxxxx GPS 0 0 comment line, and the Air Vario announces=3D it to me with a voice warning. Didn't do that before. Not beyond the bounds of possibility that reporting No GPS in the L-recor= d is a new feature Introduced with Version 6? As I said, this was introduced in V6. The same information was available in= the B record in prior versions, but you had to dig for it a bit more. Of c= ourse the Vario is not looking at the IGC file, only the serial stream, whi= ch I do not have the equipment to directly capture, so I do not know what c= hanges where made to it, and what changes to the interpretation. Have you looked at the .IGC records that begin with "F"? These contain firstly the time, followed by pairs of characters which give the satellite ID? These records should occur at leats every five minutes. |
On Sunday, July 5, 2015 at 11:45:06 PM UTC-7, Tim Newport-Peace wrote:
At 05:54 06 July 2015, jfitch wrote: On Sunday, July 5, 2015 at 10:00:07 AM UTC-7, Tim Newport-Peace wrote: At 00:31 05 July 2015, jfitch wrote: On Thursday, July 2, 2015 at 10:12:49 PM UTC-7, jfitch wrote: I am getting this bitching Betty alarm every so often. It may do it fo= r a=3D minute or so, then goes away, then comes again.=3D20 =3D20 Looking at the Flarm IGC file, there are comment lines that look like thi=3D s: =3D20 LFLA213757GPS 7 45=3D20 =3D20 Which I believe represents GPS status (7 satellites?) =3D20 Then I get some that look like this: =3D20 LFLA213857GPS 0 0 =3D20 No satellites? The B field time stamps show a lat and long 4 seconds befo=3D re and 4 seconds after. In the flight today I got 14 of these and about tha=3D t many warnings (I didn't count the warnings).=3D20 =3D20 This didn't happen last year, started coincident with the 6.0.2 firmware =3D "upgrade".=3D20 =3D20 Can anyone shed any light on this? Can't find any spec from Flarm that de=3D scribes it. I have now written an XL parser for the Flarm IGC file, which counts the in=3D stances of dropped fixes. I found no dropped fixes at all from flights i= n 2=3D 013. I found dropped fixes in one flight in 2014, 56 dropped on one particu=3D lar flight, none in any others. I have now 3 flights in 2015 with the ne= w f=3D irmware. 1st flight shows 19 dropped fixes, 2nd flight 373 dropped fixes= , 3=3D rd flight 882 (and all fairly short flights too). Not an encouraging trend.=3D =3D20 The reason I am now aware of it, is that the new Flarm firmware announce= s b=3D ad fixes with the Lxxxxxx GPS 0 0 comment line, and the Air Vario announces=3D it to me with a voice warning. Didn't do that before. Not beyond the bounds of possibility that reporting No GPS in the L-recor= d is a new feature Introduced with Version 6? As I said, this was introduced in V6. The same information was available in= the B record in prior versions, but you had to dig for it a bit more. Of c= ourse the Vario is not looking at the IGC file, only the serial stream, whi= ch I do not have the equipment to directly capture, so I do not know what c= hanges where made to it, and what changes to the interpretation. Have you looked at the .IGC records that begin with "F"? These contain firstly the time, followed by pairs of characters which give the satellite ID? These records should occur at leats every five minutes. I have looked at them, they are unremarkable. They do not appear near the dropped fixes. The IGC spec requires them only every 5 minutes or when the constellation changes. |
Flarm IGC files on non-IGC certified Flarm? | Movses | Soaring | 21 | March 16th 15 09:59 PM |
Experience with Flarm "Stealth" and Competition modes | Evan Ludeman[_4_] | Soaring | 39 | May 30th 13 08:06 PM |
FLARM for SAR | FLARM | Soaring | 57 | November 21st 12 07:21 PM |
IGC FLARM DLL | [email protected] | Soaring | 1 | March 25th 08 11:27 AM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
