1-26 1000K Attempt In Progress
Old April 19th 16, 01:25 PM posted to rec.aviation.soaring
Papa3[_2_]
Default 1-26 1000K Attempt In Progress
Ron Schwartz got off tow a little before 7 a.m. after a launch from Blairstown. He has a declared 1000K 3 turnpoint in the box. While the synoptic picture isn't classic, it seems to be working. Local winds picked up shortly after sunrise and reporting stations along the route are currently starting to swing around to the northwest. Karl Striedieck reports solid winds at Eagle Field, which is about the midpoint of the task area. Ron buys some time by getting his first lap in on the local ridge before heading south across the Susquehanna and Potomac rivers later in the day. If you listen carefully, you can hear the oil canning even now...
P3
18yr old flies 1000k Ventus_a Soaring 8 December 15th 10 08:23 PM
How much water for a 1000K attempt? ttaylor at cc.usu.edu Soaring 16 August 11th 05 11:07 AM
1000k comp task Mel Dawson Soaring 0 July 5th 05 08:22 PM
Youngest 1000k...? Luke Roberts Soaring 4 March 26th 05 03:12 AM
1000K Questions Brian Iten Soaring 7 April 29th 04 02:05 PM
