Tow rope length?
Old October 19th 16, 02:09 AM posted to rec.aviation.soaring
BravoMike
Default Tow rope length?
For the sake of this discussion I have just posted my video from 2013 taken at my home Aeroklub Poznanski with a 10 m rope tow given to Jerzy Makula:
https://youtu.be/eBInTKSbq_Y
Incidentally, the rope proved to be so short that the poor girls had to push the glider by 0.5 meter to hook it up.
Enjoy!
BravoMike
Old October 19th 16, 02:47 AM posted to rec.aviation.soaring
Enjoy!
BravoMike
That is the best soaring recruitment video I have ever seen.
Old October 19th 16, 11:01 AM posted to rec.aviation.soaring
Bruce Hoult
I'm disappointed they didn't roll inverted (or via half-loop) during initial climbout.
Maybe more power is needed?
Old October 19th 16, 02:13 PM posted to rec.aviation.soaring
WAVEGURU
So the question remains unanswered. Why not use longer ropes for added safety? The shorter the rope, the harder the tow. I wonder if there are any accident statistics?
Boggs
Old October 19th 16, 05:21 PM posted to rec.aviation.soaring
son_of_flubber
I was happy to have a longish towrope when the right landing gear of a Pawnee collapsed at 30 knots and prop strike. (Just enough time and space to avert collision.)
The other day I saw a CG hook launched glider go out of position and pull the tug's tail sideways. A longish rope made this recoverable.
Old October 19th 16, 02:39 AM posted to rec.aviation.soaring
"Too close for missiles. Switching to guns."
Old October 19th 16, 02:58 PM posted to rec.aviation.soaring
Surge
On Tuesday, 18 October 2016 15:18:15 UTC+2, Waveguru wrote:
It seems that most operations here in the USA use a 200' tow rope, and I've heard that some places in Europe even use a rope as short as 120'. Ropes at our operation are more like 275' because it seems safer and easier when it's longer. What is the rational behind using shorter ropes? I see no reason for short ropes unless you are towing out of a short field.
Boggs
One reason I can think of for a shorter rope is the extra height a tug aircraft requires to clear an obstacle (such as a fence or power line) while landing. Every little bit of extra height greatly increases the required landing distance but if the airfield is that small it probably shouldn't be used for aerotow operations because what is your safety margin on takeoff?
There is always the option of dropping the rope before rejoining the circuit and landing if obstacles are an issue.
Less than 45 meters (150 feet) is looking for trouble IMO.
Antenna and Coax Length ContestID67 Soaring 16 February 3rd 07 06:32 PM
oil and length of time for break-in Matt Owning 6 December 14th 05 03:27 AM
Gyrocopter VHF antenna length Lew Home Built 2 August 18th 05 01:52 PM
antenna length Ken Home Built 4 March 31st 05 05:25 AM
F-104 Zero Length Launch Bjørnar Bolsøy Military Aviation 0 January 4th 04 11:40 PM
