If you have a Private Glider or Commercial Glider rating and want to fly light sport glider, I don't see the problem. You are already qualified to fly a glider above 10,000 MSL.
If you want to fly a self launch or "motor glider", it's a glider, that may qualify for "Light Sport" because it is speed limited. Get the self launch endorsement and go fly. You do not need a "light sport" rating. If it's certified as an "light sport airplane", then you need a light sport airplane rating, 8710-11 completed with two qualified instructors after training. Is the mud getting thinner now? BillT |
I plan to get an LSA add on. Talked to a couple of CFIs in SF Bay Area and they are confused about the rules. Can somebody provide specific pointers to support two-CFIs endorsements path?
Thank you |
FAR 61.303. Look at the sixth line down in the table (assuming you hold a US Driver's License. It refers to 61.321, which documents the endorsements required.
As I said before, I have done this path. It works. The hardest part is to submit the required form at the end to report the endorsement to the FAA. When I did it, it couldn't be done via IACRA. Instead, you need to submit for 8710-11. Note the -11 at the end; you can't use a regular 8710. Google it and CAREFULLY follow the instructions for the form. Lynn Alley "2KA" |
Thank you Lynn,
After reading FAR 61.303 about 10 times I now understand it. Your help appreciated. -Val |
First glider flight toward rating add-on | BrianM | Soaring | 0 | June 7th 13 07:24 PM |
Glider rating near Sacramento | Robert M. Gary | Piloting | 19 | March 8th 06 09:34 PM |
Get the first ATP - Glider rating in the USA! | Mark James Boyd | Soaring | 0 | December 6th 04 07:06 PM |
Glider Rating | ... | Soaring | 6 | February 18th 04 04:40 PM |
rotorcraft commercial rating or better rating advice | Rick Cook | Rotorcraft | 0 | October 13th 03 04:49 PM |
