JJ Sinclair wrote:
Kirk, I agree with you that competent, current pilots, don't inadvertently stall any ship. But your statement that you like a crisp stall, got me wondering. How do you like a crisp stall, in the pattern, after some hard maneuvering to avoid a mid-air? How do you like a crisp stall, when on the rocks, and get hit with a large tail-gust? The stall I got in my LS-7, after adding zig-zag to the horizontal stab, was the worst stall I have ever seen in any sailplane. I mean she went near vertical on me. Don't care to duplicate that in the above situations. PS, I suspect the zig-zag delayed the *normal* seperation on the stab, but when it did seperate, I lost all the down force from the horizontal stab and that gave me the near vertical pitching moment. The wing may not have stalled at all. Now someone please feel free to tell me just how full of Ka-ka, I am about aerodynamics. :) JJ Sinclair I am not an expert in aerodynamics, but I don't agree with your above interpretation. It implies that just below the stall your elevator was producing a down force, near the maximum possible or rather the (negative) lift coefficient was near its maximum possible value and this maximum value was reached when you lost control, before the wing reached its maximum (positive) lift coefficient. It seems to me that it is an error to believe that more down force on the tail plane is needed for obtaining an higher nose up attitude. As airfoils commonly used in sailplanes are unstable, more nose up attitudes tend to self amplify when you consider only the forces on the wing and the tail plane has to counter this by a lower down force (or a higher up force, depending on position of the CG). This is not in contradiction with the fact that you need aft stick in order to keep a higher nose up attitude. This change of attitude also change the angle of attack on the tail plane by an amount exceeding the variation of force needed and the back stick has to compensate for this. For these reasons I think that when you come closer to the stalling angle of attack for the wing, the tailplane on the contrary is far from its stalling angle of attack. When the wing reaches its stalling angle, a further increase in angle of attack will lower the lift coefficient, thus increasing again the angle of attack due to the glider beginning to fall and so on. This also increases the angle of attack on the tailplane which produces an upward force, despite the full aft stick, and this produces the pitching moment that makes the nose drop. It would be logic to think that in this case, the increased efficiency of the the tail plane due to the added turbulator increases the pitching moment and brings the glider more quickly closer to a vertical dive. |
I'm not aware of any glider that stalls from a sharp
break stall on the horizontal stab, though many of us have experienced running out of elevator authority - just try any combination of pushing the c.g. forward or increasing the bank angle in a turn to make this real (I have, and it's annoying in a thermal, though not particularly dangerous unless taken to extremes). Turbulator tape trips the boundary layer from laminar to turbulent and should allow the elevator to create lift at higher, rathern than lower angles of attack, so unless you change the wing or tail incidence it's hard to imagine that it would lead to the tail stalling first. What likely happens is it gives you enough additional authority to get the wing to really stall, rather than mush around just past max Cl angle of attack. I won't say whether this is good or bad per se. 9B At 20:30 14 October 2003, Bill Daniels wrote: JJ, you are about right on. I strongly suspect that if a glider 'stalls' but retains aileron control, the wing didn't really stall - just the horizontal tail lost its grip on the air and let the tail pop up (Nose pops down). Normally, this is a pretty benign way to limit minimum airspeed. Adding any device to increase up elevator authority might allow the pilot bring the whole wing to stall with the possibility of a spin departure. It seems to me that the only reason to increase up elevator authority would be to improve thermaling and then only in the case of a glider whose minimum airspeed is limited by up elevator ineffectiveness. A case might be the G103 Twin II when the CG is near the forward limit. This limits minimum airspeed to well above minimum sink in a steep turn. Bill Daniels 'JJ Sinclair' wrote in message ... Kirk, I agree with you that competent, current pilots, don't inadvertently stall any ship. But your statement that you like a crisp stall, got me wondering. How do you like a crisp stall, in the pattern, after some hard maneuvering to avoid a mid-air? How do you like a crisp stall, when on the rocks, and get hit with a large tail-gust? The stall I got in my LS-7, after adding zig-zag to the horizontal stab, was the worst stall I have ever seen in any sailplane. I mean she went near vertical on me. Don't care to duplicate that in the above situations. PS, I suspect the zig-zag delayed the *normal* seperation on the stab, but when it did seperate, I lost all the down force from the horizontal stab and that gave me the near vertical pitching moment. The wing may not have stalled at all. Now someone please feel free to tell me just how full of Ka-ka, I am about aerodynamics. :) JJ Sinclair |
Kirk Stant wrote
ITS MY LIFE AND I CAN DO WHAT I WANT WITH IT, THANK YOU VERY MUCH! Kirk (last bastion of stupid individualism) 66 I would defend to the end your right to do what you want with your life. Sadly it is not those who kill themselves that is the problem, it is The 'friends' left behind who have to scrape the bits of the airfield and shovel them into a body bag. (Yes I have done it) The relatives who have to be comforted. (And this) Followed by the thieving grasping lawyers who make a fortune out of the grief left behind. (and seen this happen) So come on take care have a thought for the others you will leave behind and make sure the lawyers have to live of state benefits and our premiums stay low. If you want to kill yourself go out quietly and shoot yourself please do so. It is also easier and cheaper. Please! |
Kirk Stant wrote
Meanwhile, the rest of you guys out there relax, I appreciate your concern but I haven't reached this ripe almost old age by doing really stupid things. Mildly stupid things, perhaps (like paying too much attention to RAS). Kirk 66 Point taken! Half the trouble is most gliding clubs have a box at the gate where many members leave their brains, spend a day on the airfield and then collect the brain on the way home. Sorting out .......those who know what they are doing from .... those who think they know what they are doing from .....those who know absolutely nothing but go on and do it anyway from....... those who can't do it but have seen somebody else do it so they will try it anyway All goes to provides a headache for the fun police, who can't do right for doing wrong....! Hope the turbulator tape works. Dave |
Dave Martin wrote in message ...
Kirk Stant wrote Meanwhile, the rest of you guys out there relax, I appreciate your concern but I haven't reached this ripe almost old age by doing really stupid things. Mildly stupid things, perhaps (like paying too much attention to RAS). Kirk 66 Point taken! Half the trouble is most gliding clubs have a box at the gate where many members leave their brains, spend a day on the airfield and then collect the brain on the way home. Sorting out .......those who know what they are doing from ... those who think they know what they are doing from ....those who know absolutely nothing but go on and do it anyway from....... those who can't do it but have seen somebody else do it so they will try it anyway All goes to provides a headache for the fun police, who can't do right for doing wrong....! Hope the turbulator tape works. Dave Hello all I have a Phoebus C with all-flying tail. It has a very thin profile. I had contakt with a german pilot that "had heard somewhere" that you could improve the plane by attaching turbulators on the elevator. Because the plane has some odd stall habbits ( compared to modern planes), I wouldn´t like to try it out whitout to here from somebody with experience with it. So my question is: do anyone of you know where I could get first hand information in the matter. Matts |
On 17 Oct 2003 00:48:22 -0700, (Phoebus_810)
wrote: Hello all I have a Phoebus C with all-flying tail. It has a very thin profile. I had contakt with a german pilot that "had heard somewhere" that you could improve the plane by attaching turbulators on the elevator. Because the plane has some odd stall habbits ( compared to modern planes), I wouldn´t like to try it out whitout to here from somebody with experience with it. So my question is: do anyone of you know where I could get first hand information in the matter. Ask he Fiberglas-Technik Rudolf Lindner GmbH & Co. KG, Steige 3, D - 88487 Walpertshofen Tel: 07353/2243 Fax: 07353/3096 E-Mail: http://www.ltb-lindner.com/index.html They are the ones who are taking care of the Phoebus. The owner, Helmut Lindner, is the son of Rudi Lindner (who designed the Phoebus). Bye Andreas |
Question from a new flight student (whopping 7 hours!) | Gary G | Piloting | 90 | October 21st 04 11:48 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
