#11
![]() anyone had any experience with the EW looger. It's about half the price of the others. __Mike They are OK if you operate them correctly ... as the internal battery can run flat very quickly. The don't have any ENL recording so are not suitable in Turbos/Self Launchers. I use an EW B model in my self launcher and its easy. The EW has leads for a motor contact switch that you can hook up. The internal battery lasts plenty long unless you set a rediculously short data point interval. -- Peter D. Brown http://home.gci.net/~pdb/ http://groups.yahoo.com/group/akmtnsoaring/ |
Tim Newport-Peace ]s comments read:
X-no-archive: yes In article , Tim tim_spam_d writes (Mzsoar)s comments read: anyone had any experience with the EW looger. It's about half the price of the others. __Mike They are OK if you operate them correctly ... as the internal battery can run flat very quickly. The don't have any ENL recording so are not suitable in Turbos/Self Launchers. Firstly, the latest model (D) can run on external power. Although the D will run from internal power if it is turned on and _then_ connected to external power. Just make sure you do it the correct way round -- Tim - ASW20CL "20" |
As others have said, you will need a gps to send data
to the EW logger. I would suggest a Garmin. It seems if you show up at a fun-fly or a contest, there may be others there with EW/Garmin combinations, and getting turnpoints and doing downloads might be easier if others are in the same 'group.' I have a Volkslogger. Compare the cost of it with the EW/separate gps. (Cost in U.S. Dollars) 1. Volkslogger: $800 2. Goddard power supply and cable: $130 +/- (I forgot actual cost) 3. Compaq 1520 (from e-bay about three years ago and I paid way too much. Your mileage may vary. ) 4. The 'free-ware', PocketNav, (or whatever it is called) from Cambridge for the Compaq 5. Software sold by Paul Remde, created by Henri Birecki, that transfers the Volklogger igc file to the Compaq. With this $20 piece of software, I don't need a notebook computer to download the Volkslogger at the field. However, I won't be able to upload any data to the Compaq or Volkslogger at the field, unless I borrow someone's computer. Hopefully, I'll have all the data I will need (cross my fingers) when I get to the field. Total cost: $950, not including pda. So yes, you can get an EW and a gps for less than $950. The good thing about one model of the EW is that it has the internal battery. The Volkslogger has no internal power source and power must be provided via the cable that also sends and recieves data. Ray Lovinggood Carrboro, North Carolina, USA At 12:06 10 September 2003, Jose M. Alvarez wrote: Recently I decided for a Volkslogger. Easy installation, screwed it in place of the camera, small, GPS included. IGC files perfect. Several friends have EW and have trouble with downloads, plus you need another GPS to connect. If I were you I'd go for a Volkslogger. Besides, the EW is not that cheap! Jose M.Alvarez 'Eric Greenwell' escribió en el mensaje . .. In article , says... Most other loggers include a GPS the EW does not and has to be used with a specified GPS for ICG approved flights. This aspect makes it more work for you and your official observer, if you go for badges or records. It is also limited to the Diamond badge and lower. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) |
Looking back over the comprehensive posts under this recent thread,
I'm curious that the Thermi was not included in the discussion? Is it not a suitable FAI approved logger/gps that can drive programs like WinPilot on an iPaq Pocket-PC? How does Thermi differ from Colibri or Volkslogger? I am interested to hear comments in this regard . . Thanks Jim Kelly. "Martin Hellman" wrote in message om... | Kevin Neave k wrote in message ... | Anyone out there got any views on the pros & cons of | the Colibri vs Volkslogger? | | They're about the same price / size etc. | | Anyone used both & have a preference? | | (I'll probably end up connecting the logger to an LX160s | vario & a PDA running the free version of Cambridge | PC-Nav) | | Cheers | | A friend of mine has the Volkslogger and I have the Colibri. I prefer | the Colibri because of its larger memory and FIFO software. That is, | when the Colibri runs out of memory, it overwrites the oldest flight, | whereas if memory serves me, the Volkslogger just stops recording. | Also, the Colibri is smart enough while you're waiting on the ground | to take off that it stops recording, while I believe the Volkslogger | wastes memory in that phase. [This is from memory and please correct | me if I'm wrong. But I did make this decision just a few months ago | and believe my memory is relatively accurate.] | | Even with engine monitor on (I fly a motorglider), I get over 70 hours | of memory from the Colibri, whereas the Volkslogger has a | significantly shorter time before you need to download. With 70 hours, | I never need to carry a laptop with me and try to download. (A real | mess based on what I saw my friend try to do, though maybe he was new | to the unit then.) I just remove the Colibri, take it home, connect it | to my PC (and 12 v) and download via SeeYou. Real smooth. | | Martin |
Silver Badge Fun (?) | Mark Zivley | Soaring | 43 | July 14th 03 07:52 PM |
