Pribina Cup 2016 - Slovakia - Mid-Air?
Old April 4th 16, 03:02 AM posted to rec.aviation.soaring
Renny[_2_]
Default Pribina Cup 2016 - Slovakia - Mid-Air?
Amazingly on the local news in Albuquerque, NM there was a report on a glider mid-air in Slovakia on April 2 at the Pribina Cup. On the contest website there was a mention of an "incident" and that all tasks were cancelled yesterday. It also said that all pilots were OK....which is really great news!
Now, the TV report indicated that at least one pilot bailed out successfully and showed a glider that crashed on top of a house....A web search revealed very little info, so does anyone "out there" have any information on this "incident?"
Thx - Renny
Old April 4th 16, 12:46 PM posted to rec.aviation.soaring
Wojciech Scigala
Renny pisze:
Mid-air, one glider landed back on the airfield, second one - you know
the story. Not much more to be told even by people who were there.
It's typical for "publicity" of competition accidents to be zero.
Organizers' reasons are obvious, but on the other hand pretending
"nothing happened" doesn't make gliding community look serious.
Wojciech
Old April 4th 16, 02:52 PM posted to rec.aviation.soaring
Renny[_2_]
On Monday, April 4, 2016 at 5:46:12 AM UTC-6, Wojciech Scigala wrote:
Renny pisze:
Wojciech
Wojciech,
Thank you for the information. Hopefully, we will learn more in time. I did receive this URL with some photos:
http://nasanitra.sme.sk/c/20129950/l...e.html?ref=trz
Thanks again - Renny
Old April 4th 16, 03:46 PM posted to rec.aviation.soaring
Frank Whiteley
Renny pisze:
Wojciech
Wojciech,
Another link, in English that helps with the Google translate of the above link. Less pictures.
http://spectator.sme.sk/c/20130833/t...-of-house.html
Frank Whiteley
Old April 7th 16, 09:38 AM posted to rec.aviation.soaring
krasw
Wojciech
Maybe it would be a good time to look at the mirror. Why is it that pilots from certain Eastern European countries find themselves in these midairs so often? It's out of any proportions, internationally. Competition culture is just plain dangerous. This is constantly proven by stream of accident reports, most remarkable example was Jantar Cup 2014 at Pila (two collisions, three parachute saves and one fatality).
Old April 7th 16, 04:04 PM posted to rec.aviation.soaring
Wojciech Scigala
krasw pisze:
Maybe the reason is the volume of competitions there? More flights =
more accidents. Mid-airs happen all over the world, without any hard
numbers comparing number of flights with number of collisions it's
impossible to judge if the reason is really behind "geopolitics". What's
more, low numbers of accidents assures high noise level. To make it even
worse, practice of sweeping accidents under the PR carpet leaves those
numbers only to official boards, so all we have are speculations and gut
feelings.
It would be great if one can give the main reason for mid-airs. Be it
lack of lookout, cockpit design, too much or too less electronics,
nationality, hours flown, sex, competition rules, etc... The issue is
complex and any simple diagnosis won't help anyone. If one says that
pilots from particular group are dangerous, those accused will just deny
that (even if proven by dry facts, it will be mentally rejected and take
long to be absorbed) - others will think "problem found, does not apply
to me". No easy solutions here.
Yes, this might be true that some countries share same deep-dug reasons,
be it law, weather, glider types or more vague ones like history,
culture, mentality etc. Finding them out (not guessing) will be great
starting point for discussion and hopefully improvements.
Right now we're only guessing. And even if guess is right, it won't help
unless we have some identified area to work with.
Regards,
Wojciech
Old April 7th 16, 05:30 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Wonder if the aircraft were Flarm equipped ?
Old April 7th 16, 06:58 PM posted to rec.aviation.soaring
krasw
These accidents usually happen at pre start gaggles with dozens of gliders in same thermals. Flarm is useless there. Only thing that help is disciple and safety-oriented attitude, which these kamikaze pilots lack.
Old April 8th 16, 06:52 AM posted to rec.aviation.soaring
Surge
Sex in the cockpit or the lack of sex?
Would gender actually be a contributing factor?
Registration open for SGP USA 2016 (July 24-31 2016) Sean Fidler Soaring 22 May 22nd 16 02:19 PM
Slovakia 2010 WGC Standard Class results? [email protected] Soaring 3 May 29th 12 12:06 PM
Flying in Slovakia RRK Soaring 1 June 5th 09 08:20 PM
pribina results bagmaker Soaring 0 April 14th 07 01:13 AM
Pribina Cup rules Tuno Soaring 5 April 10th 07 03:03 AM
