#11
Oops, meant 247
"Scott" wrote in message ... G103 allows for up to 147 i believe. "Eggs" wrote in message et... What's the L/D on a C-47? Does it come in a kit? What do you use for a tug? Maybe I should phrase my question thus: Even a slender rough and tough me isn't going to weigh less than 220. Seriously. So should I just give up this soaring dream and go back to fuel-sucking noisemakers? Perhaps my question was too tongue-in-cheek, but it was a serious nonetheless. Thanks, Curt "John Shelton" wrote in message nk.net... You can be so fat that you have to be lifted out of your room with a Sikorsky Skycrane just to go to the crapper. You will just need a C-47 for a glider. If you want to fit into any of the other ones, you might consider burning a little more than you consume for a while. A half hour walk a day until the vernal equinox should just about do it. Or, as an alternative, I would suggest, as an appetite suppressant, taking up smoking profusely. --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.512 / Virus Database: 309 - Release Date: 8/19/2003 -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.512 / Virus Database: 309 - Release Date: 8/20/2003 -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
I wonder how many of these flying "over seat max" are ones that are having
the wings come apart. You can do what you want.. but over limit is over limit.. And there is also a limit.. for some but not all gliders.. of "max weight of the non lifting parts"... BT "Be wary of buying a glider from a big (fat) pilot" "Bruce Greeff" wrote in message ... Another option is the Schempp-hirth Standard Cirrus it's comfortable for my 6'2" 235lb lump of humanity. Much over 6'4" and there will be no headroom but the cockpit is wide and the CG range reasonable too. Not particularly forgiving of hamfisted beginners but a very nice glider - particularly if you fly precisely. Cockpit limit is oficially 110kg but I have seen a lot more than that flying them quite safely. The seatbelts are certified using a 110kg mass - hence the limit. George William Peter Reinhart wrote: Eggs, Don't give it up just because you're not one of those underfed, shrimpy european body types whose max weight by regulation can never be over 242 lbs. I can assure you that the Nimbus 2 I recently sold had more than adequate space for a Texas sized pilot and a C. G. range to match. The LS-4 comes to mind as a wonderful glider to fly and a spacious cockpit as well, if you get one with a tail battery box, you'll probably be able to tailor the C.G to suit you. There are others that come to mind as well so look around some and you'll find a wide choice available. My understanding of the 242 max cockpit weight for most recent Euro gliders is that it is the minimum weight for certification of the cockpit restraints under JAR 22 and has little to do with the actual strength of the airframe. I remember that the LS-!F had around 276 as the max cockpit weight. It'll be a tight fit though. Cheers!, Pete Eggs wrote in article . .. What's the L/D on a C-47? Does it come in a kit? What do you use for a tug? Maybe I should phrase my question thus: Even a slender rough and tough me isn't going to weigh less than 220. Seriously. So should I just give up this soaring dream and go back to fuel-sucking noisemakers? Perhaps my question was too tongue-in-cheek, but it was a serious nonetheless. Thanks, Curt "John Shelton" wrote in message link.net... You can be so fat that you have to be lifted out of your room with a Sikorsky Skycrane just to go to the crapper. You will just need a C-47 for a glider. If you want to fit into any of the other ones, you might consider burning a little more than you consume for a while. A half hour walk a day until the vernal equinox should just about do it. Or, as an alternative, I would suggest, as an appetite suppressant, taking up smoking profusely. |
I understand that the maximum cockpit weight is the lowest figure set by the
following four limitations: Max. all up weight for the whole glider. Max. weight for the non-lifting parts. Max. weight by moments (forward C. of G. limit). Max. weight per the handbook (weight the seat, seatbelts etc. is stressed for). The placard should show the lowest of the above weights as the maximum. It is quite normal for a tandem two-seater flown solo (e.g. K21) to have a maximum weight over 300 lbs. for the front seat on the first three criteria, it is the seat stressing case which limits it to 110kg. (242lbs.). W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Eggs" wrote in message et... The soaring bug is in me. But unfortunately so is that chicken-fried steak, mashed potatoes, fried okra, turnip greens and apple pie I had for dinner. I'm a fairly big guy; six foot, one inch tall, broad shoulders. Let's put it this way... I can't drive a Miata. Assuming I crack the scales at the beginning of next years' season at say, 240, am I going to be able to find a plane that can handle both me and an instructor? Am I going to be able to find a ship of my own later? That I can afford (read: cheap)? Be honest. I can sniff take it. Curt |
I agree - was not endorsing overloading or uncontrolled experimenting.
Best approach is to lose weight. (Muscle or Fat) |
On Thu, 25 Sep 2003 16:39:21 -0700, "BTIZ"
wrote: I wonder how many of these flying "over seat max" are ones that are having the wings come apart. I've seen a Lo-100 shred its wing during a roll - the pilot's parachute opened 100 ft over the ground. He was nearly 100 pounds overweight. Bye Andreas |
parachute opened 100 ft over the ground. He was nearly 100 pounds overweight. It's bad enough flying over gross... but intentional rolls?? one lucky pilot.. with a Wylie Coyote parachute.. BT |
Proof that demonstrating sufficient skill to be allowed to fly a glider
does not imply having the sense to avoid killing yourself in one... Flying overweight implies that you have made the safe flight envelope smaller. You are in the experimental area - even if you neglect to register this by moving the glider to the experimental category. Low level aerobatics are high risk at the best of times. Not a good place to be testing where exactly the envelope limits are. Andreas Maurer wrote: On Thu, 25 Sep 2003 16:39:21 -0700, "BTIZ" wrote: I wonder how many of these flying "over seat max" are ones that are having the wings come apart. I've seen a Lo-100 shred its wing during a roll - the pilot's parachute opened 100 ft over the ground. He was nearly 100 pounds overweight. Bye Andreas |
Jeff Dorwart wrote:
Perhaps there is a Schweitzer 2-32 available in your area. Useful load 231 Kg/509lbs. Designed to carry three adults but makes a good trainer with two big guys. jbd I've flown a 2-32 and have heard a lot of things said about them. Having it called a "good trainer" has never been one of them. I can't imagine any club or FBO that would solo a student in one. Tony V. http://home.comcast.net/~verhulst/SOARING/index.htm |
![]() "Tony Verhulst" wrote in message ... Jeff Dorwart wrote: Perhaps there is a Schweitzer 2-32 available in your area. Useful load 231 Kg/509lbs. Designed to carry three adults but makes a good trainer with two big guys. jbd I've flown a 2-32 and have heard a lot of things said about them. Having it called a "good trainer" has never been one of them. I can't imagine any club or FBO that would solo a student in one. Tony V. http://home.comcast.net/~verhulst/SOARING/index.htm I've flown 20 or so different 2-32's and the handling varied greatly from quite docile to damn tricky. This could not be attributed entirely to weight or CG location so I put it down to poor quality control at the factory. However even the worst became more docile with forward CG. I would think if you are lucky and find a docile one and the big guy moves the CG far enough forward, it would be possible to solo a good student in one. Lots of qualifiers here. Bill Daniels |
"Eggs" wrote in message . net...
The soaring bug is in me. But unfortunately so is that chicken-fried steak, mashed potatoes, fried okra, turnip greens and apple pie I had for dinner. I'm a fairly big guy; six foot, one inch tall, broad shoulders. Let's put it this way... I can't drive a Miata. Assuming I crack the scales at the beginning of next years' season at say, 240, am I going to be able to find a plane that can handle both me and an instructor? Am I going to be able to find a ship of my own later? That I can afford (read: cheap)? Be honest. I can sniff take it. Curt ************************************************** ******************************** You would easily fit in a Genesis 2. Following was lifted from the GenesisFlyers Yahoo site. It was posted sometime in 2000. Hello Genesis lovers... Dave wrote... "First of all, a pilot's "sitting height" will limit his fit at one of two spots: the stick or the canopy...". Let me begin my reply with a Big Thanks for all the helpful comments from list members (I am the fellow who "doesn't fit" and therefore started this thread). Allow me to elaborate on my position (literally!)... All humans (99.999%) are born with a certain number of vertebra, either "X" (I forget the exact number) or "X+1". Those with "X+1" are called "long waisted". Your vertebra size will be proportionate to your frame size (i.e. taller people will have larger vertebra). I am an "X+1" guy who is 6'5" tall. Therefore, the very tall "sitting height" (a term which almost- solely decides what ejection-seat jets you are allowed to fly in the military) is reflective of a "X-vertebra" person 6'7" to 6'8" tall. In a Genesis, I have absolutely NO PROBLEM fitting in the cockpit from a stick/pedal standpoint. Head room is the only issue. In fact (shameless plug) I was a Designer, Cockpit Displays and Operational Logic Subsystem for the B-() bomber, and can say as a professional crewstation designer that the G2 is not just "a good glider cockpit", but a marvel of efficiency and in fact a superb design. If anybody does not "like" something about the G2 cockpit, it is because of a personal preference lying outside the realm of "optimized effectiveness" (and yes, improvements could undoubtedly be made but they would be trivial). All of the "fit" suggestions made by list-members were tried by me at Lift 2000. No-go. But hey! I'm a giant and "fitting everybody" would make for a sport-glider, not a hi-performance machine. A G2 sized as an LS-8 (i.e. "cockpits for midgets" ![]() vertically-challenged) would likely stomp the competition back into the stone age. |
