Do L'Hotellier Ball Fittings Wear?
Old April 13th 16, 03:56 PM posted to rec.aviation.soaring
Casey[_2_]
Default Do L'Hotellier Ball Fittings Wear?
L'Hotellier web site has little info. An email to them and I was sent the maintenance Instruction.
https://www.dropbox.com/s/ii53drru82...01-00.pdf?dl=0
Casey
Old April 13th 16, 04:18 PM posted to rec.aviation.soaring
I use spray lube to annual time. Work the sliding cylinder with something soft (like a brass key) and drown it with lube as you work it several times, until everything works easily, then wipe off excess spray and she's good to go for another year.
JJ
Old April 13th 16, 04:57 PM posted to rec.aviation.soaring
JS
The Gliding Federation of Australia requires that L'Hotellier balls be replaced at some specified interval. They had to be replaced on my N3 when it was registered there. Tried to look up the GFA AD for details but their search engine doesn't find it.
The ball is inexpensive. If you need to replace the other part.... Not so.
It's a miniature trailer ball. Have a look at the trailer hitches on a few vehicles to see if they wear.
Old April 13th 16, 07:13 PM posted to rec.aviation.soaring
Eric Munk
when
their
so.
few
The interval recommended by L'Hotellier (and taken over by several national
authorities as mandatory) is ten years or 3000 hours (whichever comes
first). Most manufacturers of aircraft who use L'Hotellier balls have
specified their replacement during the 3,000 and 6,000 hours and so
intervals. IIRC Schempp-Hirth has closer intervals (500 hours?) due to them
being fitted in a different way and they have had threaded ends fail.
Old April 13th 16, 08:20 PM posted to rec.aviation.soaring
PGS
On Wednesday, April 13, 2016 at 9:06:58 AM UTC-4, Casey wrote:
Thanks for the comments.
I'm wonder what the dimensions of the balls are new.
My aileron balls on both wings are 0.02 mm smaller than the spoiler balls on both wings. Dimensions are same on each wing.
What is best lubricant? Thicker grease or thiner spray? I know the pro and cons of each but just wonder others thoughts.
Casey
I would not be surprised if 0.02mm was within the original manufacturing tolerances. Certainly a long way from the 0.1mm out of round tolerance that someone else mentioned.
Old April 13th 16, 09:47 PM posted to rec.aviation.soaring
Casey[_2_]
Erik,
Where do see that L'Hotellier recommends ten yrs or 3000 hrs? Also my glider manufacturer has no mention of this in the life extensions.
I emailed them this morning and all they sent me was the maintenance instruction and there is no mention in that of this recommendation.
Old April 13th 16, 09:53 PM posted to rec.aviation.soaring
Casey[_2_]
Casey
pgs.
The balls are not out of round, just different between spoiler and aileron. But now I'm thinking these balls are of different diameter to begin with, a closer look, the stem to the ball is longer on those that are the 0.02 smaller.
Casey
Old April 13th 16, 10:10 PM posted to rec.aviation.soaring
Casey[_2_]
Eric,
Where do see that L'Hotellier recommends replacement at ten yrs or 3000 hrs? Also my glider manufacturer has no mention of this in the life extensions. But does mention that maintenance must be done at each annual or 500 hrs for spherical.
I emailed L'Hotellier this morning and all they sent me was the maintenance instruction and there is no mention in that of the replacement recommendation.
Casey
Old April 13th 16, 10:16 PM posted to rec.aviation.soaring
Bruce Hoult
On Thursday, April 14, 2016 at 8:53:54 AM UTC+12, Casey wrote:
Casey
pgs.
Casey
Are the size differences large enough to prevent a control surface being connected to the wrong control lever? (assuming such a thing was geometrically possible)
Old April 13th 16, 10:29 PM posted to rec.aviation.soaring
Casey[_2_]
Casey
pgs.
Casey
Bruce,
Not possible. But the spoiler ball has a longer neck and is designed that way.
Casey
Source of L'Hotellier Fittings? Six-Seven Romeo Soaring 2 September 1st 15 05:33 PM
Brass Compression Fittings,Fittings for Pex-Al-Pex Sale on good price valvetom Piloting 0 November 27th 06 05:58 PM
L'Hotellier [email protected] Soaring 5 September 9th 05 04:21 PM
wanted L'Hotellier ball fitting assembly Udo Rumpf Soaring 3 January 7th 05 03:05 AM
Hotellier connections Mike Soaring 38 September 28th 04 04:30 PM
