LS3a vs Pegasus
Old April 28th 16, 04:18 AM posted to rec.aviation.soaring
IA DPE
Default LS3a vs Pegasus
I really wanted a Pegase, but I weigh 225 lbs, and best as I can tell by the POH, max pilot weight of a 101 is 185. This is max weight of non lifting surfaces minus empty weight.
If someone can show me different I'll certainly listen!
Old April 28th 16, 01:20 PM posted to rec.aviation.soaring
gkemp
Never weighed under 245 lbs, put in a tail tank and flew it for years including 1000K
gary kemp
Old April 28th 16, 01:21 PM posted to rec.aviation.soaring
gkemp
Never weighed under 245, put in a tail tank and flew it for years including my 1000K
gary kemp
Old April 28th 16, 01:23 PM posted to rec.aviation.soaring
I just looked at a digital copy of a manual and it listed max load at 260 lbs. Where did you get the 185 number?
Old April 28th 16, 01:36 PM posted to rec.aviation.soaring
Eric Munk
This varies per aircraft. Depends on the actual empty weight of non-lifting
components (fuselage, stabilizer), and therefore damage history and
equipment fitted. I have two in maintenance with a 225+ lbs max weight (227
and 231). 242 (and a bit) is maximum load per design specifications
(seatbelts and attachment) if max non-lifting is not reached before that.
Old April 30th 16, 01:37 PM posted to rec.aviation.soaring
On Tuesday, April 26, 2016 at 4:51:47 PM UTC-4, wrote:
Let me know if your going to sell your 15, I would be interested in it if you put her up for sale.
Dan
I noticed your interest in an ASW-15B. Mine is for sale and is posted on Wings & Wheels. Jack
Wanted: LS3A or LS3A-17 (USA) Uniform Zulu Soaring 1 November 21st 07 07:36 PM
LS3A performance Rob Dunning Soaring 7 July 7th 07 03:38 PM
FS - LS3a Simon Waddell Soaring 0 January 17th 04 04:05 PM
OPINIONS ON AN LS3A Gordon Schubert Soaring 6 November 14th 03 10:41 AM
Drag of LS3 compared LS3a. Peter Warburton Soaring 0 August 18th 03 06:59 AM
