Lilium: the world's first 250mph, 300 mile range, electric vertical take off and landing jet
Old December 9th 16, 11:27 PM posted to rec.aviation.piloting
Larry Dighera
Default Lilium: the world's first 250mph, 300 mile range, electric vertical take off and landing jet
https://www.youtube.com/watch?v=JZbWsgAIc_c
Lilium: the world's first electric vertical take off and landing jet
Published on May 8, 2016
The egg-shaped plane, called Lilium, has been heralded as high up as the
European Space Agency (ESA)
The plane, designed by four German engineers, takes off and lands vertically,
meaning it can use helipads
Lilium has a top speed of 250mph, a range of 300 miles and only requires 50
feet by 50 feet of space
Read mo http://www.dailymail.co.uk/travel/tr...rticle-3579328
Flying in the city? The first electric vertical take-off and landing jet. BMW
Welcomes
Is this the future of private jets? The world's first electric vertical
take-off and landing plane that you can fly out of your back garden
vertically, meaning it can use helipads
By John Hutchinson for MailOnline
Published: 05:49 EST, 8 May 2016 | Updated: 07:45 EST, 8 May 2016
Private jet flying could change forever as the world's first electric vertical
takeoff and landing aircraft is about to hit the market.
European Space Agency (ESA), who highlight its environmental benefits as well
as not needing to land at an airport.
The plane takes off and lands vertically, meaning it can use helipads. The
aircraft, designed in Germany, has a top speed of 250mph and a range of 300
miles.
The plane is designed to be able to be flown in good weather conditions in
uncongested airspace in the daylight
In a release sent out from the ESA, Lilium co-owner Daniel Wiegand said: 'Our
goal is to develop an aircraft for use in everyday life.
'We are going for a plane that can take off and land vertically and does not
need the complex and expensive infrastructure of an airport.
'To reduce noise and pollution, we are using electric engines so it can also be
used close to urban areas.'
RELATED ARTICLES
The electric jet is set to be available to buy in 2018, although at the time of
writing, there is no indication of how much the futuristic plane will cost.
The plane has been designed with environmental targets in mind. As well as
being electric meaning there are less emissions, the plane will be a lot
quieter than the traditional private jet as it uses ducted fan engines.
The environmental benefits of Lilium have been heralded, as well as the fact
that it does not need to land at an airport
aircraft has a top speed of 250mph and a range of 300 miles
THE VITAL STATISTICS
Take-off and landing - Vertically
Steering -Easy to fly (Fully computer-assisted control system)
Number of passengers -2
Max. take-off weight - 600 kg
Cruising velocity - 180 mph
Max. velocity 250 mph
Range - 300 mi
Power - 435 hp
The ESA state that although the aircraft will primarily be using airfields for
landing and take-off, 'the goal is for it to take off vertically from almost
anywhere – even from back gardens.'
A pilot's licence stipulating at least 20 hours of training is needing to guide
the two-seater plane, that fits into the Light Sports Aircraft category.
A point to note is that the aircraft is designed for flying in daylight, where
the weather conditions are 'good.'
A description of the private jet on the designers's website reads: 'Elegance,
speed, comfort and sustainability – fusing to a new form of traveling, defining
a completely new form of freedom.'
Due to its smaller size, it will not have to fit into airport scheduling to
land and take off.
The project, run by four Munich University graduates, began in 2015 with
several prototypes based on a similar model.
This, however is the group's first vertical take-off and landing aircraft.
Popular Science says that 'the whole plane should fit comfortably in an area 50
feet by 50 feet, or roughly the same area as a modest helipad.'
Lilium has been designed by German engineers Daniel Wiegand, Patrick Nathen,
Sebastian Born and Matthias Meiner.
It is even believed the plane will be able to fly out of the owner's back
garden such is the small amount of space it needs to take off
Read mo
Personal aircraft aiming to take off from your home / TTP2 / Space
Engineering & Technology / Our Activities / ESA
http://www.esa.int/Our_Activities/Space_Engineering_Technology/TTP2/Personal_aircraft_aiming_to_take_off_from_your_hom e
http://www.popsci.com/lillium-wants-...quieter-future
Lillium: The Private VTOL Plane Of A Quieter Future
The Jetsons? No, they're our loud neighbors. We're the Ducted Fandersens.
By Kelsey D. Atherton May 6, 2016
Lillium Concept Plane
Vertical takeoff and landing, too
The European Space Agency is incubating a new kind of aircraft. Revealed today,
the glossy, white, egg-like form of the craft resembles nothing so much as an
airplane designed by Apple. The planned two-seater will be all-electric, built
for personal use, and, thanks to pivoting engines, it can take off from
helipads instead of runways.
Dubbed Lillium, the craft when built is expected to travel at around 250 mph,
faster than most helicopters but well below the speeds of private jets. The
whole plane should fit comfortably in an area 50 feet by 50 feet, or roughly
the same area as a modest helipad. It will also take part in a modern, quieter
revolution in aircraft design: planes designed with noise reduction in mind.
From the European Space Agency:
Entirely electric, the plane is much quieter during takeoff than
helicopters thanks to its ducted fan engines. Its batteries, engines and
controllers are redundant, making it a much safer design than conventional
helicopters. The plane is classed as a Light Sport Aircraft for two occupants,
with the pilot’s licence requiring 20 hours’ minimum training – almost like
taking a driving licence.
It is intended for recreational flying during daylight, in good weather
conditions and in uncongested airspace up to 3 km altitude.
Watch a short clip of the concept below:
[Click for video]
Tags:
airplanes vtol ducted fans ESA European Space Agency concepts gifs Video
lillium Aviation
Editors' Picks
Old December 10th 16, 01:40 AM posted to rec.aviation.piloting
Vaughn Simon[_2_]
Default Lilium: the world's first 250mph, 300 mile range, electricvertical take off and landing jet
Even if it were the world's first VTOL electric "jet" (which is isn't)
you can't make that claim until the plane has actually been built and
flown. (No evidence of that in the links)
As for the 250 MPH speed and 300 mile range claims, given today's
technology I call "bull****". At best, you MIGHT be able to build a
plane that would be sufficiently optimized to give you one of the above,
definitely not both.
Old December 10th 16, 08:56 PM posted to rec.aviation.piloting
Larry Dighera
Given the GOPesque puffery, the Lilium's marketing is consistent with the
mendacity of Trump. :-)
Old December 10th 16, 11:11 PM posted to rec.aviation.piloting
My take was it was written by someone that does not know much about aviation.
Jim Pennino
Old December 10th 16, 03:14 AM posted to rec.aviation.piloting
Not with a cruise speed of 180 mph.
Jim Pennino
PowerFlarm: 2.7 Vertical Range [email protected] Soaring 8 April 10th 13 12:27 AM
Vertical and Short Takeoff / Landing Fighters Aviation Naval Aviation 7 January 5th 04 09:49 PM
Vertical and Short Takeoff / Landing Fighters Aviation Military Aviation 6 January 5th 04 02:18 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) ArtKramr Military Aviation 2 August 27th 03 12:06 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
