FLARM - No GPS
Old November 24th 16, 01:08 AM posted to rec.aviation.soaring
Dan Marotta
Default FLARM - No GPS
It worked fine last time I flew but today, it was stuck on the startup
screen with 0 Satellites showing. I cycled the power a couple of times
with no effect. Both my ClearNav vario and my Dell Streak were both
receiving good GPS locks. The Streak reported 8 satellites.
The PF Portable had been stuck on my glare shield using Dual Lok
fasteners but, a few days ago I fabricated an aluminum plate to bolt the
portable to and then screw the plate to the glare shield. That should
make no difference, but I thought I would tell all.
Being new to this, I have no idea where or how to look for faults. The
PF receives switched power from the DC bus. It has 3 antennae hooked to
it, and its serial port is connected to one of the inputs of a
K6BT-Mux. The other input of the Mux is connected to the serial output
of the CN vario. The Bluetooth radio transmits to the Dell Streak
running XCSoar. On the Streak, I can monitor the interface traffic out
of the Mux. I saw sentences from the Flarm and the ClearNav vario. The
data stream from the CNv had good GPS information and the $PF sentences
appeared to have zeros instead of position data. That would agree with
the startup screen.
It's my understanding that, absent a good GPS signal of its own, the PF
portable should use the GPS data from the vario.
Can anyone offer any advice?
Dan, 5J
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
