"John Galloway" wrote...
Which software does send a new bugs adjusted polar to the 302? Will it make the PDA software, the 303 final glide altitudes, and the 302 speed to fly all use the same polar? My homebuilt software changes the polar in the 302 when the bug setting is changed. This affects the 302 STF indications, but would not, to my knowledge, change anything in the 303 (I don't have one). The 303 listens for changes in ballast, MacCready, etc., from the 302, but there probably isn't any way for it to know that the polar has changed. The only way to get bug support in the 303 is to lobby Cambridge to change the firmware. Marc |
Marc,
Thanks, I understand now. That would be a step in the right direction and I think that a new pre-calculated polar sent to the 302 will probably be used by the 303. However that is not quite the same as the 302 having the ability to calculate a new polar for itself from a bugs setting entered on e.g. a hypothetical new bugs factor screen which is what I think would be far more generally useful (essential) in that it could be used no matter what software is used in the PDA or even with no PDA for 302/303 users. In the case of ballast settings, I think that GN11 sends a setting to the 302 (which then calculates the ballast adjusted polar internally) rather than sending a newly calculated polar, so the 302 should be able to do the same for bugs settings sent from the PDA - IMHO. Another note to CAI I think. John Galloway At 18:42 13 September 2003, Marc Ramsey wrote: 'John Galloway' wrote... Which software does send a new bugs adjusted polar to the 302? Will it make the PDA software, the 303 final glide altitudes, and the 302 speed to fly all use the same polar? My homebuilt software changes the polar in the 302 when the bug setting is changed. This affects the 302 STF indications, but would not, to my knowledge, change anything in the 303 (I don't have one). The 303 listens for changes in ballast, MacCready, etc., from the 302, but there probably isn't any way for it to know that the polar has changed. The only way to get bug support in the 303 is to lobby Cambridge to change the firmware. Marc |
