Libelle 201 query
Old January 30th 16, 03:13 AM posted to rec.aviation.soaring
JS
Default Libelle 201 query
Frank, to get the excitement up have a look at these H201 Libelle flights by my friend Bob Dircks at Lake Keepit. One was just shy of 1000 points on OLC.
In 2013 when I finally completed a declared 1000k, my second favourite flight of the year was a 500k triangle in the 201B.
http://www.onlinecontest.org/olc-2.0...t=olc&pi=47926
On Friday, January 29, 2016 at 5:43:05 PM UTC-8, Ommadawn wrote:
I'm in Adelaide South Australia.
Cheers
Frank.
Ommadawn
Old January 30th 16, 01:19 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Fri, 29 Jan 2016 22:26:44 +0000, Ommadawn wrote:
I have a significant history of hang gliding, RC model soaring and FPV
piloting.
How will you be launching your Libelle?
I ask because its *essential* that you get properly briefed by a current
Libelle pilot before you winch it. You may also find these notes useful:
http://www.gregorie.org/gliding/libelle/h201_notes.html
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 1st 16, 05:26 AM posted to rec.aviation.soaring
Nick Gilbert
Hi Frank,
There are several Standard Libelles in South Australia, including a few at Gawler, and at least one at Stonefield. I'm sure the owners of these gliders would have been more than happy for you to have a sit in one to see how you fit. I am guessing you are likely at Balaklava.
For what it's worth, I'm 6 foot 3 & quite meaty, and I flew a Libelle for many years. If anything, the biggest issue was related to my feet rather than the size of the cockpit. Some people find them to be quite narrow across the shoulders as the cockpit walls taper inwards at the top, but deceptively long.
My Libelle was a combination of 2 - early production wings combined with late production fuselage. My wings were balsa core and had upper & lower surface brakes. I don't believe the switch to foam core was intended to modernise the glider, more to solve a material sourcing problem.
Jim, for what it's worth, mine was the first of 2 libelles that Bob Dircks owned, VH-GAK.
A 1973 build Libelle is likely to have foam core, the thicker & rounder tailplane, and top surface airbrakes only. Come to think of it, considering the fact that i'm an avid reader of gliding classified sites, and Libelles, I am fairly sure I know the one you are talking about. Considering it's serial number is in the late 450's I am certain it is as described above.
Cheers,
Nick Gilbert
Mosquito VH-GSG
On Saturday, 30 January 2016 12:13:05 UTC+10:30, Ommadawn wrote:
Thanks for the comprehensive feedback chaps.
I cant actually try out the glider as it is 2300Km away.
I will be making an epic road trip to check her out.
I will fit, as I'm not really big, but my buddy was the one I was
concerned about. He is about 6"1 and 100Kg.
Sounds like it won't be an issue for him.
If she checks out ok I will be hauling her home.
I hope to become a regular contributor to this forum, even if its just
to ask dumb newbie type questions, as this will be my first private
sailplane.
piloting.
Cheers
Frank.
Ommadawn
Old January 31st 16, 04:39 PM posted to rec.aviation.soaring
JS
On Tuesday, January 26, 2016 at 5:43:03 AM UTC-8, Ommadawn wrote:
I guess what Im mostly concerned with is how big can a guy be and still
fit into the Libelle cockpit. Would 6'2" be too tall?
Ommadawn
Frank, Tom Gilbert would be a good source of information like the change from balsa. Was it with the "B" version?
Colibri II query waremark Soaring 11 October 19th 12 02:45 AM
Query on Geo Pilot GPS Mike Isaksen Piloting 7 August 8th 07 02:38 AM
Query on the Woodstock Stealth Pilot Soaring 3 July 25th 06 08:02 PM
A query news Military Aviation 2 October 18th 03 04:27 PM
Moving map query Martin Gregorie Soaring 7 September 8th 03 05:26 PM
