FLARM A minimum spacing to ADS-B Antenna? 1 foot !?!?
Old October 27th 16, 04:09 PM posted to rec.aviation.soaring
OHM Ω
Default FLARM A minimum spacing to ADS-B Antenna? 1 foot !?!?
Maybe this has been covered in RAS but I couldn't find it. I looked through two documents about the spacing of FLARM antennas, specifically the FLARM A and ADS-B antennas. Obviously, the thing to avoid is the transmitting of FLARM data (A antenna) interfering with ADS-B (or GPS) reception.
The FLARM document "PowerFLARM_Application_Note_ANTENNAS1.pdf"* has the following information about antenna spacing. It doesn't mention a minimum distance between the FLARM A and ADS-B antennas;
Keep antennas separated as far as possible!
Min. distance between RF antenna on FLARM A and FLARM B port: 1ft (0.3 m)
Min. distance between RF antenna on FLARM A port and GPS antenna: 1ft (0.3 m)
Min. distance between RF antenna on FLARM B port and GPS antenna: 4in (0.1 m)
Min. distance between ADS-B / XPDR antenna and GPS antenna: 4in (0.1 m)
The FLARM Core V2.0 manual** says the following in the section on ADS-B antennas;
"This antenna should be placed at least 30cm/1ft away from the FLARM antennas. The FLARM antennas have priority over this antenna for best placement."
1 foot (30cm) spacing within our tight glider cockpits is going to be a struggle. Based on the FLARM portable (might not be the best example) the two antennas are only 2.5" (0.06 m) apart.
Anyone have more information on this spacing conundrum?
Thanks, John "OHM"
* http://cumulus-soaring.com/flarm/Pow..._ANTENNAS1.pdf. I don't see it on the FLARM.org web site. Was it superseded?
** https://flarm.com/wp-content/uploads...anual-2.00.pdf
FLARM Antenna Hall of Shame? Dave Nadler Soaring 4 July 21st 14 09:22 AM
FLARM antenna mounts for ASG-29 Sean F (F2) Soaring 20 September 11th 13 02:35 PM
Nice FLARM antenna mount in ASG-29 Dave Nadler Soaring 8 April 6th 13 09:49 PM
Again with FLARM antenna questions. brianDG303[_2_] Soaring 0 July 23rd 12 05:35 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
