Power Flarm Display
Old March 22nd 16, 10:13 PM posted to rec.aviation.soaring
jfitch
Default Power Flarm Display
On Tuesday, March 22, 2016 at 8:41:17 AM UTC-7, JS wrote:
On Tuesday, March 22, 2016 at 8:16:48 AM UTC-7, jfitch wrote:
On Monday, March 21, 2016 at 9:04:28 PM UTC-7, K m wrote:
Readers,
Was wondering what pilots are doing for Flarm displays. Ive used an LXNav Flarm View for years but with the upgrades to SYM it seems a dedicated screen is redundant. I am in the process of off season maintenance and will probably ditch the Flarm View display unless I can figure out what it does that See You Mobile does not.
Don't want to turn this into an argument about how safety and modern technology makes for bad pilots. Ive noticed many people running SYM opt to not install a separate display. Whats the logic behind this.
Thanks
I have a Power Flarm and no dedicated display. Any warnings are called out in loud, clear voice warnings by the Butterfly Vario, and also shown on iGlide. Traffic that is not a collision threat is always shown on the iGlide screen. I don't see what a dedicated display would add. I would worry a bit if the only warnings were voice warnings from a tiny little PDA speaker.. The voice warnings are the best part of the system.
Jon, does the Butterfly give you Mode C transponder warnings?
Last I heard it didn't, because Mode C is history in Europe.
I've tried it, but never saw any Mode C warnings so disconnected a while ago.
Using LX FlarmView57 and ClearNav 2 for displays, much as others have commented.
I like the CN audible warnings, try not to look at any display.
I don't believe it does give an audible warning. They appear on the vario radar screen as a received signal if you have it viewable. I don' think I have seen a Mode C target on iGlide. The warnings from the Vario are "Glider, 12 o'clock, high" for Flarm target or "Aircraft, 3 o'clock, low" for ADS-B target. On iGlide they will show as a red triangle radiating out the direction of the threat. Not sure you can extend that to Mode C - "Aircraft, somewhere in vicinity, unknown altitude and distance?" is kind of vague. Mode C is pretty dodgy as a collision avoidance tool.
Old March 23rd 16, 02:26 PM posted to rec.aviation.soaring
kirk.stant
On Tuesday, March 22, 2016 at 5:15:11 PM UTC-5, George Haeh wrote:
My Butterfly showed me a tight Mode C
ring that turned out to be a Cardinal
coming up my 6 from an airport several
miles East.
When I spotted the ring I began looking
and rocking my wings.
I'm not sure whether SYM displays xpdr
and ADS-B. I definitely see them on the
Butterfly.
SYM does shows ADS-B (jet symbol at target position) and xpdr "range" (circle around own position). Good backup for the Butterfly display, which I like as its up higher in my crosscheck and dedicated to Flarm.
Old March 23rd 16, 03:13 PM posted to rec.aviation.soaring
jfitch
miles East.
Butterfly.
Need to be specific: Butterfly Flarm display or Butterfly Vario display?
Old March 23rd 16, 05:59 PM posted to rec.aviation.soaring
George Haeh
Butterfly Flarm Display
miles East.
Butterfly.
Old March 23rd 16, 06:43 PM posted to rec.aviation.soaring
George Haeh
miles East.
Butterfly.
Power Flarm [email protected] Soaring 3 May 25th 14 11:03 PM
Power flarm [email protected] Soaring 10 March 24th 14 02:31 AM
Power Flarm Display SteveB_Z5 Soaring 64 March 25th 13 08:17 PM
Power FLARM power Andy[_1_] Soaring 9 June 6th 12 12:38 AM
Power FLARM question Kimmo Hytoenen Soaring 26 March 23rd 12 04:28 AM
