Winglets for SZD55
Old February 11th 16, 01:08 PM posted to rec.aviation.soaring
Default Winglets for SZD55
As an owner of a SZD 55 I am interested in the comments of Peter Masak about winglets on the 55, but couldnt find the above mentioned results when typing Peter Masak SZD55 into google - does anyone here have a link?
Anyway, I'd also like to see pictures of a 55 with winglets, just out of pure curiousity - simply cant imagine how winglets work and look like with the very special shape of the 55 wings.
BTW - wasnt the 55 wing especially designed to work without winglets, turbulator tape etc.?
Regards,
Michail
Old February 14th 16, 06:50 PM posted to rec.aviation.soaring
On Monday, October 13, 2003 at 1:29:23 PM UTC-8, Tom and Jane Gilbert wrote:
Any 55 owners fitted winglets to their ships? Thoughts... comments??
Tom Gilbert
I have SN 39, modified with Nelson winglets which look a lot like ASW 27 winglets, and I
suspect are more effective than the LS-8 bent up tips. Compared to my recollections of another
'55 that I owned (SN 29) low speed roll control is improved-- which helps with partial
ballast take offs.
On the subject of how much water to put in, Jerzy Szemplinski once told me about the '55:
"Bill, you fill it. You always fill it!"
Old February 14th 16, 08:47 PM posted to rec.aviation.soaring
Tom & Jane Gilbert
Hi Bill. At that time (12 years ago!!) I was looking for ways to tame the
take off habits of my '55. Because of my weight (max cockpit) I had to fly
with partial ballast only. Filling it would greatly exceed max all up
weight. Because of the long skinny tanks the partial water load would move
when the wing dropped on take off... something it almost always did unless I
had a very athletic wing runner. So every take off was an adventure and
very entertaining to the onlookers. Having said that I never actually lost
it on take off. But wing down, everything in the opposite corner for an
extended period was not comfortable.
I sold my '55 a few years back. I loved it in the air and it was a rocket
at max weight. It held the Australian 300k out and return for a while at
147kph. I sold it because I considered it to be not the best glider to grow
old in. The new owner (much younger than me) loves it. I now fly a
DG-400... much more in keeping with my aging abilities!!
Best regards,
Tom Gilbert
Tom Gilbert
winglets, and I
with partial
ballast take offs.
about the '55:
Old February 15th 16, 05:51 AM posted to rec.aviation.soaring
Paul B[_2_]
Hi Tom and Bill
I am also flying 55, and I have some 600 hours in it. I am like Tom, at max cockpit weight. I seldom fly with water and if so only partially full. With or without water I tend not to drop wings though. I take off with partial airbrake, full forward trim and stick on the front stop. I do not finesse the ailerons, they go from stop to stop. On the occasion that I have dropped the wing, as Tom said, everything in the opposite corner brings it up. It has never happened to me with water, so I cannot comment.
Interestingly I am keeping mine to get old, I can still lift the wing at the root with one hand, and I cannot do that with any other glider wing that I am familiar with.
I find the comments about flying with max all up weight intriguing, as I think that I thermal quite poorly(read fast) with water on board (all up 440 kg). Not sure if it is me or the glider.
I would appreciate any comments on the above.
Thanks
Paul
Best regards,
Tom Gilbert
Tom Gilbert
winglets, and I
with partial
ballast take offs.
about the '55:
Old February 15th 16, 09:29 PM posted to rec.aviation.soaring
Tom & Jane Gilbert
Your take off technique sounds pretty standard Paul. At max weight (135
liters of water in my case) a wing drop can be an issue. The '55 sits tail
down with a large angle of attack. The ailerons are not very effective
until you get the tail up and reduce that angle. If you have a cross wind
or quartering tail wind (the worst!!) you need to keep the tail wheel on the
ground for the early ground roll. So it's a fine balance. I have never
been able to fly it with full tanks so I can't comment on it's behaviour in
this case.
I take your point about the wing weight. A friend of mine bought a '55 for
that reason so he and his wife (small lady) could rig and de-rig without
assistance. I had a 201b Libelle for many years and describe the '55 as a
Libelle on steroids!
All gliders need to be flown faster in thermals when carrying water ballast.
From memory the '55 liked another 5 to 8 knots or so. But it handled the
weight well and never caused me a problem in that regard.
Tom
"Paul B" wrote in message
Hi Tom and Bill
am familiar with.
Thanks
Paul
fly
move
I
lost
grow
Best regards,
Tom Gilbert
Tom Gilbert
winglets, and I
with partial
ballast take offs.
about the '55:
Old February 16th 16, 11:25 AM posted to rec.aviation.soaring
Paul B[_2_]
Thanks Tom
Where did you put your CofG, mine is at 75%. Also what thermalling speed you used when empty(if ever ).
Cheers
Paul
Old February 16th 16, 08:56 PM posted to rec.aviation.soaring
Tom & Jane Gilbert
Probably about the same but I don't remember actually calculating that. I
installed a brass tail wheel (great mod) and always put an extra litre in
the tail tank when ballasted.
Empty thermalling 48 to 50 knots... down to 45 in very smooth thermals.
Tom
Thanks Tom
Cheers
Paul
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 03:09 AM
Wanted: Ventus C Winglets E.Mertins Soaring 1 October 14th 03 01:15 PM
