water ballast
Old July 14th 15, 07:35 PM posted to rec.aviation.soaring
Alexander Georgas[_2_]
Default water ballast
The only time head or tail-wind affects inter-thermal speed or the need for
ballast is when the glide is to a fixed point on the ground, either a turn
point to be rounded before the next thermal is taken or a final glide to
landing.
....or when thermals are linked to ground features, such as when flying
above mountains which create energy lines
Old July 14th 15, 09:13 PM posted to rec.aviation.soaring
Jim White[_3_]
At 14:49 14 July 2015, Chris Rollings wrote:
Some of the confusion is caused by the fact that (at least some years ago
maybe not now, I don't know) the FAA written (on line) exam for a glide
pilot certificate required one to give the factually wrong answer to
question about inter-thermal speeds into and down-wind, in order to get
th
mark for the question. You had to answer that it was correct to fly
faste
between thermals when going into wind than when going down wind. This i
nonsense, but drawing the mistake to the attention of an FAA Inspector
onl
got his agreement and regret that he could do nothing about it.
fo
landing.
Chris, you should perhaps read Brigliadori's Competing in Gliders. They
make a pretty convincing argument for flying a bit faster into wind between
thermals. Its in the appendices.
Old July 15th 15, 01:00 AM posted to rec.aviation.soaring
Brad[_2_]
so, I gotta ask....wonder what the public is going to think if/when they find out a bunch of guys in their expensive racing sailplanes fill them up with water just so they can fly faster,and then dump it out over the desert.
Brad
GK
Old July 15th 15, 02:17 AM posted to rec.aviation.soaring
Paul Agnew
Just tell them it's chemtrails.
Old July 15th 15, 03:11 AM posted to rec.aviation.soaring
Dan Marotta
Is that the same public that gets it panties in a bunch at the mere
thought of an SUV?
Brad
GK
Dan Marotta
Old July 15th 15, 01:43 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
desert.
Much the same as their reaction when they find out that Formula 1 racing
cars have a wooden plank strapped to the underside[*].
[*] actually its Jabroc, not just a simple lump of dead tree.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Water Ballast Tripod [email protected] Soaring 3 July 31st 12 05:43 PM
DG-300 Water Ballast Bags noel.wade Soaring 7 February 18th 10 02:39 AM
Winter Water Ballast Scott Alexander[_2_] Soaring 14 November 27th 09 03:11 AM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
