Asw19 rudder bolt (evil)
Old March 25th 16, 11:23 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Default Asw19 rudder bolt (evil)
You need to first align the holes in the rudder and its bracket. Find a long rod the diameter of the 10mm bolt and insert that part way from the bottom. Then use forceps to push the bolt down.
Old March 25th 16, 01:27 PM posted to rec.aviation.soaring
John,
What you need are a pair of extended reach glidernutboltistats. I recommend buying 2. One to keep at the airport and one at home. Here is a link to a picture.
http://daziv.com/gliderdolly/tool.jpg
Since you live in Houston, the easiest thing is to go over to EPO (Electronic Parts Outlet) on Fondren. The specialty glider tool section is over on isle 7 just past the flux capacitors. Everything in that section is made from Pakistan stainless. I think the item shown was under $20 (even though it's worth $200 for a -19 rudder project).
Mark
Old March 25th 16, 03:49 PM posted to rec.aviation.soaring
JS
On Friday, March 25, 2016 at 6:27:45 AM UTC-7, wrote:
John,
Mark
Excellent, Mark!
Unsure of Pakistani stainless steel, even after working near the Pakistan Steel works E of Karachi. Did try to buy a hat made in Pakistan, but the fellow in the shop said "let me get you a better hat". It was made in China.
So even a glider pilot may want to upgrade to the Chinese glidernutboltistats at the far end of aisle 7, bottom left.
Old March 25th 16, 04:53 PM posted to rec.aviation.soaring
Papa3[_2_]
Since we're drifting already anyway... the next level of hell is trying to remove the rudder from a Grob Twin Astir that's been stored outside. Cursing in 6 languages, ruptured blood vessels, gallons of penetrating oil, and entreaties to various deities didn't do it. All I remember is that we eventually ended custom-manufacturing what amounts to a bearing puller. Luckily, we have the world's best machinist in the club.
ASW19 Inner Tube [email protected] Soaring 1 September 21st 15 03:54 PM
asw19 airbrake kit steve[_2_] Soaring 2 April 7th 11 08:32 PM
Asw19 Winglets for sale Gregg Leslie Soaring 0 November 21st 06 02:31 PM
ASW19 performance mods Jim Crowhurst Soaring 2 June 3rd 05 12:18 PM
